Samsung Syncmaster 940BX problem - Need help please
  • muzzo
    • May 2010
    Hi all, great forum and thanks for the chance to join. I started a new thread for this problem as I got no answers tagging on the end of a previous thread - so fingers crossed :-) - I have read with interest the progress of other members in fixing the Samsung 940BX monitor. Before diving into mine and following guidelines already posted I thought I would run my fault past the list members first, in case there is something in particular for me to check that is not already covered.
    My monitor works for two seconds after switch on then goes to a blank screen, with the blue light still on. It seems to be very similar to the problem other members have had. In the two seconds or so that it is on the screen it looks fine and the displayed data is as it is on another screen. Should I just start replacing capacitors as described? Best ones to start with?
    Thanks again!
    73,
    Graham.
  • PlainBill
    • Feb 2009
    • 7034
    Re: Samsung Syncmaster 940BX problem - Need help please
    Thanks again!
    73,
    Graham.
    How do the capacitors look? It's worth replacing all the caps if some of them are bulging. On the other hand, if the monitor has nothing but United Chemicon caps, and they all look perfect, changing them is not the best way to start.
    PlainBill
    • CptChronic
      Samsung LU32J590UQUXEN Monitor display problem
      by CptChronic
      I have an intermittent display problem with my monitor, when I plug in the HDMI cable to my (or any) laptop, you see the connection screen shrink on the laptop as it usually would before displaying on the monitor but 95% of the time the monitor display stays black.
      Before it cut out all together, tapping the monitor control button a fair few times would make the screen display, and everything work fine.
      But now it never does it. Not sure what's going on, hoping someone can help. I'm capable of stripping the thing down and soldering in new parts if needed, or programming...
      04-24-2023, 04:33 PM
      09-07-2024, 05:50 AM
    • howardc64
      Samsung UN55JU650DF network/streaming problem
      by howardc64
      Fixed a 9 year old UN55JU650 by replacing backlight. Original backlight LED was still working after 27k! hours but terrible picture of course. Few LEDs were out, 5-6 lens fell off (bright white spots) and another few popped off with slightest force. Surviving LEDs were all slightly blue so picture has a blue tint.
      This TV runs older Tizen OS (updated to latest version, see pic) and have problems with network (wifi or ethernet) connection. The Tizen UI frequently switch to coax input source while changing content sources. . If no good signal (coax not connected, no prior antenna/cable...
      07-09-2025, 12:44 PM
    • alro7779
      Samsung UN55MU6103F video problem; has colored stripes on the display
      by alro7779
      Hello, everyone!
      A co-worker gave me a 55-inch Samsung TV model UN55MU6103F so I can try to fix the following problem... As soon as I plug it in to the wall, the TV turns on, and the display shows a few stripes all over the screen. I took off the back cover and disconnected both ribbon cables that go to the display (one at a time) so by doing that I can narrow down the bad section of the problem, but in both cases the display turns black. I know there are some voltages that I have to check (VGH, VGL, etc.) but don't know what reading each has to show. If anyone could guide me on this,...
      09-27-2025, 11:29 PM
    • soopacrucial
      by soopacrucial
      Hi folks,
      10-29-2024, 02:40 PM
