HP EN623AA - static /blocky white areas
  • retiredcaps
    • Apr 2010
    • 9271
    Re: HP EN623AA - static /blocky white areas
    Originally posted by torin3
    Your current one is LD1117AL 33AGFSL06. The datasheet suggests that the output current is 1A.
    http://pdf1.alldatasheet.com/datashe...5-TA3-A-R.html
    The one you chose is 1.2A. I don't know if that is enough of a difference, but try to find one that matches the datasheet exactly.
    --- begin sig file ---
    --- end sig file ---
    • jetadm123
      • 2169
      Well, the 3.3V one when I started out was a rock steady 3.30V. When it started doing its weird video thing I read it as 3.33VDC it was gradually climbing. When it got to 3.38VDC I took the probes off, waited a few seconds and then checked again and got 3.39VDC.
      I went ahead and turned it off at that point.
      Should I leave it on longer and see when it stops?
      Should I just switch to the other voltage regulator now?
      Suggest that you at least also check the output of the 1.8V regulator.
      • torin3
        • Aug 2009
        • 178
        http://search.digikey.com/scripts/Dk...=497-1236-1-ND
        Closest I found at DigiKey was 950mA
        Ok. I'll post when I get the results.
        • retiredcaps
          • Apr 2010
          • 9271
          I search with "3.3v 1a to-252" and got about 70 results. I chose this one
          http://search.digikey.com/scripts/Dk...P1117D33GCT-ND
          but I'll let others like PlainBill who have more experience with these jellybean parts to confirm.
          If you look around your junk or old boards, you may see this voltage regulator. For example, a lot of old sound cards I have noticed have 3.3, 2.5, and 1.8V regulators.
          • retiredcaps
            • Apr 2010
            • 9271
            BTW, on some of your monitors, you are getting static, fluctuating voltages, changed voltages. Any chance your source is bad? Or is this just coincidence?
            Do you have a UPS? Do you have multiple devices plugged into these circuits?
            • torin3
              • Aug 2009
              • 178
              #26
              It started at 1.83V when I first turned it on, and is now up to 1.87V and the picture hasn't even started having problems yet.
              Edit: Seems to have stabilized at 1.87VDC. I'll check again when the diplay goes wonky.
              Edit2: It did go up to 1.88VDC before the display went wonky (about 3-4 minutes before). However when the display did go wonky, there was no additional voltage increase.
              Possibly. It is plugged into a UPS. Which runs my computer plus 2 monitors. It is a 1500VA unit. The additional monitor is also plugged in when testing them.
              • retiredcaps
                • Apr 2010
                • 9271
                #27
                My UPS math is non existant. For fun, try testing the bad monitors on its own circuit and see what happens.
                • retiredcaps
                  • Apr 2010
                  • 9271
                  #28
                  Odd, in the other thread, PlainBill says LDOs should be +/- 1%.
                  1.8 x 1.01 = 1.818
                  3.3 x 1.01 = 3.333
                  So are both regulator are out of spec? Or is this a symptom of something else?
                  • torin3
                    • Aug 2009
                    • 178
                    #29
                    It should handle a 750W load with ease.
                    1.8 x 1.01 = 1.818
                    3.3 x 1.01 = 3.333
                    Well, they aren't expensive units. I'll get a couple of each and replace them and then see where we are.
                      MSI Prestige P65 8RF-456NL Creator White Notebook P Specification for Upgrade or Repair
                      This specification for the MSI Prestige P65 8RF-456NL Creator White Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the P65 8RF-456NL Creator White boardview and P65 8RF-456NL Creator White schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                      09-06-2024, 07:46 AM
                      MSI Prestige P65 8RF-442 Creator White Notebook P Specification for Upgrade or Repair
                      This specification for the MSI Prestige P65 8RF-442 Creator White Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the P65 8RF-442 Creator White boardview and P65 8RF-442 Creator White schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any...
                      09-06-2024, 07:29 AM
                      MSI Prestige P65 8RF Creator White Notebook P Specification for Upgrade or Repair
                      This specification for the MSI Prestige P65 8RF Creator White Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the P65 8RF Creator White boardview and P65 8RF Creator White schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                      09-06-2024, 07:25 AM
                      MSI Prestige P65 8RF-457BE Creator White Notebook P Specification for Upgrade or Repair
                      This specification for the MSI Prestige P65 8RF-457BE Creator White Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the P65 8RF-457BE Creator White boardview and P65 8RF-457BE Creator White schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                      MSI Prestige P65 8RF-445ES Creator White Notebook P Specification for Upgrade or Repair
                      This specification for the MSI Prestige P65 8RF-445ES Creator White Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the P65 8RF-445ES Creator White boardview and P65 8RF-445ES Creator White schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
