Denon X5200W - No Video, No Audio and CAN NOT SET UP
  • MrBig9529
    • Aug 2015
    • 11
    • Singapore
    Hi Guys,
    I am trying to fix a Denon X5200 AVR with the following symptoms. Appreciate if you can help my by providing pointers to fix this.
    No Video output on the TV/Monitor
    No Audio on speakers and also in headphones, though I can hear the speaker relay clicks upon power up.
    Set up Function ( both on AVR and remote) doesn't respond. so can not do the configuration.
    Thanks,
  • madan1
    • Nov 2016
    • 726
    Re: Denon X5200W - No Video, No Audio and CAN NOT SET UP
    Greetings.
    Well, you can start with the standard things, but most likely the problem is in one ( or more ) of the chips on the HDMI board.
    The standard thing is to measure the low voltage rails. Then check if each chip/controller on the hdmi board gets its power supply.
    If you get good voltage readings everywhere, you can try tracing the audio signals through the board.
    If there are any BGA chips on the hdmi board you can try reflowing them.
    • Longbow
      • Jun 2011
      • 623
      Originally posted by madan1
      Greetings.
      You are saying that faults on the HDMI board can disable the menu system? The OP does not say which input he is using as a source. Need more specific info on that part.
      What does it mean if you have a "normal" display on the front panel, but no response to front panel buttons or to remote control?? I would say that the unit is in "child lock" mode. Just a guess.
      Is it plugged in?
      • madan1
        • Nov 2016
        • 726
        I have two personal examples - denon 2113 and onkyo tx nr609
        Both have "no video and no sound" issue.
        Onkyo have acknowledged the problem and blame faulty BGA chips.
        Denon officially have not acknowledged the issue, but many users have experienced it ( there is a topic about this here ).
        Both units appear to be fully functional - they switch on, the displays work fine, the menus are fine, only that they do not pass any sound from the inputs to the analog part ( the amplifiers ).
        The denon unit indeed has partial menu functionality - for instance it operates fine the network part ( successfully opens network radio streams and the network/usb DAC produces sound, but that sound then is not routed properly to the amplifier ), but cannot operate the tuner section, the output switching chip ( even though the display shows switching through the inputs ) and most likely the main DAC, the DSP processor, the HDMI switching and so on. The firmware version of the HDMI section also seem to be corrupted.
        People say that the denon problem is caused be deteriorating memory chips - the write/read processes are interrupted and eventually the firmware gets corrupted/unreadable which causes partial or total failure to operate.
        Of course this does not mean that the post owner's unit has the same problem. It is always best just to start with the simple things - factory reset, voltage readings, loose connection, etc.
        • Longbow
          • Jun 2011
          • 623
          You are saying that these two products are actually the same, or very nearly so? Just a different brand name on the front?
          Is it plugged in?
          • madan1
            • Nov 2016
            • 726
            Oh no, not the same.. they /that two units/ just share similar issue - premature chip deteriorating and/or bad BGA solder joints.
            Well, at least the board designs are different, the analog parts also. Still, they use third party cpu, memory, dps, video processing, hdmi/audio switching, dac/adc chips and it is not uncommon to see the same chips in one generation similar price range receivers..... so probably yes.. it could be said that the hardware inside the metal boxes is the same.
            • samson7point1@yahoo.com
              Help troubleshooting an audio problem with an RCA SGT-250 CED Player
              by samson7point1@yahoo.com
              The Problem: This player has a toggle switch to select between Stereo, Mono R, and Mono L. Regardless of the setting it outputs the sound to both the L&R audio jacks. In the Mono R position, the audio output level is normal (from both the L and R audio output jacks), in the Stereo position the audio output is about half the volume, and in Mono L, it's about 3/4 the volume. Something about putting it into Stereo mode is causing the volume to drop significantly and I can't figure it out.
              The player processes the audio signal using two different reference frequencies. The "R"...
              04-30-2024, 11:22 AM
            • hemant_2222
              Schematic for Denon Remote Control RC1156
              by hemant_2222
              Hello Everyone,
              Hope everyone is enjoying their repairs at hand!.
              I am looking forward to get the schematic of Denon remote control RC1156. Actually long time no use of the remote leaked the battery thereby corroding few parts as well as the tracks.
              I was able to join few of them but the remote is still not working, so i am looking forward for your help, in case anyone understand the schematic or the remote circuit diagram and could me assist me in repairing it.
              Please refer to the attached picture, i think the voltage divider is missing...
              10-06-2023, 02:05 AM
            • kotel studios
              Lantec PULSE 386 subwoofer - no audio output
              by kotel studios
              Hi
              I have this Lantec PULSE 386 subwoofer I got a while back laying around awating repair for quite some time. Sadly it's missing it's original speakers which it came with.
              After plugging in the mains, the LED on the volume controller lights up. When I plug in the 3.5" jack cable to my soundcard (confirmed to work), I get no audio on the subwoofer (nor the speaker jack at the back).
              The PCB is quite simple. There is a UTC4558 amp and two D6282 audio amps. When I put my finger on the UTC4558 I can see and hear the speaker "fart". Although, the left...
              11-29-2025, 04:15 AM
              HP Compaq dc7700p Intel Core2 Duo Processor E6300 2x512M/80G DVD-ROM WXP Pro Small Form Factor PC E6300 Specification for Upgrade or Repair
              This specification for the HP Compaq dc7700p Intel Core2 Duo Processor E6300 2x512M/80G DVD-ROM WXP Pro Small Form Factor PC can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Compaq dc7700p Intel Core2 Duo Processor E6300 2x512M/80G DVD-ROM WXP Pro Small Form Factor PC boardview and Compaq dc7700p Intel Core2 Duo Processor E6300 2x512M/80G DVD-ROM WXP Pro Small Form Factor PC schematic. Our users have donated over 1 million documents which are being added to the site. This page will...
              09-12-2024, 03:36 PM
            • SolarFlare
              Mi TV 4 Pro-Samsung Panel LSC550FN20 - Video problem, backlight and Audio works fine.
              by SolarFlare
              My barely 3 year old TV has stopped displaying video, although the video output comes for a few seconds after turning ON which displays the manufacturers logo then shows the home screen (all this with some blue flicker) then the video goes blank and the screen is dark blue with the backlight on. The audio output works perfectly and the TV also takes in voice commands(smart TV).
              The TCON board has the following Chips -
              Samsung VTU63A0
              RT6939 - 2nos.
              and all these chips are getting real hot within a minute, I dont know if this is normal....
              06-26-2022, 08:58 AM
