Samsung 912T click then off
  • sceva
    • 196
    The ccfl's come on for an instant and then go off. I can hear a click (when the the lights flash) somewhere on the inverter side of the board, but can't tell where.
    I found a bulging cap at C617 between the two inverter transformers and replaced it. 470u/25v But no change in symptoms.
    Also tried external ccfl's and no change.
    The on signal from the main board stays on after the lights flash.
    I have never seen the raised circuit board before. Should I remove it and take a look? I am hoping someone has an idea of what the click is!
    Thanks.
  • retiredcaps
    • Apr 2010
    • 9271
    Re: Samsung 912T click then off
    Pics?
    --- begin sig file ---
    --- end sig file ---
    • sceva
      • 196
      I hate this because these are the clearest, sharpest pictures yet! I did add them before, but the website upgrade must have zapped them!
      • retiredcaps
        • Apr 2010
        • 9271
        Check out this "samsung 920N, MJ19BS inverter/power board fault"
        https://www.badcaps.net/forum/showthread.php?t=8453
        • sceva
          • 196
          That is my board, except mine is Rev MP 3 instead of 5. I will take it off and have a look. Thank you.
          • Dgtech
            E. Technician
            • Apr 2009
            • 1462
            • Steeler
            From looking at the pins on the hybrid board, there is some discoloration from heat. Dont forget to check FH601 and FH602 (2 round red fuses)
            • sceva
              • 196
              I have the small board off, and the component in the bottom right is definitely damaged. It is burnt, and the other board underneath it shows burn also. It looks like the numbers on it read:
              The first letter which might be the manufacturer's symbol is a forward slanting "F".
              PE7A0 (I am fairly confident this is correct)
              FDS (there could be more letters but I don't think so)
              4935 (this could also be 14935 but can't tell for sure)
              Any ideas where to get a replacement part for this?
              The link here: https://www.badcaps.net/forum/showthread.php?t=8453 looks like my board but the part number he shows is different.
              Thanks.
              • Dgtech
                E. Technician
                • Apr 2009
                • 1462
                • Steeler
                Here is the data sheet. The discription of that part is Dual 30V P-Channel PowerTrench MOSFET. There is a guy selling it on ebay for $11.
                • retiredcaps
                  • Apr 2010
                  • 9271
                  $1.25 at Digikey
                  http://search.digikey.com/scripts/Dk...=FDS4935ACT-ND
                  You might want to test the MOSFET (both of them) to see if they are shorted or not.
                  • sceva
                    • 196
                    Digikey and mouser don't have any in stock. The one on ebay has a different set of letters across the top: P42DN - mine says PE7A0, but the rest of the numbers are the same. Will it work? (it is 10.99 for 5 pieces).
                    • Dgtech
                      E. Technician
                      • Apr 2009
                      • 1462
                      • Steeler
                      The other numbers are often a lot number or date code. The important numbers match. I found another one at this site:
                      http://www.alliedelec.com/search/sea...ry&Ntt=fds4935
                      Go with the FDS4935A on that page.
                      • retiredcaps
                        • Apr 2010
                        • 9271
                        TI found another one at this site:
                        If the Allied doesn't work, some sellers on ebay, when contacted, will sell you modified/customized versions of their listings.
                        For example, I only needed 1 IC and the guy was selling 5. So I wrote him and offered him a price for 1 and he accepted by making a customized listing for me.
                        • sceva
                          • 196
                          Thanks so much for the help locating some parts. I don't know enough about the parts to know, for example, if I look up fds 4935 on digikey, there are about 4 parts and I can't tell which is the correct one...
                          I called digikey about the one mentioned above, and they said they did not know if/when they would have any in, but suggested http://search.digikey.com/scripts/Dk...=785-1058-1-ND as a replacement. Could someone check and see if this might work? The original part at digikey is http://search.digikey.com/scripts/Dk...=FDS4935ACT-ND.
                          I also contacted the eBay seller to see if he would sell a smaller quantity.
                          Thanks so much.
                          • Dgtech
                            E. Technician
                            • Apr 2009
                            • 1462
                            • Steeler
                            I reviewed the data sheets and this will be a perfect match. The specifications and pinout match up. Do make sure that you observe the orientation of the part when you remove it.
                            • sceva
                              • 196
                              Awesome! I have it on order and will update when it arrives.
                              • sceva
                                • 196
                                I replaced the FDS4935 and still get the same result - backlights flash on/off, and a click occurs at the same time... aaarrrgg.
                                • retiredcaps
                                  • Apr 2010
                                  • 9271
                                  Did you test the other non burnt out mosfet to see if it is shorted? Maybe try testing ZD1 and ZD2 next to the burnt mosfet that you replaced to make sure they are working?
                                  • retiredcaps
                                    • Apr 2010
                                    • 9271
                                    Have you tested T602 and T603 for open windings using an ohms test or shorted turns using a ring tester?
                                    • jetadm123
                                      • 2169
                                      Hello! Even with substitution of the fds4935a, there's always the chance that there still could some incompatibilty between the old and new chip. Ideally, you should have replaced both the burned out chip and the one above it. I've included a pdf file of the inverter controller, OZ960. If you look at the application circuit you can test to make sure it's getting the proper voltage at pin 6. Also note that the U1 and U2 config is a little different than yours, since each chip has a N and P-channel mosfet in it.
                                      • sceva
                                        • 196
                                        The mosfet near the one I replaced seemed ok when i tested it, but I didn't remove it from the board... I will test it again when I get the board back off (seems like a foolish way to mount a board onto another board!) and test ZD1 & 2 also.
                                        I have tested T602 & 3 and they showed ok with the ring tester.
                                        The chip above the one I replaced has a different part number than the one I replaced. When I first looked at the board I thought they would have been the same, but after looking thru the magnifying glass I saw they were different. It is possible one or the other were replaced before?
                                        I have no idea how to test the small board for proper voltage, since I have to desolder it from the main board to see the components. I guess if I had a power supply I could power it up that way, but without being connected to the inverter transformers I think it would shut down anyway?
                                        No one has commented on the clicking noise. Any idea which component would click?
                                          09-07-2024, 05:50 AM
                                          09-06-2024, 11:40 PM
                                          09-06-2024, 08:40 PM
                                          09-06-2024, 06:20 PM
