HP W2408 Problem
Re: HP W2408 Problem
Originally posted by sprocket View PostOK where we at, are you saying replacing Q110 and U117 will fix it?
If so what did you come up with for a Q110, the one I listed above?
And I lost track of another detail. I had asked for the part number on U109. What are the voltages on it's pins?
PlainBillLast edited by PlainBill; 09-04-2011, 05:49 PM.For a number of reasons, both health and personal, I will no longer be active on this board. Any PMs asking for assistance will be ignored.
Originally posted by sprocket View Postpin1 = gnd
pin2 = 3.3 vdc
pin3 = 3.3 vdc
I'm using an analog meter and reading a tad better than 3v and calling it 3.3
I'll dig out the digital and scale down ...
Actually using the digital pin3 is 3.288 and pin2 is 3.294
PlainBillLast edited by PlainBill; 09-04-2011, 07:32 PM.For a number of reasons, both health and personal, I will no longer be active on this board. Any PMs asking for assistance will be ignored.
Man you lost me .. where is this gm5868H-LF located and does it say that on it?
OK went back and I see it. That looks like the whole Kaboodle
Changing that would be pretty challenging even if I could get one.
I searched for a new ILIF035 digital board and didn't find anyLast edited by sprocket; 09-04-2011, 08:12 PM.
Originally posted by sprocket View PostMan you lost me .. where is this gm5868H-LF located and does it say that on it?
This case is different for several reasons - you haven't reported that U109 has a hole in it, I can't find any information showing that U109 is a reset controller, and most importantly, the GPU IS showing some signs of life.
At this point I'm guessing, but if I had to make a guess, I'd guess that U110 is the problem. That contains the firmware for the monitor, and it may be corrupt. The two paint dots on it suggest it has been loaded with code prior to being installed.
There are a couple of things you can try. With power off, check the resistance between U109 pins 2 and 3. It should read well over 1K ohm, probably over 10K. If it reads less than 10 ohms, remove U109 and try the monitor. Alternatively, with power on, short U109 pin 1 to pin 2 and see if the monitor starts working.
PlainBillFor a number of reasons, both health and personal, I will no longer be active on this board. Any PMs asking for assistance will be ignored.
U109 2 to 3 measures 4500 ohms
Shorting 1 and 2 and holding it makes the blue light first go out then in about 10 seconds it comes on amber. If I remove the short it goes out and 10 seconds comes back on blue.
If I just hold it shorted, it will be amber and blink off and on every 10 seconds
Yes the back light does come on and a white rectangle like for a message shows in the middle but has no text (just blank white)
I'm going back and try it with a HDMI cable and will report if any difference
OH ya, I do have to ground pin2 to kick start this scenario each time
OK here is what happens
With VGA and I reset pin2, the white blank rectangle will show only
With HDMI and I reset, XP desktop actually shows but is really washed out with brightness
In either case above the OSD will not show using any of the keys
If I shut down, the back light will stay lite but I have to reset when I reboot to get XP to show.
I read on the 10 second Menu lockout and none of that worked
Also when changing screens in XP, the brightness flairs all over the place
Originally posted by sprocket View PostPlain Bill
I wish to thank you for all your work for me
It must indeed been the chip lost it's programming. I found a new board for $70 bux and it's now up and running
I got around a $100 in it but I think it's worth more than that
Hello!
I found this forum when I was looking for some tips to fix my Hp w2408H monitor that went dead.
Insted of starting a new thread I ask my question in this so I can refer to what already been said.
My monitor:
When it still worked I heard a ticking when I turned my computer off. That was not a problem when i never closed it down.
Then I moved and when i tried to start it again nothing happend. Only the amber status light was on, and i heard the ticking.
Now 9 months later I am looking into it again and found that now the amber status light not light up anymore but i still hear the ticking.
Originally posted by PlainBill View Post
Using either pin 3 or 4 as the ground point, what are the voltages on pins 1, 5, 7, and 8? What is the voltage across C3?
C3: varies from about 5V to about 15V
pin 1: varies from about 5V to about 15V
pin 5: varies from about 0V to about 5V
pin 7: 0V
pin 8: 0V
Christer Bruno-Lundh
2) You could have dry capacitors causing your voltage fluctuations.
3) There could be a shorted component causing excessive load on the smps.
Either way, post top down view pictures of all your boards following my sig file below exactly.--- begin sig file ---
--- end sig file ---
I can't find any legend. I took a better photo of the connection point.
Tried to take a photo of the "daughter board". I think I have to take it off to take a better picture.
I found something that looks like some burn. (Found it when i uploaded the pictures)
But i can't remember seen it before. Not sure I caused it when I was mesure the the pins yesterday.
Originally posted by brunolundh View PostTried to take a photo of the "daughter board". I think I have to take it off to take a better picture.
http://pdf1.alldatasheet.com/datashe.../SG6902SZ.html
I found something that looks like some burn.--- begin sig file ---
Thanks, retiredcaps for providing the link.
brunolundh, refer to the datasheet for the location of pins 10 and 15 on the SG6902SZ. CAREFULLY!!! measure the voltage on from pin 10 (black lead) and 15 (red lead) on the IC. It's tight quarters, we may have to find another way to do this.
