Samsung 940BX Help
  • david7037
    • Oct 2011
    Samsung 940BX Help
    A few quick questions for the regular/experts:
    symptom: blue power light on but no backlight.. sometimes monitor comes on but gets noticably longer between intervals
    took it apart and the monitor has a BN44-00123A power board
    visual inspection shows one of the 4 Samxon 1000uF caps is bulging
    Question is will a BN44-00123E board be a direct replacement?
    I do plan on changing the 4 caps... but just in case will the "E" revision board work Ok in this model
    Thanks in advance for any help you can provide...
  • retiredcaps
    • Apr 2010
    • 9271
    Re: Samsung 940BX Help
    I don't know if "E" will work since manufacturers make revisions for a reason, but changing 4 caps on your "A" board should be fairly easy if you have done any soldering before.
    If the Samxon caps are labeled GF, they are a problematic series. Use something like Panasonic FR or FM series for replacements.
    --- begin sig file ---
    --- end sig file ---
    • david7037
      • Oct 2011
      They are from the "GF" series
      • retiredcaps
        • Apr 2010
        • 9271
        Assuming they are 16V 1000uF caps and the dimensions fit (height and diameter), these Panasonic FR would be a good replacement.
        http://search.digikey.com/scripts/Dk...tock=1&x=0&y=0
        Also, don't overlook the other caps like the small startup cap. Little caps don't have to bloat in order to be bad. In fact, most of them don't bloat when bad.
        • david7037
          • Oct 2011
          Replaced the 4 1000uf caps and monitor is back in action ......Thanks!
          This 940BX uses a older power supply board normally found in a 940BW
            09-07-2024, 05:50 AM
            09-06-2024, 11:40 PM
            09-06-2024, 08:40 PM
            Samsung Galaxy Book Ion NP930XCJ-K01DE Notebook Specification for Upgrade or Repair
            This specification for the Samsung Galaxy Book Ion NP930XCJ-K01DE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP930XCJ-K01DE boardview and NP930XCJ-K01DE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
            09-06-2024, 06:20 PM
