Hi folks. Anyone got some pointers for this one? I temporarily replaced four of eight 100uf 35 volt caps. (the four remaining passed ESR with flying colours, but when I get get my parts order in all eight wil be replaced). I did this as a check to see if the problem persists. It apparantly does. The SMPS checks out ok. The monitor will still only flash once in a blue moon. All fuses ok. Nothing is noticably running hot, or burnt. There is a turn on signal from the "control" board. Good, stable 24 volts to the inverter. (normal for this monitor) Any ieas?
Mag model 2600
Tags: None
Re: Mag model 2600
Originally posted by xtraelectronicsAnybody? help pls
What have you done between the first and second posts? Are the fuses good? Did you compare the voltages on the OZ960GK with the datasheet? Did you try substituting CCFLs? Did you search for a schematic? (OK, forget the schematic. I'd take a miracle to find one.)
PlainBillFor a number of reasons, both health and personal, I will no longer be active on this board. Any PMs asking for assistance will be ignored.
Never be afraid to try something new. Remember, amateurs built the ark. Professionals built the Titanic.Comment
Re: Mag model 2600
Didn't mean to sound impatient. Yes the fuses are all fine, as are the MOSFET drivers. I still must look up the IC datasheet. In the meantime I removed the mainboard and found many bad surface mount caps! I don't know if this will affect the inverter's operation, but looks like I will have to repair the mainboard, so I will need to order more caps. At that point I set it aside to persue other repairs. (A Sony receiver, and a JVC amplifier). I will devise a test scheme for the inverter board, and check it out with the datasheet next. Thanks, I'll keep you posted.Comment
Re: Mag model 2600
the caps I put on the board are ones I had here, branded EKM, all measured less than one on the esr meter. the reason for doing tis was to confirm if this was the only problem. I will be replacing all 8 with high quality low esr parts.Comment
Re: Mag model 2600
Originally posted by xtraelectronicsDidn't mean to sound impatient. Yes the fuses are all fine, as are the MOSFET drivers. I still must look up the IC datasheet. In the meantime I removed the mainboard and found many bad surface mount caps! I don't know if this will affect the inverter's operation, but looks like I will have to repair the mainboard, so I will need to order more caps. At that point I set it aside to persue other repairs. (A Sony receiver, and a JVC amplifier). I will devise a test scheme for the inverter board, and check it out with the datasheet next. Thanks, I'll keep you posted.
Re: Mag model 2600
Did you take out the MOSFETs (packaged like an IC)? Outboard tests are needed. OZ960GN rarely fails. If ok, go back to the supply board.Comment
Re: Mag model 2600
thanks. will do that. (when I get time) got a road grader in here today for speakers.Comment
This specification for the HP ZBook 14 G2 Base Model Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 14 G2 Base Model boardview and 14 G2 Base Model schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or...09-06-2024, 05:27 AM
This specification for the HP EliteBook 840 G2 Base Model Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 840 G2 Base Model boardview and 840 G2 Base Model schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...09-06-2024, 05:27 AM
This specification for the HP ProBook 640 G1 Base Model Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 640 G1 Base Model boardview and 640 G1 Base Model schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...09-06-2024, 05:27 AM
This specification for the HP ZBook 15u G2 Base Model Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 15u G2 Base Model boardview and 15u G2 Base Model schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...09-06-2024, 05:27 AM
by edugimenoHi!!
Yesterday I was installing a new Wifi thermostat for my domestic gas water heater model Vaillant 242/2-3, and accidentlly one wire from mains touched one wire from the thermostat output contacts. This shut off the heater so I finished installing the thermostat and then went out to check the heater
I found one fuse blown (T2 250V). Replaced it with another equivalent fuse and it blew right away. I measured L-N in mains input and I sometimes got 4K but sometimes, not sure why, I got 100 Ohm...
At a certain point, moving stuff around, I put all wires back in place and... - Loading...
