Samsung 244T
  • thraxarious
    • Jun 2010
    • 25
    Samsung 244T
    Hello, I'm trying to track down some information on the power board inside this guy, I was hoping someone had more information.
    Unfortunately I have not been able to find a diagram or schematic for the board in this, and I'm trying to double check what kind of capacitor it uses in a couple spots.
    Board: PSLF101401A
    Capacitor locations CM809, CM813, CS806
    Other versions of the power board used in this monitor have some different capacitors at CS802 that does not match what this one has.
    In other words, I lost which capacitors go where.
  • thraxarious
    • Jun 2010
    • 25
    Re: Samsung 244T
    This is mostly because I ended up moving with a few projects half finished...
    I know that CS806 is a 47uf 6.3v capacitor,
    but the other two I know one is a 10uf 50v, the other is a 100uf 10v...
    I was hoping someone knew of ways to get info on the schematics somehow or had one they could double check.
    • PlainBill
      • Feb 2009
      • 7034
      Re: Samsung 244T
      Good clear pictures of the top and bottom of the power supply would make it possible to deduce which is where. The 10uF, 50V one is most likely on the Vcc supply for the SMPS controller. The 100uF, 10V one may be in the regulator circuit.
      PlainBill
      • gregsal
        • Mar 2010
        Re: Samsung 244T
        Samsung pslf101401a rev 1.0
        CM809 - 100μf 10v
        CM813 - 10μf 50v
        CS806 - 47μf 63 v (NOT 6.3v!)
        CM851, CM852, CS852 - 1000μf 35v
        CM801, CS808, CM810 - 47μf 50v
        CM856 - 1000μF 25V
        CM861 - 2200μF 10V
        CS802 - 10μF 50V
        I think that covers it for caps
        (Crapxon - FTW!!)
        • ndttech
          • Sep 2014
          • canada
          Re: Samsung 244T
          Although this is late to this thread...
          Here is the cap layout for the Syncmaster 244T power supply attached...
          Regards...
          • Erwin0265
            • May 2017
            • 18
            Re: Samsung 244T
            Thanks, ndttech; now it may end up being helpful for me three years on (so good they don't close posts that are a year old with no activity like so many forums do)......
            • golemmaster
              • Jul 2009
              • 100
              Re: Samsung 244T
              I am currently working on a Samsung 244T for my brother.
              As you already know, ALL the CapXon caps have to be replaced. Even the 450v. It failed without bulging. I took it out to test out of circuit for the heck of it... bad. Don't assume that one is good. Go ahead and replace that one too.
              Testing done with a ESR-micro v3.1 I bought some time ago.
              • Andrew F. Ali
                • Jan 2014
                • 2450
                • Trinidad & Tobago
                Re: Samsung 244T
                After replacing the caps, is the unit working now??
                • Daffy Duck
                  • Oct 2020
                  • USa
                  Re: Samsung 244T
                  Big Cap should be 100uF, 450 V, not 1000uF as defined in PDF file
                    09-07-2024, 05:50 AM
                    09-06-2024, 11:40 PM
                    09-06-2024, 08:40 PM
                    Samsung Galaxy Book Ion NP950XCJ-K01DE Notebook Specification for Upgrade or Repair
                    This specification for the Samsung Galaxy Book Ion NP950XCJ-K01DE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP950XCJ-K01DE boardview and NP950XCJ-K01DE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                    09-06-2024, 06:20 PM
