Norcent LM-2265W with Blank Display
  • tervel12
    • 42
    Hello all!
    I have another LCD with a problem. This one has a blank display.
    When the monitor is powered up with no computer connected, the display shows a No Signal message after several seconds and then goes blank. The power light also changes to amber.
    With a computer connected, the display remains blank and the power light remains green. I have shined a flashlight on the screen and I am not able to see any image.
    I have checked for voltages at different points and everthing seems normal but without a schematic I am not sure.
    Any ideas where to look?
    Thank you.
  • retiredcaps
    • Apr 2010
    • 9271
    Re: Norcent LM-2265W with Blank Display
    On the logic card, there is a voltage regulator at I104. With respect to ground, list the voltages on all pins.
    Please also report the part number of I104.
    --- begin sig file ---
    --- end sig file ---
    • PlainBill
      • Feb 2009
      • 7034
      Check the display resolution setting on your computer. Many monitors go black if the signal resolution exceeds the capabilities of the monitor.
      PlainBill
      • jetadm123
        • 2169
        Did you try repairing the logic board at all? Looks like two transistors have been resoldered/replaced? Circled in photo.
        • tervel12
          • 42
          I will check the voltages when I get home. However I did note that the middle leg is missing on that regulator. The part number is 1084-33 0712HL.
          PlainBill
          The display resolution is set to 1024x768 and displays fine on a working 15" monitor.
          I removed both transistors to test them out of circuit. So the poor soldering is my handywork. (it's a bitch soldering those little things)
          Thanks.
          • tervel12
            • 42
            Pin 1 is 0V
            Pin 2 is 3.3V
            Pin 3 is 4.7V
            • jetadm123
              • 2169
              Pin 1 is 0V
              Pin 2 is 3.3V
              Pin 3 is 4.7V
              Looks like the 3.3V output is good. Input should be closer to 5V, but 4.7V will do.
              Did you verify that the video cable used to connect your pc to the monitor is good?
              When you say the screen is "blank", I'm assuming that the backlights are also off?
              • tervel12
                • 42
                The cable is good. I have used it on other monitors with no problems.
                The screen backlight comes on briefly when it displays the 'No Signal' message and then it goes out.
                When the computer is connected, there is no backlight or image that I can see.
                Why does I104 not have a pin #2 connected to the board?
                I have removed the caps on the logic board and tested them and they all check out fine.
                • retiredcaps
                  • Apr 2010
                  • 9271
                  How? Did you use an ESR meter?
                  • jetadm123
                    • 2169
                    The middle pin of I104 is internally connected to the metal tab on the back of the regulator.
                    You should at least be getting an image, since the the logic board is getting 5V.
                    • tervel12
                      • 42
                      I do not have an ESR meter. I removed the caps and put them on my DMM with the ohms set to 20K. I can watch the resistance climb as though the cap is charging with the leads connected to the right poles. If I reverse the leads, it shows an infinite reading immediately.
                      Good to know about I104.
                      Since there is no image from either the DVI or VGA line, could the main IC on the logic board be bad?
                      The only image I ever see is the No Signal message with no input connected.
                      Thanks.
                      • jetadm123
                        • 2169
                        Thanks.
                        Yes, I'm starting to think something is wrong with the scaler chip (main chip).
                        • tervel12
                          • 42
                          Any way to test it?
                          Also, is it replaceable?
                          Thanks.
                          • jetadm123
                            • 2169
                            Any way to test it?
                            Thanks.
                            No way to replace the scaler chip. As for the way you tested the caps, it will give very limited results at best. Since you had them out, it would have been best if you had just replaced them all with Panasonic FM or FC series caps.
                            • tervel12
                              • 42
                              Aside from trying the caps, then this thing is pretty much trash I guess?
                              • jetadm123
                                • 2169
                                Not really. You can keep an eye out for a logic card on ebay. Or, try selling it as-is through craigslist or ebay.
                                • tervel12
                                  • 42
                                  I have searched both but have not been able to find any other Norcent monitors. I have found some TVs, but it seems like it is a pretty scarce brand.
                                  Off to ebay then! Maybe somebody out there needs the screen.
                                  Thanks.
