BENQ 19inch FP937+ black display
  • mildseven
    • Aug 2009
    • 6
    my 3,4 year old BenQ FP937+ 19inch display automatically turns black 2 seconds after turn on the switch. using my flash light, it's very dim but I can see my windows.
    Funny thing is sometimes, it's working perfectly (whole day)
    But most of time, once I turn on the switch, I see BENQ logo, and for 1 sec, I see my background of Windows, then it turns black.
    After spent some time on searching, and I have decided to replace below items:
    4 x Elite 470uF 35V cap with Rubycon
    2 x Elite 1000uF 16V cap with Rubycon
    2 x Elite 1000uF 10V cap with Rubycon
    4 x 2SC5707
    2 x FU9024N
    1 x 3A fuse
    before the replacement, I visually checked on caps but they seemed ok.
    and tested transistor with my DMM, but didn't see they were shorted, but I gave a try.
    however it ddin't fix the problem. what else do I need to check?
    Thank you in advance for your help/suggestion
  • Bobdee
    • Jun 2008
    • 461
    Re: BENQ 19inch FP937+ black display
    4 x 2SC5707
    2 x FU9024N
    1 x 3A fuse
    This could be one or more bad CCFLs
    But before going there you must resolder the 4 inverter transformers
    Also check all the solder joints on the board with with a good 6 to 10 times magnifying glass looking for bad solder joints and ring cracks
    Pay particular attention to anything on heatsinks
    Then try again and post back with findings
    • mildseven
      • Aug 2009
      • 6
      Bobdee, thank you for your feed back.
      I just resoldered 4 inverter transformers, and three heat sinks, but the same result
      also I just did go through all the solder joints, but could not find anything is bad.
      • Bobdee
        • Jun 2008
        • 461
        OK then just check 3a fuse and the 4 transistor that you replaced, because one or more may have blown again before you resolded the transformers, (sometimes and if not mostly the transformer ring cracks are the cause of fuse and a c5707 failing)
        If they are still ok then you have to check the CCFLs
        BTW I never meant you to resolder heatsinks themselves just components on them if they needed it
        • Bobdee
          • Jun 2008
          • 461
          Mildseven
          you dont have to remove transistors to check them, check one pairs readings against the other pair (very rare both pairs go down)
          • mildseven
            • Aug 2009
            • 6
            I checked c5707, and fuse on board and seems fine with my Fluke DMM. (hopefully I test correctly..)
            could it be 2 CCFLs are bad? When I turn the monitor on, I can see BENQ logos. if CCFL is bad, do you usually see the BENQ logo?
            • Bobdee
              • Jun 2008
              • 461
              If you have one pair reading much lower than other pair then there is usualy a bad transistor in that lower reading pair, when that pair is removed you find that one is shorted
              However more than probably now its bad CCFLs
              As for seeing Benq logo yes you will still see it, you seem to have a failing tube or tubes that come on and the protection circuit senses that one or more is on its way out and it shuts down that is why it works sometimes, the tube is failing and close to dead if not dead now
              There are a couple of ways to check CCFLs I personaly use another panel that has good CCFLs in it, some take panel apart and visibly inspect tubes
              others have CCFL comp mod kit, and they use the inverter to test the monitor tubes and you can use the tubes to test the monitor inverter
              Hopefully other members can suggest other methods to you
              • mildseven
                • Aug 2009
                • 6
                I think it's the bottom CCFL that's causing the problem. I was switching 4 pin to CCFL, and I removed top two pin to CCFL, then "BENQ" logo was dim.
                but I have another problem, I have been resolding on the board, and now when I turn on the monitor switch, I dont have video signal. Green light changes to Amber after 1 sec.. where could be the problem? any suggestion?
                • Bobdee
                  • Jun 2008
                  • 461
                  Thats a nasty bit of bad luck
                  Check the whole solder side for any solder that might have spat about and created a short ect
                  Also check your solder work you may have bridged two tracks or something (with good magnifying glass)
                  • mildseven
                    • Aug 2009
                    • 6
                    Thanks, I'll get 10 times magnifying glass and take a look
                    • mildseven
                      • Aug 2009
                      • 6
                      Update:
                      It's working now!!
                      No signal sign was causing by faulty D-Sub cable.. It was working before, but somehow it's not sending any signal. I tested on other monitor, and it was giving the same error.
                      So I swaped with DVI cable, and now it's working. I dont know what was the root cause at the beginning. I still think my CCFL is getting old. I'll see if this happens again near future.
                      Thanks for all your help
                        HP Elite Elite 7100 Microtower PC Elite 7100 i3-530 Specification for Upgrade or Repair
                        This specification for the HP Elite Elite 7100 Microtower PC can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Elite Elite 7100 Microtower PC boardview and Elite Elite 7100 Microtower PC schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any...
                        09-12-2024, 03:44 PM
                        HP Elite Elite Dragonfly Hybrid (2-in-1) Specification for Upgrade or Repair
                        This specification for the HP Elite Elite Dragonfly Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Elite Dragonfly boardview and Elite Dragonfly schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                        09-06-2024, 11:51 AM
                        HP Elite x2 Tablet Elite x2 1013 G3 Hybrid (2-in-1) 1013 Specification for Upgrade or Repair
                        This specification for the HP Elite x2 Tablet Elite x2 1013 G3 Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Tablet Elite x2 1013 G3 boardview and Tablet Elite x2 1013 G3 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any...
                        09-06-2024, 11:32 AM
                        HP Elite x2 1012 G2 + Elite Presenter Mouse + Essential Top Load Case Hybrid (2-in-1) 1012 Specification for Upgrade or Repair
                        This specification for the HP Elite x2 1012 G2 + Elite Presenter Mouse + Essential Top Load Case Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 1012 G2 + Elite Presenter Mouse + Essential Top Load Case boardview and 1012 G2 + Elite Presenter Mouse + Essential Top Load Case schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help...
                        09-06-2024, 08:20 AM
                        HP Elite x2 Elite x2 1012 G2 Tablet (ENERGY STAR) Hybrid (2-in-1) 1012 Specification for Upgrade or Repair
                        This specification for the HP Elite x2 Elite x2 1012 G2 Tablet (ENERGY STAR) Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Elite x2 1012 G2 Tablet (ENERGY STAR) boardview and Elite x2 1012 G2 Tablet (ENERGY STAR) schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                        09-06-2024, 07:10 AM
