Samsung SyncMaster 223BW
    Have a little problem with a 223BW samsung ...
    Have changed all 5 820uF capacitors,the 330uF,and the big one 100uF/400V (with 150uF/400V)
    The problem is the monitor turns off after 2,4,5,10 minutes (no rule when) ...
    The power led is on,but no picture,after pressing the power button off/on the monitor works (for 2,3,6,9 minutes) ...
    Example : the autoadjust pressed,and after 5-10 sec screen goes off
    the autoadjust pressed, and after 30 sec the screen goes off
    the power button remains on (blue)
    thx
    Re: Samsung SyncMaster 223BW
    Check with a lamp if the image is still present.
    Low the brightness at minimum in order to see if it stays on for more time.
      Ok,with brightness on 0 the monitor is 20++ minutes up ....
      What to change ??
        Probably the inverter transformer.
          Will try to change,thx
            As i can see you are using windows 7 and maybe this wont help you but i will say.
            I had similiar problem,first i changed inverter transformer because it was turning monitor off after 5 sec, after that monitor was working same as yours 2,4,5,10 minutes.
            I have found out that was problem with windows 10 and graphic drivers because i had one monitor and just switched on another.
