Acer H213H power issue
  • Charlie Zhou
    • Jan 2025
    • Switzerland
    Very strange problem: monitor works for some days perfectly, then some days it won't power on at all. ( Completely no power).
    I checked the cable, AC 240 input socket. All good. Capacitors look okay. I don't know what could cause this strange problem? thanks for suggestions or places to check...
  • GLISIT
    by GLISIT
    01-16-2025, 02:29 PM
  • justice171
    Acer Spin 1 SP111-33 Power-On Issue (Troubleshooting Assistance)
    by justice171
    I am seeking guidance on an Acer Spin 1 SP111-33 that does not turn on when pressing the power button.
    Below are the observations and troubleshooting steps I have taken so far: Observations and Tests:
    1. Verified that all critical voltages are present:
      • 3.3V and 5V are always present if DC is plugged.
      • 1.8V on the BIOS chip is present.
    2. Checked the power button functionality:
      • When pressed, the voltage drops to 0V, indicating the button is functional.
    3. Inspected the flex cable connecting the USB, audio, and power button to JUB1:
      • Confirmed connectivity is intact, ruling out issues
    11-26-2024, 12:39 AM
  • claws77
    Acer Sf314-41 power issue
    by claws77
    my laptop has a weird power-on issue.
    Once the laptop has been powered on, it can restart/ wake just fine on battery power or Adapter, ONLY If i have not closed the LCD.
    If i am running on battery and have closed the LCD (even momentarily). it will not power-on/ wake-up on battery power no matter the battery percentage.
    but once i open the LCD and connect it to the adapter (even momentarily) it will wake up gain and I wont experience any issues till i close the LCD.
    i do not know where to look for repair.
    thank you all for any advice.​
    04-30-2024, 04:36 PM
  • claws77
    lenovo flex 5 14itl05 power sequence issue
    by claws77
    hi guys, my motherboard will not start no matter what
    when connected to ac power, the battery does get charge, led indicator glows red when discharged and turns white as it is fully charged.
    but rest nothing happens no sign of life.
    this laptop has one preexisting usbc power issue - so i use DCIN jack for charging my laptop.
    with this issue my laptop was unable to power ON only sometimes i just had to wait some time.
    but now nothing happens no matter how much i wait/ charge/ press and hold power button.
    i have no knowledge of motherboards ....
    10-20-2024, 02:48 PM
  • usbdevice
    Acer X223HQ (Version Bbd) on/off-power-cycling
    by usbdevice
    Hi all
    There's two other threads about this monitor with seemingly the same problem. The problem was resolved in one case by replacing the entire PSU board and in the second one by replacing an unknown IC.
    https://www.badcaps.net/forum/showthread.php?t=50657
    https://www.badcaps.net/forum/showthread.php?t=40512
    The first one has pictures of the pcbs and I noticed that there's one IC and assorted caps not populated on mine (but the PCB itself looks identical) so I thought that'd warrant a new thread.
    It's my dad's old monitor. He...
    08-05-2022, 02:21 AM
