Samsung 912T click then off
Originally posted by PeteS in CARemember that by the time consequences of a short-sighted decision are experienced, the idiot who made the bad decision may have already been promoted or moved on to a better job at another company. -
Re: Samsung 912T click then off
Sorry. In my previous post I mentioned pin 6 as the voltage supply for the OZ960, it's actually pin 5. I also didn't realize the board was soldered in place. Ouch!! If you decide to unsolder it again, using your DMM, maybe you can trace back to one of the soldered pins for your measurement. Or, maybe you can trace back from pin 5 to the nearest capacitor or resistor and solder a small wire at that point and route the other end of the wire off to the side where you can take your measurement.
As for the fds4935 chip, it consists of two p-channel mosfets. The chip above it should have 2 n-channel mosfets. These two chips work together with the OZ960 to generate the square wave for amplification in the transformer(s).
I believe the clicking sound you hear is the power supply trying to start up. The sound might coming from a transformer. Try this the next time you turn on the display: place a cardboard tube taken from a paper towel roll and place it over the transformer (large yellow one T601) while listening to the other end. Move to other areas if that wasn't the source of the click. Also, try looking at the power supply in a darkened room to see if there's any arcing during the power on process.Comment
Maybe try testing ZD1 and ZD2 next to the burnt mosfetComment
A good fuse is 0.3 ohms or less. Some multimeters like mine will beep "good" if I use the continuity check feature. "good" is 25 ohms +/- 10 ohms.
So when I measured a picofuse and it was "good" with the continuity feature, but it was actually bad because it was 19 ohms.
With the dmm in diode mode, ZD1 reads .22, and reads the same with I swap the probes. ZD1 reads .72 with the red probe on the mosfet end, and open circuit with probes swapped. I think this means ZD1 is bad?
edit: If ZD1 is bad, it may have been the reason that caused the IC to go bad.Last edited by retiredcaps; 08-09-2010, 11:50 PM.--- begin sig file ---
--- end sig file ---Comment
Always do resistance tests with power OFF and unplugged!
In order to verify if ZD1 is bad or not, you need to test it out of circuit. In circuit may not give accurate readings because other components or board design may give false readings.
edit: If ZD1 is bad, it may have been the reason that caused the IC to go bad.Comment
I had checked one in the past that showed 'good' with continuity, but bad under load, so if I am in doubt, I had been checking voltage coming in and out of the fuse when power is flowing. Good to know to about the 0.3 ohms rule.
I removed ZD1 and it tested the same as when it was in the board, about .22 both ways. It has a line or groove across it and then it has the letters BC. Is that a part number?
I believe BC is the 'smt package marking'. It corresponds to a 5.6V 0.3W zener diode.
PlainBillFor a number of reasons, both health and personal, I will no longer be active on this board. Any PMs asking for assistance will be ignored.
Never be afraid to try something new. Remember, amateurs built the ark. Professionals built the Titanic.Comment
I don't know how to read that code. Someone else will have to help out.--- begin sig file ---
I looked up the 5.6V 0.3W zener diode at digikey and it looks like the right part.
http://search.digikey.com/scripts/Dk...client_id=5042
I will get one ordered and let you know. Thanks again for the help and education. I am getting the hang of the chip quick and soldering these smaller devices.Comment
Thanks for the heads up. I have a spare, usually buy a couple of extra when the parts are inexpensive. I also have a couple of the small resistors that are inline with these parts. Sometimes I do more damage than good with the soldering axe.Comment
Another LCD temporarily saved from the recycle bin. (I hope, still testing...)
The parts came in the mail, and when I got out the zener diode, I realized that it was almost 1/2 the size as the original... I was concerned, but thought I would try it since the specs should be the same. It was a little difficult but I managed to get it soldered in good. So a reminder to folks - always check the dimensions before ordering!! Fired it up and it works very well.
One other question if anyone has time. Right above and below ZD1 and ZD2 are two smd's with the numbers 103 on them. I thought they were resistors or diodes. When I test them on the board, they read like diodes. About .6 one way, and open circuit with probes reversed. I removed the one near ZD1 to check it as it was in line with ZD1 and the blown mosfet. When it was off the board it reads an open circuit either way the probes are connected. I thought I had damaged it while removing it from the board, so I took another one off an old board and it did the same thing. When I replaced it on the board it tested about .6 again. What is this, and is it possible to test it off the board??
Thanks again to everyone who helped with this one.Comment
It is 10 (with 3 zeros) or 10000ohm 10k ohm resistor. So it should read about that.
Glad you got the monitor working.--- begin sig file ---
This specification for the Samsung Galaxy Book 2 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Galaxy Book 2 boardview and Galaxy Book 2 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...09-07-2024, 05:50 AM
This specification for the Samsung Galaxy Book Ion NP950XCJ Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP950XCJ boardview and NP950XCJ schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...09-06-2024, 11:40 PM
This specification for the Samsung Galaxy Book Ion NP930XCJ Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP930XCJ boardview and NP930XCJ schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...09-06-2024, 11:40 PM
This specification for the Samsung Galaxy Book Ion NP950XCJ Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP950XCJ boardview and NP950XCJ schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...09-06-2024, 08:40 PM
This specification for the Samsung Galaxy Book Ion NP930XCJ-K01DE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP930XCJ-K01DE boardview and NP930XCJ-K01DE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...09-06-2024, 06:20 PM
- Loading...
