Samsung 223bw
  • Buddierdl
    • Nov 2009
    • 9
    Samsung 223bw
    Hey,
    I'm a homeschooled college student starting an electronics repair business in my basement. I've got a Samsung 223bw monitor as my first outside job (I've repaired two of my own monitors). I opened it up and noticed several bloated caps. They are Samsung XC series caps, 105 degrees, 25v, and 820uF and 330 uF. I am getting replacements for these on mouser. Will general purpose capacitors work okay, or do I need low impedance or low esr? Should I recap the whole board or just the bloated ones? Your help is greatly appreciated!
  • PlainBill
    • Feb 2009
    • 7034
    Re: Samsung 223bw
    Originally posted by Buddierdl
    Hey,
    A student, huh? The information is here on this site. By rights I should make you look it up for yourself. DO take the time to review https://www.badcaps.net/forum/forumdisplay.php?f=24 before you start working on other's equipment. Your reputation is at stake.
    Do NOT use general purpose caps. They will work for a while, then fail. This will result in former customers complaining about the poor work you do.
    Use high temperature (105°C) low ESR caps. I personally prefer Panasonic FM and FC series. If bloated caps are found, replace all caps of the same brand, with the exception of the large 450 volt, 100 uF cap. I also suggest you investigate Digikey. Their First Class Mail shipping option will save you time and money on small orders. In general it is possible to recap an entire monitor for less than $10.00 in parts.
    PlainBill
    • Buddierdl
      • Nov 2009
      • 9
      Re: Samsung 223bw
      Thanks for the reply. I'll definitely check out Digi-key. Low esr capacitors apply to monitor inverter boards as well as to MOBOs, right? Do they also need to be low impedance?
      • PlainBill
        • Feb 2009
        • 7034
        Re: Samsung 223bw
        I use Panasonic FM or FC series in all applications. The few dimes saved on a lesser cap aren't worth the hassle of the additional stock. I'm trying to get one monitor working well, not building 100,000 at the lowest possible cost while hoping most will survive the warranty period.
        It's always a good idea to compare the specs (ESR, impedance and dimensions) of any replacement cap with the original.
        PlainBill
        • Buddierdl
          • Nov 2009
          • 9
          Re: Samsung 223bw
          I can't find anything on the Samsung XC series capacitors. They sold their capacitor business in 2002.
          • Buddierdl
            • Nov 2009
            • 9
            Re: Samsung 223bw
            Also, the FM and FC series Panasonic capacitors are too tall (25mm instead of 20). It seems that low esr caps are taller.
            • PlainBill
              • Feb 2009
              • 7034
              Re: Samsung 223bw
              Not necessarily. Many of the popular sizes of caps are available in two height / diameter combinations. It isn't necessary to match the original dimensions, it IS necessary to choose a capacitor that will fit in the available space.
              Again, READ THE FAQ!! https://www.badcaps.net/forum/showthread.php?t=2280
              https://www.badcaps.net/forum/showthread.php?t=613
              If you REALLY aren't up to locating the proper caps, post the vital information (capacitance, voltage, manufacturer, series, height, and diameter) for each capacitor. Eventually someone will respond with a list of replacements. Oh, it's a good idea to identify what country you are in.
              PlainBill
              • Buddierdl
                • Nov 2009
                • 9
                Re: Samsung 223bw
                I've checked all the capacitors on the good capacitors list and I only found a few that are the rights size that are carried at digi-key or mouser. The HV Nichicons are the only ones of the right size, but there is no stock of one value that I need. I don't think that I should mix series... Any advice? I can't wait 12 weeks leadtime and I can't order larger caps. The current ones barely fit.
                • PlainBill
                  • Feb 2009
                  • 7034
                  Re: Samsung 223bw
                  Mixing series (or manufacturers) is fine. As often as not when I open a monitor I will find two or three different manufacturers / series of caps in them. The buy from whoever will give them the best price - which is the source of a lot of the troubles.
                  PlainBill
                  • MixMasta
                    • Feb 2006
                    • 142
                    Re: Samsung 223bw
                    Is there really 25v on those caps or less, like 12v? I am pretty sure the last Samsung LCD power supply I recapped has 25v caps and was really 12v, so I replaced them with 16v Panasonic FM. Also, is anything stopping you from leaving the leads long and folding the capacitor over onto the circuit board?
                    • Buddierdl
                      • Nov 2009
                      • 9
                      Re: Samsung 223bw
                      Is it okay to use a higher voltage? Do you think it would be better to use higher voltage with the same lead spacing, or right voltage with smaller lead spacing and bend the leads?
                      • PlainBill
                        • Feb 2009
                        • 7034
                        Re: Samsung 223bw
                        I'd say six of one, half a dozen of the other. The only precaution would be to take care not to disturb the leads and break the seal where they enter the rubber bung.
                        It depends on the power supply. The vast majority have 5 Volt and 12 (or 13) Volt outputs. However, some have higher voltage outputs. The highest I have seen was 18 Volts; someone else reported a 24 Volt output.
                        Bending the leads has good and bad effects. It results in longer leads, thus increased (slightly) impedance. It also can get the capacitor away from the heat sinks, always desirable.
                        PlainBill
                        • Buddierdl
                          • Nov 2009
                          • 9
                          Re: Samsung 223bw
                          Is the Nichion HD series 330 uF 35V 105 degree capacitor a suitable replacement for the Samsung XC series 330 uF 25V 105 degree capacitor?
                          • PlainBill
                            • Feb 2009
                            • 7034
                            Re: Samsung 223bw
                            Without specs of the Samsung XC series it's hard to be sure, but it certainly should be. One question - why are you going with a higher voltage replacement?
                            PlainBill
                            • Buddierdl
                              • Nov 2009
                              • 9
                              Re: Samsung 223bw
                              I'm going with higher voltage because its the right size and in stock. I just found the Nichicon PJ, PS, and TS series are for switching power supplies, but these are not listed on the good list. Are these good to use, since I'm repairing the power supply in the monitor?
                                09-07-2024, 05:50 AM
                                09-06-2024, 11:40 PM
                                09-06-2024, 08:40 PM
                                Samsung Galaxy Book Ion NP930XCJ-K01DE Notebook Specification for Upgrade or Repair
                                This specification for the Samsung Galaxy Book Ion NP930XCJ-K01DE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP930XCJ-K01DE boardview and NP930XCJ-K01DE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                09-06-2024, 06:20 PM
