Solved: Samsung 204T LED blink, chirp, unresponsive controls
  • pkanar
    • May 2013
    • 19
    I am posting my repair notes in the hope they may save someone else the trouble. Based on searching the web, my issue seems rather uncommon.
    A 9-year old Samsung Syncmaster 204T stopped working around 2015-03-26. Increasing audible noise from its internal power supply was noticed in the weeks prior to failure. Then, one day, the bezel buttons would no longer respond, and neither the backlight nor the pixel grid would function. The green LED blinked every 0.54sec with a very brief (barely noticeable) off time. This is quite different from the blink pattern that means "no video signal". An audible chirp from the big transformer accompanied the off phase of the LED. It was immediately noticed that the chirp went away when the scaler card is unplugged from 13V DC supply.
    In the course of diagnostic efforts, the display did suddenly turn on normally (2 times out of over 100). In retrospect, I think that was random, and had nothing to do with the changes I made to the circuit. But it did lead my diagnostics on a wild goose chase to repair things that weren't broken.
    In the end, the first clue proved right: problem was traced to the scaler card (BN41-00620D, rev. MP1.3). The 13V supply and inverter driver board, after 9 years of almost always being powered on, was still working great. It was the 3.3V rail on the scaler card that was experiencing some sort of glitch, resulting in a periodic restart behaviour. The sudden change in the impedance of the load seen by the 13V supply caused the PWM-induced oscillation in the transformer 's secondary winding to phase-shift abruptly, which explains the chirp. (Although the PWM's oscillator is 66kHz, it does not drive the transformer at these high frequencies. The sawtooth wave on the 13V rail, at that particular load level, was found to be about 300Hz, with 17% duty.)
    I have managed to patch over the issue by adding more capacitance to C419, the capacitor that backs the scaler's 3.3V supply. It is one of the 6mm-tall SMD electrolytics, marked 100 16J. I simply soldered a no-name 1000uF 25V cap in parallel (mind the polarity if you do that). The display is working now, though I doubt that the underlying problem is cured. Some component has come out of spec after all these years, and it may not be the C419. If the display should fail once more, I will add a note here.
    This hasn't been the story I had hoped for. It would have been neat to spot one big bad capacitor, and conquer the beast in one fell swoop. Instead, after throwing all my brainstorming power at the problem, repeatedly, for 2.5 months, the result feels like a Pyrrhic victory. Life is not neat.
  • Th3_uN1Qu3
    Believe in
    • Jul 2010
    • 6031
    • Romania
    Re: Solved: Samsung 204T LED blink, chirp, unresponsive controls
    Life is never neat. I would recap the whole PSU. I have fixed one of those a few months back by replacing all secondary side caps, some of which were bloated. But capacitors do not have to be bloated to be bad, they can simply dry out.
    A working TV? How boring!
    • pkanar
      • May 2013
      • 19
      Yeah, I did recap the whole PSU, although the old Samxons were looking great and doing their job just fine.
      • retiredcaps
        • Apr 2010
        • 9271
        Thanks for sharing. Not enough people provide solutions.
        Yes, but that would have been boring.
        For me, spending the time to learn isn't wasted. 99% would have tossed the monitor into the recycle bin after 2.5 hours of troubleshooting.
        --- begin sig file ---
        --- end sig file ---
        • Agent24
          I see dead caps
          • Oct 2007
          • 5038
          • New Zealand
          Agreed, I learn something on every repair or repair attempt. That's worth something, to me too.
          -David VanHorn
          • cloo
            Panasonic ZT60 plasma tv with strange behavior and 8 blink code
            by cloo
            I recently got my hands on a 60" Panasonic P60ZT60 plasma tv (european model) that has some strange issues along with an 8 blink code.
            It know this tv is getting old but it was once considered one of the best plasmas ever made, and i think it is still holds on to that even by todays standards.
            So, long story short. When i first got the tv it had a very bright washed out picture with very raised blacks in all picture modes and i couldn't find the cause in the picture setting menus.
            After doing a factory reset this problem was gone and the picture was back to...
            01-06-2025, 06:02 AM
          • EazyBone
            Un50cu7000 2 blink oddity *partially solved
            by EazyBone
            I write this to maybe help another with this TV.
            So I aquired this TV a 2023 model. It started the 2 blink reboot problem which indicates bad panel. It was still under warranty and the repair man came by.
            The Samsung repairman brought a brand new panel and switched my original boards to the new panel. The new panel then had the 2 blink error code. The repair guy said he has seen this and the MAIN board on this model will cause the 2 blink. He then replaced the main/power board (they are both connected) and put it back onto my original panel. Voila it worked.
            03-18-2024, 10:24 PM
          • Vebririon
            panasonic TX-P50V10E 6 blink led problem
            by Vebririon
            I'm new here and trying to repair my Panasonic TX-P50V10E plasma TV, which is currently showing the 6 red blink error code.
            Just for context: I'm used to building PCs and installing modchips in old consoles, but this is my first time trying to fix a TV. I'm French, and while my English is okay, I'm using ChatGPT to help translate and clarify my messages as much as possible — so please forgive any odd phrasing.
            I'm also not very experienced with using a multimeter, but I'm very motivated and ready to follow instructions carefully and report...
            05-17-2025, 10:16 AM
          • pixelcap
            Pioneer Kuro Pro 111FD 8 red blink error
            by pixelcap
            Pioneer Kuro Pro 111FD 8 blink red LED.
            I have been trying to solve the power-down 8-blink red LED problem with my Pioneer.
            So far I have replaced the power supply board, and the digital assembly board, I have reconnected the ribbons to all boards, ensuring the connections are good. Even though the problem is the 8 red light error and not the more common 8 blue light error code, I had Kcrownie,
            based in North Carolina replace the chips that cause the 8 blue LED problem (the main board and audio board) the plasma is still powering...
            10-06-2024, 11:26 PM
          • nervx
            Panasonic TH-42PZ800 8-blink error mystery
            by nervx
            Years ago my tv gave a 7 blink code which turned into 8 during diagnosis. I had ordered a replacement ss board but somehow the tv started working again and i never used the board. Now a week ago my tv flickered and shut off at random and gave the 8 blink error code. The same issue it had all those years ago. The only difference this time is that over the last few months there has been some purple and green tinge that comes and goes in more solid colors such as white.
            Anyway i checked all the screws and replaced the ss board with a known good one and still got 8 blinks. I saw a...
            04-08-2022, 05:19 AM
