Getting started with troubleshooting [Samsung 245BW]
    I have two dead monitors right now, one is a Samsung Syncmaster 245BW that died mysteriously last night and was a replacement for my first dead monitor, a Samsung Syncmaster 204B.
    The 204B has the flickering issue, and about a year ago I had found all the howtos for replacing the capacitors on the power board, but I never got around to actually fixing it. That is, until last night when my 245BW died. The 204B has now been disassembled, and I see the tell-tale bulging capacitors and I will be having a friend (who is handy w/ a soldering gun) help me replace them shortly.
    Now, I'd like to start troubleshooting the issues w/ my 245BW - the power button doesn't even light up. I see there are other threads already about similar issues w/ the 245BW, so I want to try the existing suggestions/tests to make sure the solution to my problem hasn't already been discussed. However, as I read through the threads I realize I'm in a bit over my head.
    So, I wanted to make sure I had the right tools and get some basics down before I got started. I have a multimeter (attached a picture), but I see people mentioning an ESR meter. From what I gather, it's designed to measure much lower values than most multimeters can measure? Will I need an ESR meter?
    Also, I see people advising to measure voltages and resistances of various circuits. Am I correct in assuming that this is done w/ the monitor opened up, but everything still connected and w/ power on?
    Finally, I see there's a 245BW thread already. Once I'm ready, should I post my issue in there or should I start a new thread? Not quite sure what the etiquette is here.
    Thanks!
    Re: Getting started with troubleshooting
    The power LED not lighting up could also be a sign of bad capacitors. Capacitors die from age, heat, and shoddy build quality. Capacitors DO NOT have to be visibly bloated in order to bad. They can be out of tolerance uF (a 1000uF measures 20uF) and/or have high ESR (ohm). A multimeter will be insufficient to test for ESR. For that you need an ESR tester which costs between $50 and $300.
    Replacing all your caps is probably less than $10 while a low end ESR meter is $50. So unless you are doing a lot of repairs, the economics don't justify the purchase of an ESR meter.
    Yes. Since there is no power LED, you will be asked to see if there is secondary voltage present between the power and logic board using your multimeter. The logic board needs probably 5V DC to enable the power LED. Resistance is ALWAYS measured with power OFF and lcd unplugged.
    Either tacking on or starting a new one is okay here. Each has its pros and cons. Make a decision and keep it in one thread so people are not confused.
    --- begin sig file ---
    --- end sig file ---
      I agree...
      An ESR measures Ohms, yes, but it measures it using [in our case] a 100kHz test signal.
      A DMM measures it with DC.
      Mann-Made Global Warming.
      - Dr Seuss
        The 245BW is pretty well documented on this site and it seems that problems for this monitor are narrowed down to bad caps or bad resistors.
        Another great tool for troubleshooting is the "search" function located in the above toolbar. You're already ahead of the game, since you've taken the time to read some of the threads. There's one thread that spans 15 pages! You definitely get the gold star if you can stomach reading through it all. However, there's great info and it's likely you'll solve the problem using that info.
        If you still have problems, then as mentioned above, post some photos and provide a good description of the symptoms and we'll go from there.
          Thanks for the reply guys. So, just so I understand -
          1.) The DMM I have should be sufficient for measure voltages, and is what I'll need for testing that there is voltage present between various components
          2.) An ESR is for diagnosing specific capacitors (assuming it isn't obvious what's wrong from other tests)
          So I guess the next thing for me to do is to test that voltage is present between the power board and logic board. I believe I know which is which - the power board is the one that has the power switch and power cable connector, and the logic board is the one with the DVI and VGA ports? If so, can I just connect those two together to test for voltage, or do I need to connect everything together (power board to inverter board, logic board to LCD panel, etc)? And how exactly would I test for voltage between those two boards (i.e., which pins would I use)?
          I've attached pictures of the 3 boards I can see, and I'd just like to make sure I've identified them properly:
          A-front.jpg and A-back.jpg is the front and back of the power board.
          B-front.jpg and B-back.jpg is the front and back of the logic board.
          C-front.jpg is the front of the inverter board (the back is empty).
          Thanks again!
            I forgot to mention, when I noticed the monitor wasn't turning on, I smelled the back grill and detected a an electronic burn smell. In A-front.jpg, I highlighted a solenoid(?) in the lower right hand corner that had a faint electronic burn-type smell to it. None of the other components seemed to have a noticeable smell. Not sure if that means anything or not.
              Pretty good pictures, but there is a slight problem. The legends on the bottom aren't quite clear enough to read. I'll describe what I need, then you can take it from there. If you need further help identifying the correct pins, please provide better pictures of the connector areas of the power supply.
              This is a common type of power supply used in larger monitors. It is actually a dual supply. The standby supply normally produces 5 volts whenever the power cord is plugged in. There is a control line from the signal board (logic board) that turns the main supply on. Turning the main supply on also turns on a PFC front end. Also, the board shows signs of moderate overheating.
              For the first test, all you will need are the power supply and the signal card hooked together; disconnect the cable that runs to the inverter. The first test is on the connector from the power supply to the signal card. One of the lines (pins) should be labeled 5VSB or something similar. Other pins will be labeled Gnd. With the monitor connected to power, measure the voltage between Gnd and 5VSB.
              If 5VSB is present, look for a pin labeled PSON, On/Off, or something similar. Measure the voltage from Gnd to that pin. Does the voltage change when you press the power button?
              If 5VSB is not present, check the voltage across the very large cap in the center of the board. That should read either 165 volts or something like 380 volts. If that voltage is missing, check the two fuses.
              EDIT: The 'solenoid' is an inductor. Check the leads for cracked solder joints.
              PlainBill
                Yes, the Greenlee multimeter is much better than those generic 830 made ebay junk and is more than sufficient to measure voltage.
                An ESR tester measures the equivalent series resistance (ohms) of a capacitor. While nice to have, it is not a requirement.
                Correct.
                Connect everything to get a "load" on the power supply.
                1) Put your multimeter on 20V DC.
                2) Put your black probe on a ground screw on the logic board.
                3) Put your red probe on each pin on connector CN700. Use a steady hand and do not let the red probe slip and touch 2 connector pins because that might cause a short.
                4) Report each pin and its voltage measurement. Some will be 0, and others should be 5V DC.
                  It looks like PlainBill and I were composing responses at the same time, but his ISP beat mine. :-)
                  Anyway, we are both saying esentially the same thing, but his response covers A to Z, while mine is more "step by step" one at a time and deliberately slower because I sense you are newbie at using your multimeter (I was in your shoes recently).
                  Note that measuring the main filter capacitor involves high voltage so be careful.
                  PS. Since responses are already present in this thread, don't tack onto to the other 245BW threads. Keep everything here.
                    An ESR meter checks the AC 'resistance' of a cap.
                    It's test voltage is [usually] 100kHz.
                    The purpose is to know how well the cap is handling Ripple which is a random AC [usually] at about 100kHz.
                    A DMM can only check DC resistance because it's test voltage is DC.
                    Still somewhat useful with caps because you can find completely open or completely shorted caps but it will miss caps that are shot insofar as their AC properties which is how most caps fail and/or a sign the cap is seriously degraded.
                    - Dr Seuss
                      I've taken a few more pictures:
                      power-logic-connected.jpg - A picture of what I had connected for the tests, just to make sure I understood you correctly.
                      powerboard-power-pins.jpg - Closer view of the power board pins
                      logicboard-power-pins.jpg - Closer view of the logic board pins
                      Which board is showing signs of overheating? I'm assuming you mean the logic board since those pins are looking brownish.
                      I saw what appears to be an S_B pin (just to the left of the PSON pin), and I tested that voltage and, depending on how steady my hands were, between 3.5V and 4.3V.
                      Because I wasn't sure if S_B was the right pin to be testing, I also tested the three 5.3V pins. Those all read 0V.
                      The PSON pin measured between 0.6V and 1.4V. I noticed though that if I had a voltage over 1.0V, it would often slowly decrease until it reached 0.6V or 0.7V.
                      When I connected the cable that leads to the buttons on the front bezel, and pushed the power button, I noticed at most a 0.1V drop, but I wasn't sure if that was from my unsteady hands, the decreasing voltage behavior I mentioned above, or what. Pressing the power button repeatedly did not cause the voltage to go down any further, nor would it go back up 0.1V. I tried to wait until the PSON voltage stabilized before pressing the button, but it was a little difficult holding the leads with one hand, pressing the button w/ the other, and staying steady enough to read the DMM. If you like, I can try it again when my wife gets home to help me out.
                      I tested it anyway, it measured at 160V.
                      I didn't connect everything, because as you correctly noticed, I'm new to this and wanted to start out with the simpler setup first. But, if you think the results below warrant more tests with everything connected, I can certainly do that.
                      Going from top to bottom:
                      NC: 0V
                      NC: 0V
                      +5V_IN: 0V
                      +5V_IN: 0V
                      +5V_IN: 0V
                      GND: 0V
                      GND: 0V
                      GND: 0V
                      NC: 0V
                      NC: 0V
                      NC: 0V
                      GND: 0V
                      GND: 0V
                      GND: 0V
                      5.2V_ST: Ranged between 3.5V and 5.2V
                      POWER_EN: 1.41V
                      Definitely appreciate it, you are right, this is my first time working w/ electronic components.
                      Thanks again for the advice guys!
                        Well, we have a smoking gun - or at least the odor of gunpowder. First, a few points. The bottom of these boards have been coated with some sort of conformal coating. That causes the brown tint on the bottom, and can cause problems making reliable contact. If you look at the lower left corner of the top view of the power supply board you will see what I would call a normal PC board. If you look at the board just above and to the right of the large capacitor you will see it is several shades darker. There are other spots with a similar appearance. This isn't to the point I would suggest junking the board, but does indicate something about the history of the monitor - it saw a lot of use, and got quite warm.
                        The pin you tentatively identified as S_B is definitely the standby supply, and it is not behaving properly. I would expect a steady voltage (probably 5 Volts) at that point. And that leads me to the smoking gun.
                        Referring to the picture of the top of the power supply, directly below the large cap is an 8 pin IC (with pin 6 missing). That is the power supply (SMPS) controller. Below that IC are three small electrolytic caps. The erratic voltage and the 'baked' appearance of the board leads me to suspect one of the caps is bad. What are the voltage and capacity of those? I don't have a good idea which one would be responsible, but at about $.30 each, it seems logical to replace all three.
                        PlainBill
                          Are you referring to the brown/rusty looking substance on the logic board pins? Or are you referring to the darker color of the power board?
                          Yeah, this particular monitor was either on or in standby all the time. I guess I should get in the habit of turning it off...
                          If I'm reading the values correctly, then:
                          - Small, left most capacitor = 50V, 22uF
                          - Larger, center capacitor = 50V, 47uF
                          - Small, right most capacitor = 50V, 2.2uF
                          Thanks, PlainBill
                            Apologies if i am barging in without knocking..
                            Correct me if i am wrong but does the
                            1) 8 pin IC (with the Pin 6 missing) marked A6159?
                            and
                            2) 16 pin IC (12 o'clock of the Big capacitor) marked MC33067P?
                            if yes then
                            1) is Flyback Switching Regulator STR-A6159
                            2) is MC33067P - HIGH PERFORMANCE ZERO VOLTAGE SWITCH RESONANT MODE CONTROLLERS - ON Semiconductor
                            and i believe this is what PlainBill is referring to as the SMPS controller..
                            datasheet here"
                            Just happen that I just did a Samsung TV with ALMOST identical PS board... but i could be WRONG as well..
                              and
                              if yes then
                              datasheet here"
                              For the most part you are correct. Thanks for identifying the ICs. Both are SMPS controllers, although they work in slightly different ways.
                              At this point the STR-A6159 is the focus of my attention - it is part of the Standby power supply. The output of the standby regulator is obviously wrong, now it's a matter of fixing it.
                              PlainBill
                                The coating is causing the dark color in the pins, and can make it difficult to get a reliable reading, as you have already noticed. It's annoying, but nothing that should seriously impede troubleshooting. Just remember if you make a measurement that indicates something (a resistor) is open, it may be the coating preventing good contact.
                                Not strictly necessary. I'm pointing out the darkened color because of what it suggests - caps may be dodgy because they have been lightly toasted. It also may indicate air circulation wasn't particularly good.
                                Thanks, PlainBill
                                Here are the recommended replacements. The first number is the Digikey stock number; the second is the manufacturer's (Panasonic) part number. If you live in the USA I recommend Digikey because they have a USPS First class Mail shipping option that would cost about $2.50 for these parts. The caps range in price from $.31 to $.34 each.
                                - Small, left most capacitor = 50V, 22uF P12927-ND EEU-FM1H220
                                - Larger, center capacitor = 50V, 47uF P10321-ND EEU-FC1H470
                                - Small, right most capacitor = 50V, 2.2uF P10313-ND EEU-FC1H2R2
                                If I had this monitor on my workbench I would be ordering a complete set of replacement caps. Once you get the monitor working you should seriously consider doing that.
                                PlainBill
                                  Ok, I wasn't sure if that brown color on the pins indicated damage, overheating, or what not. Good to know!
                                  When you say "complete set", do you mean for the power board, or for all 3 boards (power, logic, inverter)? I count 10 more capacitors on the power board (on top of the 3 we've already identified) and 2 capacitors on the inverter board. As for the logic board, I'm not sure if those round silver things are capacitors or not?
                                    I would certainly recap the power supply and the inverter. The caps on both of these deal with high surge currents which will age the caps rapidly. The caps on on the signal board are generally on the output side of analog regulators, and don't deal with high surge currents.
                                    If you wish, you can order a complete set of caps. My reservation is you are inexperienced at this. Recently we had a multi-page thread where someone recapped his power supply and it stopped working. It turned out he had managed to break a trace, disabling the main supply. I would rather you take small steps on this project. But it IS your call.
                                    PlainBill
                                      PlainBill
                                      I think I'll take your advice - replace the 3 capacitors first, and if that's successful and I feel a bit more confident, I'll replace the others as well. I also have the capacitors on my 204B to replace, so I'll be getting a lot of practice one way or another. If I can get even 1 out of the 2 monitors working again, I'll consider it a huge success.
                                      Thanks again PlainBill, and everyone else, for your help! I'll let you know how it goes.
                                        Hi guys,
                                        I've been practicing soldering and desoldering on old components, and I think I'm ready to order the replacement capacitors and take a stab at it.
                                        For the most part, I've been able to identify the right capacitors I need for both the 204B and the 245BW. However, I had a question about a few of the replacements. I've listed the capacitor specs (voltage, capacitance, dimensions) and the digikey part # of the replacements I picked.
                                        (When taking my measurements, I assumed the height of a capacitor was just the cap itself, from the top to the base where the leads come out)
                                        Original Cap: 35V 1000uF, 12.5mm x 20mm, 105C
                                        Replacement Cap: Nichicon VZ (493-1322-ND)
                                        Is the VZ series OK? I didn't see it listed in the "What capacitors should I buy?" thread. This is the only match I could find that was rated for 105C temperature.
                                        Original Cap: 35V 470uF, 10mm x 18mm, 105C
                                        Replacement Cap: Panasonic NHG (P5554-ND)
                                        Similarly, is the NHG series OK? There are a few other options that fall under the right dimensions (all of them are 10 x 16). I should have room to accommodate 10 x 20, and if so, I can get Panasonic FC.
                                        Original Cap: 10V 1000uF, 10mm x 14mm, 105C
                                        Replacement Cap: Panasonic NHG (P5521-ND)
                                        Same situation as above. If I go up to 10 x 20, I can get Panasonic FC instead of NHG.
                                        Original Cap: 450V 82uF, 30mm x 22mm, 105C
                                        Replacement Cap: Panasonic TS-ED (P11695-ND)
                                        This is the big capacitor in the center of the board, and the label on the capacitor says "450wv". I assumed that's the same as "450V"? The replacement cap is 25mm tall so I'm concerned that this might be a bit too tall, but didn't see any other options. Also, this cap is listed as "Radial, Can - Snap-In". Is this still an appropriate replacement? Finally, this board has been unplugged for over a week now. Is it safe to remove, or do I need to discharge it?
                                        Lastly, a few of the capacitors have some solid brownish yellow "gunk" on them (you can see it in A-front.jpg in my earlier post). What is this stuff and how do I remove it so I can remove the capacitors?
