Hanns G HH251 2 seconds to black.
  • eljefefx
    • Aug 2015
    Hello all, this is my first post so I will attempt to be as thorough in my description as possible.
    Make:Hanns G
    Model: HH251
    Type Num: HH251HBUFN24
    MFG Date: APR 2009
    Gripe: This is a second hand monitor that I picked up for a very reasonable price. After a bit of research I realized that this is a common problem with this series of monitors. When connected via VGA or HDMI to two different Known Good computers, power LED comes on and stays on, while screen shows NO SIGNAL then runs to full black out mode. If hooked to the KG's before powering on the monitor, monitor will display extended background of both, so it appears that video input/processing is functioning 4.0. Cycling power nets the same result.
    I am currently still in the process of tearing the monitor town and isolating both the power board and the video board and will have non-potato quality pictures as soon as possible. A few other around the house chores need to be completed before I can dig back into this and start running power and continuity tests. Visual inspection of all components, at a casual glance, show no obvious signs such as leakage or burn out.
    Also, it is highly likely that my wife will require some kind of Feat of Strength and Loyalty within the next 3 hours, as it is the weekend. I look forward to any advice (that I haven't been able to find after going through several threads) or protips provided.
  • Adgery
    • May 2015
    • 6
    • Russia
    Re: Hanns G HH251 2 seconds to black.
    You need to upgrade the program to EPPROM.
    I experienced similar to Acer monitor.
    • Agent24
      I see dead caps
      • Oct 2007
      • 5038
      • New Zealand
      Was that EDID EEPROM or main program?
      -David VanHorn
      • Adgery
        • May 2015
        • 6
        • Russia
        Main program.
        • Rick_1234
          by Rick_1234
          Good evening, gentlemen.
          Things I tried
          06-22-2024, 04:44 PM
        • sew333
          Pc shutdown, monitor flickered with no signal after 10 seconds
          by sew333
          My pc:
          10850K stock 4800mhz stock Kraken X73 good temps
          2x16 GB DDR4 GSKILL 3000mhz XMP
          Seasonic Tx-850 Ultra Titanium
          Gigabyte Rtx 3090 Gaming OC
          Aorus Z490 Pro Gaming
          1 TB SSD
          4 weeks ago i launched Metro Exodus Enhanced and during cinematic advertisement part ( 30 fps ), pc just shutdown.
          Also monitor flickered with NO SIGNAL 10 seconds after shutdown. So only monitor and pc was affected.
          Next i pressed only power button, rebooted again and its fine again. Happened once and i cant reproduce.
          Power...
          02-22-2022, 10:27 AM
        • valscu
          EIZO SW3031W monitor blue color instead of black
          by valscu
          I have an Eizo SX3031W monitor and after a period i had problems with the tcon board. I did reflow, it went well for a while after but the problems appeared again. The second reflow attempt was a failure, the tcon board stopped working. In the meantime, I bought a perfectly functional Samsung 305T monitor from which I took the tcon board and installed it in the Eizo monitor. Since I turned on the monitor, the blue color appeared in the background instead of black. And also in Windows, appears blue instead of black. I tried various settings from the monitor and driver settings but...
          08-10-2022, 02:08 PM
        • turmix
          AOC U34G3XM, new monitor, black screen with backlight on, possible shortcircuit during dissassembly
          by turmix
          Hello, I'm working on a new deskmod pc project and have a problem with my monitor, an AOC U34G3XM, well, I may have bricked it.
          The monitor was dismanteled and the separate parts parts integrated in the desk. the screen panel alone is on the upper part, and main board/video board + power board on the back of the desk (not enough place on the cover to fit it)
          At first everything was working smoothly, then I decided to change the connexion between the video board and the screen for a longer one. Still working fine
          During another reassembly, I made a mistake, and...
          01-29-2024, 03:48 AM
          by momaka
          03-15-2023, 10:17 PM
