Dell laptop double windows.
  • hienton2
    • Sep 2009
    • 183
    I have Dell Latitude D630 . It has 2 windows with a white line at the center.
    Above the line is a window below the line is another windows. Two windows are same.
    Anybody know what can be problem? I this GPA video ic problem.?
    TIA
  • rogfanther
    • Jul 2006
    • 458
    • Brazil
    Re: Dell laptop double windows.
    Does it show that even in the bios / boot screen ?
    The way I solved it once : disconnect the display cable, clean it, then reconnect. Don“t know why it would show two windows, but, hey, it worked, so I do not complain.
    • hienton2
      • Sep 2009
      • 183
      It shows from the bios phase. I will try to clean see what will happen.
      • Th3_uN1Qu3
        Believe in
        • Jul 2010
        • 6031
        • Romania
        In that case you are right, it's a GPU problem, some of the solder balls underneath the BGA chip have failed. What GPU does it have?
        A working TV? How boring!
        • hienton2
          • Sep 2009
          • 183
          After cleaning(not longtime).I will reflow GPU. I thought GPU is culprit.
