Originally posted by retiredcaps
View Post
Sony SMD-HS73
Re: Sony SMD-HS73
Re: Sony SMD-HS73
Originally posted by torin3 View PostBut I'm not sure why you are telling me that FM would have lower ESR. I'm aware that relative to FC there are caps that would have lower or higher ESR specs in those can sizes.
Re: Sony SMD-HS73
Originally posted by retiredcaps View PostJust remember that if the equivalent FM caps are available, they have even lower ESR.
Since I've already replaced the caps with FC series caps I'm not planning on replacing them again unless they go bad. I don't know what brand/series were on there originally, so I can't say for certain that they are out of spec, but again, going by FC specs, they certainly seem to be going bad. Especially since 3 other caps, including at least 1 more 47uF cap all tested much lower.
Re: Sony SMD-HS73
Originally posted by torin3 View PostThe 10uf cap was at 15Ω, as opposed to the FC spec at 3Ω. The 47uf caps were at 6.2Ω & 7.3Ω compared to the FC spec at 1Ω.
Re: Sony SMD-HS73
Sorry I haven't been working on this one while I was waiting for my Blue ESR meter kit to arrive. I came in Monday and I put it together last night. I seem to have gotten it right the first time.
Anyway, I've been testing some of the caps I pulled off this board. It has been long enough that I'm not 100% sure of which through-hole caps were from this board, but for the logic board, it was the only one I removed SMD caps from. 3 of them seemed to be likely bad based off of the FC series data sheets. (I can't tell what brand, the only markings other than voltage and capacitance is what looks like 30I1 on the 47uF, and 3a on the 10uf cap, all 16v.)
I should be working more on this board over the weekend. I'll be trying to trace down possibly bad components on the board.
Re: Sony SMD-HS73
Originally posted by retiredcaps View PostWhat is the model number for Q3?
http://www.alldatasheet.com/datashee.../SSS6N70A.html
Originally posted by retiredcaps View PostSorry, one more. What is the part number for the diode that is providing the 12V rail? It will be one of the two that is mounted on the heatsink.
UD6340 STPS10 150 CT
http://www.alldatasheet.com/datashee...STPS10150.html
Re: Sony SMD-HS73
Re: Sony SMD-HS73
Originally posted by retiredcaps View PostJust out of curiousity, what is the part number for IC2 on the backside of the power board?
This looks like it should be right.
http://www.alldatasheet.com/datashee...1200D60R2.html
Re: Sony SMD-HS73
Re: Sony SMD-HS73
Originally posted by alexanna View PostWhat is the voltage on the enable pin #3 of oz960 when the back lights are on?
Al.
But the 1.17V reading was only when the light was off.
Re: Sony SMD-HS73
Originally posted by torin3 View PostVoltages at the on/off pin are the same as before at CN1.
Checking the Enable voltage from the oz960, I'm getting 1.17V for off, then frequent drops to about .5V.
Should I be looking between pin 3 for U1 and the on/off location at CN1 for possible bad components? .
Al.
Re: Sony SMD-HS73
Well, either I didn't remember correctly, or like mentioned, I might have a low battery, and it might be giving me screwy readings.
2.5V regulator is at 2.49V on both meters right now. 3.3V regulator is 3.36VDC.
And just to verify, I checked the 12V rail again. Up in the 17V range when peaking.
Oh, and while it is somewhat frustrating, and I probably should be up so late before staring to work on this particular monitor, I am finding this process fascinating, and I'm learing quite a bit. Thanks again for all the help.
Re: Sony SMD-HS73
Originally posted by torin3 View PostOk, I had a chance to remeasure this morning. I was reading the wrong leg. Between ground and Vout I'm get about (If I'm remembering right, I'll check again when I get home) about 2.63V. It is rock steady when on or off or the lamp coming on or off.
Checking the datasheet, if my memory is correct, the voltage looks a little high.
Re: Sony SMD-HS73
Originally posted by retiredcaps View PostBack in post #9, you measured the 5V rail as 5.05V DC stable and you measured the regulator as 2.48V
PlainBill says that the 5V rail is usually regulated.
So 1.01 (1%) x 5.0 = 5.05V.
1.01 (1%) x 2.5 = 2.525V
0.99 (-1%) x2.5 = 2.475V
So I think the multimeter that you used in post #9 is okay?
Something has changed since then to cause this higher voltage reading (17V and now 2.63V). We had one case a few days back where the battery in the multimeter was low and causing funny readings. You may want to try a fresh battery?
I'd expect it to be within 5%, but is often deliberately set high to compensate for drop through the conductors. 5.1V is very common.
PlainBill
Re: Sony SMD-HS73
Originally posted by torin3 View PostI wouldn't be surpised at all if it was my meter. I've got 2 cheapie meters, and I'll try with both of them when I get back home today.
Re: Sony SMD-HS73
Originally posted by PlainBill View PostIt is. The LDO regulators are usually specified as +- 1%. It's either the regulator or your meter.
PlainBill
I should probably get a better multimeter for when I need accuracy rather than continuity checks.
But it will have to wait until after I get my ESR meter kit.
Re: Sony SMD-HS73
PlainBill
Re: Sony SMD-HS73
Originally posted by retiredcaps View PostI'm a bit confused and it is almost 1am in the morning, but back in post #9, the regulators were identified as 1086D25 a 2.5V regulator and BA033 a 3.3V regulator. Where did 1.8 come from?
Re: Sony SMD-HS73
