Samsung 740n inverter problem.
  • BenCesur
    • Jun 2011
    • 35
    IP-35135B model of defective power board in my hand I have two. These boards are often used in the Samsung 740N monitors.
    Now both of these boards the same problem. Display does not light. Lamps are secure.
    If my actions, I changed the capacitors. I changed the 4502C circuits. Marked with blue lines where there are 620 STK. I changed her. The problem still continues. Where can I find manual to repair this product. or Do you have a friend that can help me about this problem?
    Here are pictures of products.
  • zero10
    • Oct 2011
    • 39
    Re: Samsung 740n inverter problem.
    At the bottom of this page is a huge thread specifically focusing on the samsung 740n
    https://www.badcaps.net/forum/showthread.php?t=5136
    Also, you don't say whether you changed the small fuse (F201 or is it F301...)?
    I just repaired one of these today which had bad caps and a bad fuse. I first replaced the caps then a week later (today) figured out you sometimes need to replace the fuse as well
    • BenCesur
      • Jun 2011
      • 35
      Thanks but the problem continues.
      IP-35135A and IP-35135B Samsung monitors two types of boards used. A series of boards is making the problem more easily repaired , but the B series boards is making more problems.
      This should solve the problem.
      • BenCesur
        • Jun 2011
        • 35
        Thanks ! @zero10
        Blown a fuse, as you say invisible. 3A pico fuse. Quite a funny situation.
        • dundee84
          • May 2010
          Thanks to this thread I fixed my Samsung SyncMaster 940bx.
          I replace all the major caps exept the big one. The Fuse F301 was blown too.
          Working like a charm now!
          Thanks BenCesur!!
          • GeForce_29
            • May 2013
            • Philippines
            I have here the same problm about Samsung 740n inverter,..blotted caps,blown fuse,.I replaced all blotted caps and a blown fuse,but it work for just a couple of hours and the fuse blown agai,And then I found out that one of the 4502c mosfet is partialy shorted,..So I replaced it,..And It works,..Hope this tips can help,..thnx badcaps
            • tvl_svl06
              • May 2015
              • 23
              • india
              af4502c mosfet equlant
              • The ENIGMA
                • May 2015
                • 47
                • Egypt
                [QUOTE=zero10;193199]At the bottom of this page is a huge thread specifically focusing on the samsung 740n
                I just repaired one of these today which had bad caps and a bad fuse. I first replaced the caps then a week later (today) figured out you sometimes need to replace the fuse as well [/QUOT]
                thanks man this replay solved the problem
                i didn't have that fuse and i look around for alternatives i put thin solider wire
                that should be OK ???
                it works fine i'm just afraid from burning it later !!?
                  09-07-2024, 05:50 AM
                • vincentedel
                  Samsung SyncMaster 740n Phase Control Issue
                  by vincentedel
                  I'm having an issue with the Samsung 740n's phase control setting. When I use the automatic adjustment, it sets the value to around 54 (with a range of 0-100), and the picture looks clear and sharp. However, after some timeβ€”like after playing a gameβ€”the text starts to look blurry. When I auto-adjust again, it may increase the value to 80, and everything becomes sharp once more. Yet, after a while, whether it's a few hours or a day later, the same blurriness returns, and I have to adjust it again.
                  I'm using the Samsung 740n monitor drivers instead of the default plug-and-play...
                  04-22-2025, 12:33 AM
                  09-06-2024, 11:40 PM
                  09-06-2024, 08:40 PM
