Samsung Giga Sound MX-JS8000 not responding
  • andariego
    • Mar 2011
    • 20
    Hi, they have brought to my workshop 2 Samsung Giga Sound MXJS8000 devices, the problem in these devices is that they do not turn on completely, only the "WAIT" message appears on the screen and from there nothing happens, CD does not work, NO audio .
    The 2 devices have the same problem. Maybe someone has some information about this, I have tried to look for the service manual but I have not found it. I hope you can help me with this, thank you in advance.
  • andariego
    • Mar 2011
    • 20
    Re: Samsung Giga Sound MX-JS8000 not responding
    ok, just to add that I already checked the voltages in the power supply and everything is perfect, likewise on the main board everything is fine, I have noticed that this device on the motherboard has an integrated of the RL78G13 family, which while I warm it up a bit with an air gun, the device turns on, it works perfectly and I have all the functions at 100%, after the IC recovers the temperature it stops working.
    • andariego
      • Mar 2011
      • 20
      I was finally able to fix this unit.
      • AVC
        • Jan 2012
        Hey i have the same model, same issue. What did you do to it? I tested all voltages on the power supply and just cant find the issue. Im pulling my hair out.
        • King30
          • Jan 2022
          • Us
          I have the same problem with my js8000 pls help me how can i fix it,,i try downloading the file to update it and it did not work as well,,pls help me
          Last edited by SMDFlea; 01-31-2022, 05:07 AM. Reason: Removed personal email address
          • Amjad2000
            • Jan 2023
            • United Arab Emirates
            How did you fix it?
            • BuddahLocote
              • Jul 2023
              Can u please tell me how u fixed it?
                09-07-2024, 05:50 AM
              • jchang
                Samsung UN70NU6900F no picture and no sound
                by jchang
                Hi all
                I was just given a Samsung TV with the issue. I read various threads and videos and attempted the ribbon tape method to gain an image, but no luck.
                Symptom:
                No picture no sound.
                When I plug in the power cord, Backlight LED turns on for a half second and then turns off. The red LED next to the power button located center bottom flashes 2 or 3 times. When the power button is pressed after, it does the same thing.
                No sound at all.
                What I tried:
                1. I tried unplugging the left or right ribbon...
                01-09-2023, 06:28 PM
              • Ierwin
                by Ierwin
                05-13-2025, 03:31 PM
              • ChaosLegionnaire
                by ChaosLegionnaire
                09-13-2022, 09:02 AM
                09-06-2024, 11:40 PM
