Blink EVSE touchscreen intermittent problem.
  • GLInick
    • Feb 2019
    • 31
    This is a blink Level 2 EVSE and it has an issue with the touch-screen. It was installed outdoors and facing the sun for extended periods. I cleaned the touchscreen assembly including the edges.
    There are no display issues, but the touchscreen is very finicky, and barely works intermittently. On power-up the EVSE goes through a touchscreen calibration procedure: touch 5 X's (corners + center), followed by 5 O's in the same screen positions. It doesn't accept touches after the 3rd-7th calibration point. The calibration period has a countdown, and then restarts. One time I touched some parts of the screen unintentionally, and it put me straight into the main menu but then it stopped accepting any more touch input.
    I don't know the exact touchscreen technology in use, but I highly doubt it's a multi-touch.
    Starting from the contact layer the touchscreen is made up of:
    1- a clear plastic layer with 4 contacts on the bottom right, and tracings all around. This layer is glued with double-sided tape on the edges to ...
    2- a glass assembly with 4 contact points that connect via a 4-wire flat cable to a main board header labelled "touch screen". The glass assembly seen from its side looks to be two layers of glass sandwiched together. It is clear that the center of the screen has an artifact - a square in proportion to the screen dimensions with rounded corners. This doesn't look good, but it is possible to tap on one calibration point in that area, although, I can't tell if the signals generated represent taps in that area.
    3- the display panel
    I lifted the top clear plastic (what your fingers touch) and cleaned it. I used alcohol, and goof-off on the edges to remove most of the gummy bits of the double-sided tape that held it to the glass. I didn't put new tape when I put the film back, and perhaps this is why it is not working reliably. If I am not mistaken, it should be glued so that it stands off the glass underneath, correct?
    I believe the problem is with the mating of the top film to the glass panel. There are "traces" on both the film and the panel, but I am not clear on how those interact to make the touchscreen work. The traces are gray in color, and matte, or slightly rough in texture. I used my multimeter to check continuity between the four contact points and the ends of the traces coming from them, and got no beeps.
    Any pointers would be appreciated.
  • R_J
    • 9594
    Re: Blink EVSE touchscreen intermittent problem.
    It looks similar to this http://www.urt.com.tw/products_show.php?show=215 But might be custom
    It is either resistive or capacitive, I would guess capacitive
      • Jul 2011
      • 6069
      Do you get any type of resistance reading from the bonded connector to the touchscreen or to the controller connector or the ribbon cable
      The only problem is do you have any information about the touchscreen for how to check it so it could be either one
      If you do it might not be the touchpad but might be controller
      • GLInick
        • Feb 2019
        • 31
        I was more inclined to think it is resistive, but I can't find a way to identify the existing one. The user interface running on the display seems to rely on a single-touch at a time, so my guess is it is resistive.
        I've googled a lot, and found various suppliers for touchscreen overlays for under $30, which will solve the problem I am having, but I need to know what kind mine is. I found the whole assembly on Aliexpress but the description doesn't state if the touchscreen digitizer is cap. or res.
        Some part numbers -- see pics.
        LCD display and touchpad assembly:
        UMSH-0521MD-1T
        U.R.T. No. 110324-0077
        U.R.T 7168173000
        touchpad:
        bottom of glass: URA-070007MA
        flat cable: URT 524070007001
        • R_J
          • 9594
          Did you need to put presure on the screen to move the curser or did you just need to have your finger on the glass, can you move the curser using an ordinary non conductive device (pen, wood stick)
          usually the resistive screen is soft and will deform slightly when pressed, capacitive can be a hard glass
          This might help determine the type https://www.embeddedarm.com/blog/rea...touch-screens/
          or here https://forum.digikey.com/t/resistiv...ifference/1063
          • GLInick
            • Feb 2019
            • 31
            I saw those pages but various things threw me off.
            If the touchpad surface is covered with a plastic cover (whose traces around the underside edge get powered from 2 of the 4 lines), could it still be capacitive? I didn't see any explicit mention of this, but with capacitive it seems to me that all the lines would be going to the glass layer.
            The other two lines connect to the traces all around the upper surface of the glass. That plastic cover provides an ever so slight airgap, so there is a slight "give" when pressed. I had to remove the plastic film to clean under there due to dirt, etc.
            When the touchpad works, it responds to a press from a finger or a plastic stylus.
            Safe to conclude I need a replacement resistive touch screen?
            The existing one is 164mm x 103mm. The image size on the LCD underneath is 153x92mm (7" diagonal)
            I am very grateful for all the help.
