Lenovo Ideapad 3 17ALC6 - No Backlight
  • Sofian75
    • Aug 2023
    • 87
    • France
    I need help please.
    I purchased a new screen for this laptop, I do see a very dim picture but the backlight isn't working.
    I tested the screen with another laptop and it's working fine, so I am trying to figure out what's wrong with this motherboard.
    These are the measurement I ve taken:
    +LEDVDD = 19V
    DISPOFF_N = 3.3V
    INVT_PWM = 0.126V
    CPU_EDP_HPD = 2.42V
    +LCDVDD_CON = 3.3V
    Any idea what should I check next?
    Could the problem be with the bios?
    (Bios, boardview and schematic attached)
  • Sofian75
    • Aug 2023
    • 87
    • France
    JEDP1
    • lotas
      • Jan 2016
      • 4759
      • Russia
      INVT_PWM = 0.126V - The problem is that the power supply to the inverter is too low.
      • Sofian75
        • Aug 2023
        • 87
        • France
        It comes from UC4.
        Is there a way to check if the chip is dead?
        Should I try to bridge pin 4 and pin 5 of UC4?​
        • lotas
          • Jan 2016
          • 4759
          • Russia
          The matrix loop (cable) itself is fine, did you use a multimeter to test this line from the chip to the matrix?
          Does the signal from the CPU go to 2 pin SN74LV1T125?
          And what is the resistance of this INVT_PWM line relative to ground?
          • Sofian75
            • Aug 2023
            • 87
            • France
            What is the matrix?
            I have 0.126v at pin 2, same thing than pin 4.
            I checked the resistance to the ground of UC4:
            Pin 2 = 75K ohm
            Pin 5 = 3.6K ohm
            Pin 4 = 2.8 ohm
            Shorted?
            • lotas
              • Jan 2016
              • 4759
              • Russia
              Originally posted by Sofian75
              What is the matrix?
              Shorted?
              Panel (screen).
              Yes, low resistance, disconnect the cable and check which side is short (chip side or cable/panel side)
              Maybe the cable itself is broken, the insulation at the bend is damaged and has a short to ground...
              • Sofian75
                • Aug 2023
                • 87
                • France
                Panel (screen).
                Same resistance on both side with screen connected or disconnected.
                The only other thing on the INVT_PWM line is RV6.
                Should I desolder it and check again the resistance to the ground on the line?
                Is there another way to check if either UC4 or RV6 is the one shorted?
                Voltage injection on this line?
                • lotas
                  • Jan 2016
                  • 4759
                  • Russia
                  This is definitely a resistor?, maybe it's a ceramic capacitor, if so, then it can short to ground, remove it from the beginning, if the short does not go away, then remove the chip.
                  Is this GND?
                  • lotas
                    • Jan 2016
                    • 4759
                    • Russia
                    del
                    • Sofian75
                      • Aug 2023
                      • 87
                      • France
                      Is this GND?
                      Yes according to the boardview it's a 100k resistance, I removed it, check the resistance and it was fine, 100K, and of course the short was still there.
                      Next I removed UC4 and the short on the line was gone.
                      With the chip removed I was not worried of damaging the cpu anymore so I bridged pin 4 and pin 5, now the screen is working but as expected it's at 100% brightness and moving the slider in windows doesn't do anything, I ll have to order the chip.
                      Thanks for your help 👍
                      • lotas
                        • Jan 2016
                        • 4759
                        • Russia
                        Ok!
                          Lenovo IdeaPad 3 17ALC6 Notebook 3 Specification for Upgrade or Repair
                          This specification for the Lenovo IdeaPad 3 17ALC6 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 3 17ALC6 boardview and 3 17ALC6 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Lenovo...
                          09-07-2024, 05:20 AM
                          09-07-2024, 05:00 AM
