I've taken a few more pictures:
power-logic-connected.jpg - A picture of what I had connected for the tests, just to make sure I understood you correctly.
powerboard-power-pins.jpg - Closer view of the power board pins
logicboard-power-pins.jpg - Closer view of the logic board pins
Which board is showing signs of overheating? I'm assuming you mean the logic board since those pins are looking brownish.
I saw what appears to be an S_B pin (just to the left of the PSON pin), and I tested that voltage and, depending on how steady my hands were, between 3.5V and 4.3V.
Because I wasn't sure if S_B was the right pin to be testing, I also tested the three 5.3V pins. Those all read 0V.
The PSON pin measured between 0.6V and 1.4V. I noticed though that if I had a voltage over 1.0V, it would often slowly decrease until it reached 0.6V or 0.7V.
When I connected the cable that leads to the buttons on the front bezel, and pushed the power button, I noticed at most a 0.1V drop, but I wasn't sure if that was from my unsteady hands, the decreasing voltage behavior I mentioned above, or what. Pressing the power button repeatedly did not cause the voltage to go down any further, nor would it go back up 0.1V. I tried to wait until the PSON voltage stabilized before pressing the button, but it was a little difficult holding the leads with one hand, pressing the button w/ the other, and staying steady enough to read the DMM. If you like, I can try it again when my wife gets home to help me out.
I tested it anyway, it measured at 160V.
I didn't connect everything, because as you correctly noticed, I'm new to this and wanted to start out with the simpler setup first.
Going from top to bottom:
NC: 0V
NC: 0V
+5V_IN: 0V
+5V_IN: 0V
+5V_IN: 0V
GND: 0V
GND: 0V
GND: 0V
NC: 0V
NC: 0V
NC: 0V
GND: 0V
GND: 0V
GND: 0V
5.2V_ST: Ranged between 3.5V and 5.2V
POWER_EN: 1.41V
Definitely appreciate it, you are right, this is my first time working w/ electronic components.
Thanks again for the advice guys!
