Samsung 740n inverter problem.
  • BenCesur
    • Jun 2011
    • 35
    IP-35135B model of defective power board in my hand I have two. These boards are often used in the Samsung 740N monitors.
    Now both of these boards the same problem. Display does not light. Lamps are secure.
    If my actions, I changed the capacitors. I changed the 4502C circuits. Marked with blue lines where there are 620 STK. I changed her. The problem still continues. Where can I find manual to repair this product. or Do you have a friend that can help me about this problem?
    Here are pictures of products.
  • zero10
    • Oct 2011
    • 39
    Re: Samsung 740n inverter problem.
    At the bottom of this page is a huge thread specifically focusing on the samsung 740n
    https://www.badcaps.net/forum/showthread.php?t=5136
    Also, you don't say whether you changed the small fuse (F201 or is it F301...)?
    I just repaired one of these today which had bad caps and a bad fuse. I first replaced the caps then a week later (today) figured out you sometimes need to replace the fuse as well
    • BenCesur
      • Jun 2011
      • 35
      Thanks but the problem continues.
      IP-35135A and IP-35135B Samsung monitors two types of boards used. A series of boards is making the problem more easily repaired , but the B series boards is making more problems.
      This should solve the problem.
      • BenCesur
        • Jun 2011
        • 35
        Thanks ! @zero10
        Blown a fuse, as you say invisible. 3A pico fuse. Quite a funny situation.
        • dundee84
          • May 2010
          Thanks to this thread I fixed my Samsung SyncMaster 940bx.
          I replace all the major caps exept the big one. The Fuse F301 was blown too.
          Working like a charm now!
          Thanks BenCesur!!
          • GeForce_29
            • May 2013
            • Philippines
            I have here the same problm about Samsung 740n inverter,..blotted caps,blown fuse,.I replaced all blotted caps and a blown fuse,but it work for just a couple of hours and the fuse blown agai,And then I found out that one of the 4502c mosfet is partialy shorted,..So I replaced it,..And It works,..Hope this tips can help,..thnx badcaps
            • tvl_svl06
              • May 2015
              • 23
              • india
              af4502c mosfet equlant
              • The ENIGMA
                • May 2015
                • 47
                • Egypt
                [QUOTE=zero10;193199]At the bottom of this page is a huge thread specifically focusing on the samsung 740n
                I just repaired one of these today which had bad caps and a bad fuse. I first replaced the caps then a week later (today) figured out you sometimes need to replace the fuse as well [/QUOT]
                thanks man this replay solved the problem
                i didn't have that fuse and i look around for alternatives i put thin solider wire
                that should be OK ???
                it works fine i'm just afraid from burning it later !!?
                  09-07-2024, 05:50 AM
                • howardc64
                  Samsung UN55JU650DF network/streaming problem
                  by howardc64
                  Fixed a 9 year old UN55JU650 by replacing backlight. Original backlight LED was still working after 27k! hours but terrible picture of course. Few LEDs were out, 5-6 lens fell off (bright white spots) and another few popped off with slightest force. Surviving LEDs were all slightly blue so picture has a blue tint.
                  This TV runs older Tizen OS (updated to latest version, see pic) and have problems with network (wifi or ethernet) connection. The Tizen UI frequently switch to coax input source while changing content sources. . If no good signal (coax not connected, no prior antenna/cable...
                  07-09-2025, 12:44 PM
                • vincentedel
                  Samsung SyncMaster 740n Phase Control Issue
                  by vincentedel
                  I'm having an issue with the Samsung 740n's phase control setting. When I use the automatic adjustment, it sets the value to around 54 (with a range of 0-100), and the picture looks clear and sharp. However, after some time—like after playing a game—the text starts to look blurry. When I auto-adjust again, it may increase the value to 80, and everything becomes sharp once more. Yet, after a while, whether it's a few hours or a day later, the same blurriness returns, and I have to adjust it again.
                  I'm using the Samsung 740n monitor drivers instead of the default plug-and-play...
                  04-22-2025, 12:33 AM
                • alro7779
                  Samsung UN55MU6103F video problem; has colored stripes on the display
                  by alro7779
                  Hello, everyone!
                  A co-worker gave me a 55-inch Samsung TV model UN55MU6103F so I can try to fix the following problem... As soon as I plug it in to the wall, the TV turns on, and the display shows a few stripes all over the screen. I took off the back cover and disconnected both ribbon cables that go to the display (one at a time) so by doing that I can narrow down the bad section of the problem, but in both cases the display turns black. I know there are some voltages that I have to check (VGH, VGL, etc.) but don't know what reading each has to show. If anyone could guide me on this,...
                  09-27-2025, 11:29 PM
                  09-06-2024, 11:40 PM
