Samsung 930B re-capped, no backlight
  • retiredcaps
    replied
    Re: Samsung 930B re-capped, no backlight
    Originally posted by alexanna
    The voltage is steady at 163v across the big cap with the logic board unpluged
    Sounds like something on the logic board is pulling down the power? I had something similar, but never managed to resolve due to a slip of the hand and shorted out some components on the power board.
    I don't have any ideas. Maybe PlainBill does?
  • Scenic
    replied
    r316 looks pretty toast.. doubt it has something to do with this though..
  • alexanna
    replied
  • alexanna
    replied
    It stays at 160V to 161v the majority of the time, using the min max record it will go as low as 149v briefly at times
  • retiredcaps
    replied
    Pin 1 is fluctuating between 150 and 160V D.C.
    Is the DC voltage stable across the main filter capacitor?
  • alexanna
    replied
    I have a 939B that is not working.
    All the 10mm and smaller caps have been replaced they were obviously swollen. And have been replaced this includes the two 4MM caps.
    U202 and U203 had similar damage as the OP board. And have been replaced.
    I have a power supply that is starting and shutting off repeatedly, the power LED is flashing on and off
    I am currently looking at the DM0565R power switch
    http://pdf1.alldatasheet.com/datashe...SDM0565RB.html
    I have taken some voltage measurements
    Pin 2 dose have a ground
    Pin 3 is fluctuating between 9 and 15V D.C.
    Pin 4 which is the feed Back is Fluctuating between .5 And 8 V D.C.
    Pin 5 not used
    Pin 6 is fluctuating between 32V D.C. and 159 V D.C.
    I guess i should have said anybody got any ideas on what to check
  • leperinc
    replied
    ebay has 10 (ten) for $7 CDN + $4 CDN for shipping. Just search for AF4502C.
    <smacks head> Thanks for pointing that out! I've placed the order, so now we wait...
  • jetadm123
    replied
    Fairchild shows a FDS8928A as a possible replacement. It handles less current than the AF4502C, but might be more readily available. Since they're so cheap, it would be good to order a couple extra just in case.
  • retiredcaps
    replied
    Originally posted by leperinc
    but unless I can find cheaper shipping I think I'm gonna have to call it a day
  • leperinc
    replied
    Originally posted by retiredcaps
    On the front side between the two transformers are a whole bunch of resistors and diodes. You may want to test them all "in circuit" to see if you have a bad component.
    They all look fine. No opens or shorts.
    Originally posted by jetadm123
    If you're not even getting a flash from the backlights when you push the power button, I would suggest you try replacing the two mosfets in question before going any further.
    I wasn't able to find the original part at any of the usual places. Elsewhere in the forum here i saw a couple of people claiming success with a MMDF2C03HD from another manufacturer. A quick search shows Mouser is currently the only supplier with stock in individual chips at $1.47 each.
    However, at $20 shipping, this last item is too expensive for me to continue. Getting this far has cost me $31. I'm currently not working and getting the parts from Mouser will push the total cost of this "free" monitor to just under $60. I saw the $8 USPS option but when you let them collect fees upon receipt it usually means an additional $15-20. The term "egregious" comes to mind. Well, other terms come to mind as well but...
    Big thanks to both of you for helping me with this but unless I can find cheaper shipping I think I'm gonna have to call it a day
  • retiredcaps
    replied
    I'd rather spend $5 in extra parts now as insurance rather than having to spend yet another $8 on shipping later.
    As a fellow Canadian, I can relate with the $8 shipping cost.
  • leperinc
    replied
    No problem, I appreciate your help with this. I'd like to hedge my bets on this one and ask what other components might be needed in case U202/3 are fine. I'd rather spend $5 in extra parts now as insurance rather than having to spend yet another $8 on shipping later.
    Thanks!
  • jetadm123
    replied
  • leperinc
    replied
    U301 is next to transformer T301. What's the part number?
    Sorry about that, there are no opens or shorts no matter what pins/directions I measure.
    here's the pic:
  • jetadm123
    replied
    i'm going crosseyed. I can't find it. Can you point it out to me?
  • leperinc
    replied
    U301 is on the front side.
  • jetadm123
    replied
    I agree with retiredcaps about the mosfets. Anything that heated up like that should be suspect. Also, they should always be replaced in pairs.
    As for pin 16 connected to pin 7, since MODSEL sets the output polarity of the PWM controller, I'm assuming that connecting it to ground specifies a negative polarity.
    Also, when you first power up the monitor, do you get any type of quick flash from the backlights?
  • retiredcaps
    replied
    I don't see a U301
    The look burned alright. Also, the plastic sheet has marks where the chips are.
    Even though the mosfets are not shorted, the one chip looks really bad and could be malfunctioning.
  • leperinc
    replied
    I figured I'd kill some time and poke around on U201 and measure everything from anywhere to anywhere in both directions. There appears to be one short between pin 7 and 16. I'm not sure if this is normal or not. On the similar model (3193) sheet pin 7 is GND and pin 16 is MODSEL. C345 (33uF/35v, replaced) is connected by traces across pin 7 (GND) and 10 (VCC)
  • leperinc
    replied
    See if U301 is shorted. You can measure it in circuit. Report readings.
    edit: Are you seeing 13V DC on the connector CN2?
    I don't see a U301, I'll assume U201. I tried looking up the datasheet on it and can only find the BIT3193. Is this close enough, and what pins should I be paying attention to for measuring?
    I see 13Volts on CN2, yes.
    Hmmm, you did pick the correct location for pin 1. No shorts indicated from your readings. I'm wondering if what's on U202 is leftover residue from the soldering process. Try scratching the top of U202 with your fingernail to see if it will flake off. As for the fuse, Samsung usually puts a fuse at the 13V output, just before the inverter section. And I don't see a fuse either?! As a sanity check, try measuring for the 13V at the middle pin of heatsinked D105.
    There is also 13volts on the center of D105. I've tried to clean the chips, first with my fingernail, followed by a white eraser and rubbing alcohol but it didn't change anything. I took a webcam which can be made to focus really close up and wetted the tops of the chips with alcohol. The look burned alright. Also, the plastic sheet has marks where the chips are.
    09-07-2024, 05:50 AM
    09-06-2024, 11:40 PM
    09-06-2024, 08:40 PM
    Samsung Galaxy Book Ion NP950XCJ-K01DE Notebook Specification for Upgrade or Repair
    This specification for the Samsung Galaxy Book Ion NP950XCJ-K01DE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP950XCJ-K01DE boardview and NP950XCJ-K01DE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
    09-06-2024, 06:20 PM
