dead samsung 940bw
  • blasteroo
    • Apr 2012
    • 5
    • portugal
    dead samsung 940bw
    I'm new to this forum and I've got a dead samsung 940bw monitor that went completely dead a few weeks ago, and I was hoping not to give up on it just yet and hopefully bring it back to life.
    When I turn the power switch on then hit the frontal power button, a blue led lites and I get a faint grey on the screen, almost unnoticeable.
    If it hit the frontal power button again, the blue led shuts off and the screen goes completely black.
    I already changed: (2) 1000uf/16v and (2) 1000uf/25v capacitors on the power board with no avail.
    I don't want to spend any more money on parts without having a more clear direction where to start from.
    Could you help me troubleshoot it?
    Regards,
    Paulo
  • Jasgriff
    • Feb 2012
    • 578
    Re: dead samsung 940bw
    Hi blasteroo,
    Can you see an image on your screen if you shine a flash light at it?
    Does the screen come on normally for a few seconds before turning off?
    And welcome to the forum.
    Fixed so far : 1 Home cinema system, 16 LCD Monitors, 4 LCD TV's
    How to resize your pictures guide click HERE
    Retiredcaps Ideal post example click HERE
    • blasteroo
      • Apr 2012
      • 5
      • portugal
      Jasgriff,
      Thank you for the reply and for the welcoming message.
      Regarding your questions, the faint grey image (without graphics) is only noticed in a really dark environment. In a well-lit room you can hardly see a change.
      The screen doesn't come on at all, except for the faint grey image.
      When I press the frontal power button I either get:
      - No image + no led light
      - Faint grey image with no graphics + continuous blue led light
      Best,
      Paulo
      • blasteroo
        • Apr 2012
        • 5
        • portugal
        Jasgriff,
        I think I understood what you meant when you asked "Can you see an image on your screen if you shine a flash light at it?".
        Yes, I can see windows desktop if I shine a flash light really close to the screen.
        Any advice?
        Thank you,
        Paulo
        • retiredcaps
          • Apr 2010
          • 9271
          If the backlights don't come on, check for
          1) blown fuse in the inverter section
          2) shorted mosfets in the inverter section
          Both components could be on the back side.
          --- begin sig file ---
          --- end sig file ---
          • Jasgriff
            • Feb 2012
            • 578
            that's good it tells us that its your back light not coming on or not staying on that's the issue.
            If you are not even getting a flash of light then this looks like the inverters which drive your back lights are not getting any power at all. This is why retired caps is asking you to check for a blown fuse or mosfet. As he explains these will be on the underside of you main board.
            This is difficult to point out without really good clear pics of the top and the bottom of you board.
            • blasteroo
              • Apr 2012
              • 5
              • portugal
              Thank you so much for your help!
              Please see attached pic of power board.
              I've checked the FH602 and FH601 fuses for continuity with a multimeter
              and it seems to be ok.
              Could you assist me in testing the mosfets?
              Paulo
              • Nocta
                • Mar 2012
                • 117
                • Argentina
                http://www.youtube.com/watch?v=fsdQtcd9tDs
                Você fala português.
                Or
                http://www.youtube.com/watch?v=YsJXFLnA62s
                PS: Is it me or the plastic BN26-00012A is fried? It look to me that the plastic has been exposed to really high temperatures.
                • retiredcaps
                  • Apr 2010
                  • 9271
                  I don't recommend using continuity as a good way to reliably see if a fuse is good or not. A good fuse should measure less than 1.0 ohms.
                  Some multimeters will beep continuous if the resistance is less than 1800 ohms. No fuse is good when the multimeter beeps and the resistance reading is 1795 ohms.
                  As I mentioned, the mosfets could be on the backside. A procedure for testing is at
                  https://www.badcaps.net/forum/showpo...4&postcount=19
                  • blasteroo
                    • Apr 2012
                    • 5
                    • portugal
                    Hi guys,
                    thank you so much for the help you provided.
                    I've decided to order a used powerboard from ebay, I've received and installed it today and the monitor came back to life.
                    All is good now.
                    It cost me around 19 euros and it solved the issue.
                    Thanks again for your selflessness and support.
                    Best,
                    Paulo
                    • Jasgriff
                      • Feb 2012
                      • 578
                      Hi Paulo,
                      Glad you got it up and running. Shame we didn't manage to get the olf board up and running.
                        09-07-2024, 05:50 AM
                        09-06-2024, 11:40 PM
                        09-06-2024, 08:40 PM
                        Samsung Galaxy Book Ion NP930XCJ-K01DE Notebook Specification for Upgrade or Repair
                        This specification for the Samsung Galaxy Book Ion NP930XCJ-K01DE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP930XCJ-K01DE boardview and NP930XCJ-K01DE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                        09-06-2024, 06:20 PM
