AOC 1 second display
  • winboxes
    • Oct 2008
    I have a 27 inch AOC Lcd Monitor/Tv. When powered on it displays the screen for a 1 second or less and then goes blank. The led power light remains green. I took a torch to the screen and could not see anything.
    Open it up and all the caps on the inverter/powerboard looked good. There was no buldging but there was one that was suspicous. Changed all four of them. Checked the fuse and it's good.
    Checked the backlights. 7 of them and they all light up during the 1 second or less. None that is blown.
    Powered on and still no go.
    Would really appreciate it if someone could provide some suggestions on what I should look for.
    -Mark
  • arneson
    • Sep 2005
    • 1267
    Re: AOC 1 second display
    I'd be looking for other fuses, very very small surface mount ones.
    Should be marked on board with an F number and most of these seem to be green.
    Jim
    • winboxes
      • Oct 2008
      Thanks Jim, I've looked at the board again and there only appears to be one fuse the 5a bus fuse. No others.
      When powered on, i can hear a slight buzz from the inverter board even after the lcd goes blank.
      • arneson
        • Sep 2005
        • 1267
        Speaking of sounds, leave the inverter unplugged and try for audio.
        The last set I looked at like this it was in fact the audio amp section that had shorted.
        It displayed the same symptom.
        Jim
