Samsung 710v — Dump/Flash NT68F63L?
  • piernov
    • Jan 2016
    • 4439
    • France
    Got a Samsung SyncMaster 710v with the famous bad Novatek NT68F63L. The 50ohm resistor trick worked for a while but the issue is now back. I want to replace the chip but I don't know how to dump the firmware from the old one and flash it on the new one.
    I heard of a VGA to LPT cable and using a software called EasyWriter. Does anyone have any info on this?
  • Alectronic
    • Nov 2013
    • Netherlands
    Re: Samsung 710v — Dump/Flash NT68F63L?
    That is super easy with a HDMi to VGA cable and the RT809H programmer! VGA simply plugged in on the Samsung Syncmaster and the HDMi plug into the RT809H. It autorecognizes the bios and reads and also programs it within seconds.
    I however disassembled this bad monitor for the spare parts being the cfl tubes and both boards because VGA input never worked and my Bios must have been corrupt and the backup I made also wrong somehow. Couldn't find a good bin file either.
    • maxfolder
      • Nov 2022
      • 11
      • Poland
      Alectronic is right. The HDMi should be connected to the RT809H and the VGA should be connected to the Samsung Syncmaster. This should work
      • spmetroil
        Request: SPI Flash BIOS Dump (Winbond 25Q128) for Dahua NVR4216-4KS2
        by spmetroil
        I am trying to repair a Dahua NVR4216-4KS2 that is not booting.
        The main BIOS/firmware is stored in an SPI flash EEPROM (Winbond 25Q128, labeled as U130 on the PCB).
        I have a CH341A programmer and I already attempted the following steps:
        1. Identified the correct chip (W25Q128, 3.3V SPI flash).
        2. Tried to read the contents with CH341A Programmer software. The dump seems corrupted and I often get the error: “Chip with the contents are in disagreement.”
        3. Compared several chip type selections (24Cxx and 25Qxx families) to confirm it is indeed a 25 series SPI
        08-19-2025, 09:23 AM
        09-07-2024, 05:50 AM
      • Citymin
        by Citymin
        S/N : 5RNK9FFT70...
        08-05-2025, 05:12 AM
      • Deeloc
        How to flash SSD 1tb WALRAM controller SM2259XT2G flash samsung NAND V6
        by Deeloc
        I have a 1tb WALRAM SSD (Photo)
        Controller SM2259XT2G (photo)
        Samsung memory (photo):
        Part Number K9DVGB8J1B DCK0
        Name V-NAND V6
        Type TLC
        The SSD itself is detected as 1gb, but is not initialized.
        There is a Sata to USB adapter
        A lot of SMI MPTool, did not flash it. compare flash fail (17)
        K9DVGB8J1B is not listed anywhere
        What to flash?​...
        06-05-2024, 08:32 AM
        09-06-2024, 11:40 PM
