ViewSonic VA1703wb - Hot Area - Can I Replace FSDM0565R with an FSQ0456R
  • leotron
    • Apr 2019
    • 29
    • Offworld
    As the title says the FPS 0565R blow up and I found another similar in a 22" lcd monitor. Comparing the datasheets looks like the later one can manage more voltage or at least they acomplish the same goal in the circuit. One technician said to me that I can find the same replacement but if I solder it it's gonna blow because there's collateral damage (like a chain reaction). I tested the diodes with 3 legs on the bottom and they are OK. Only the caps are inflated (lol) but that's an easy job. What do you think? (English isn't my first language as you can see)
    IMGUR Album with more detail: https://imgur.com/a/W8h5XOW
    Thanks for your time and patience, great forums.
    Regards.
  • leotron
    • Apr 2019
    • 29
    • Offworld
    Re: ViewSonic VA1703wb - Hot Area - Can I Replace FSDM0565R with an FSQ0456R
    Here are the datasheet's values for comparison, three images from the original component and the other three for the replacement.
      • Jul 2011
      • 6033
      I sent you PM message
      • leotron
        • Apr 2019
        • 29
        • Offworld
        Thank you sam, you are a godsend, what I understood from the PM it's I should check the areas in the red circle. Acording to my non-expertise the green ones are good and the principal transformer in orange it's another to check it out. I don't know what to do with the grey ones it's just a small transformer with an bridge rectifier.
        Thanks a lot and regards.
          • Jul 2011
          • 6033
          Like I said earlier in the PM that I sent you need a ring tester to test the switching transformer to see if it is shorted or it could be that the switching power supply regulator just failed because of a power surge but like said earlier in the PM I sent would recommend that you use a 100 watt incandescent light bulb ( in place of the fuse ) after you replace the switching power supply regulator and it should be very bright for a moment then dim down to almost nothing if you turn on the monitor and it works correctly that would be great if it keeps restarting then use a 200 watt incandescent light and see if it stops restarting if so then try running with out the incandescent light bulb and see if works correctly
          One note about using the ring tester on this type of switching transformer if it is the auxiliary power winding or a winding that has very few winding turns the ring tester might give you a false result and show it as a short and it might not be
          • leotron
            • Apr 2019
            • 29
            • Offworld
            Thank you so much sam sam, you should post the PM because it's very interesting.
            Now I'm at the lowest and I can't get a incandescent light bulb, I have an resistance from an electric pot or a transformer 220v ~ 9v AC @ 2A with a 12v car light lamp. Can I use those? Anyways I will get a 150w incandesent tube for the reflector for my yards.
            Regards.
            • leotron
              • Apr 2019
              • 29
              • Offworld
              hello sam, i tested the monitor with a 75w lightbulb and I got just a pulse, lets say of 50~100v AC for a sec, i'm using 220v ac in my country so I know from experience a lamp connected in series, it was a very quick flash but not too bright, the monitor didn't start up.
              kind regards
                ALIENWARE Area-51 R4 i7-7800X Specification for Upgrade or Repair
                This specification for the ALIENWARE Area-51 R4 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Area-51 R4 boardview and Area-51 R4 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for ALIENWARE...
                09-12-2024, 03:28 PM
                ALIENWARE Area-51 i7-5820K Specification for Upgrade or Repair
                This specification for the ALIENWARE Area-51 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Area-51 boardview and Area-51 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for ALIENWARE Area-51...
                ALIENWARE Area-51 R2 i7-6900K Specification for Upgrade or Repair
                This specification for the ALIENWARE Area-51 R2 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Area-51 R2 boardview and Area-51 R2 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for ALIENWARE...
                Alienware Area 51m R2 Notebook Specification for Upgrade or Repair
                This specification for the Alienware Area 51m R2 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Area 51m R2 boardview and Area 51m R2 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for...
                09-07-2024, 02:00 AM
