Need help finding flash rom for Fujitsu SOUNDSYSTEM DS P2100 Tube
  • badrianiulian
    • Apr 2012
    • 43
    Hy
    I got a friend that has a "Fujitsu SOUNDSYSTEM DS P2100 Tube"
    The main IC that controlls just about everithing is dead. It is a AT89C2051-24SU.
    I removed it from the circuit, added a couple of 0 value resistors on the volume IC (that was controlled through I2C protocol by the main IC) and now the hole system sounds like crap ... just a regular high pass in the two small speakers and a low pass in the subwoofer ... no surround
    So I was hoping that someone had a firmware for the thing so I can program another AT89C2051-24SU
  • davidebaldini
    Fujitsu E19W-5 quick white flash when plugged to AC then no life
    by davidebaldini
    Symptom: my Fujitsu E19W-5 emits a white flash from the CCFL lamps for a split second after being plugged to AC, then it behaves as if unplugged from mains: no backlight, no image on the LCD, no LED light on the front bezel; it remains in this status indefinitely. Re-pugging the AC cable repeats the behavior.
    I have fixed it by replacing the four capacitors on the power supply circled in the photo. It is functional without defects now. This PCB seems identical to the Fujitsu E19-5 that was discussed here for the same symptoms, for which replacing C910 alone was sufficient....
    10-24-2024, 04:13 PM
  • ekozeko333
    by ekozeko333
    🧠 What I’ve Done So Far
    Flashed...
    06-21-2025, 02:48 AM
    Fujitsu LIFEBOOK LIFEBOOK U7511 Notebook U Specification for Upgrade or Repair
    This specification for the Fujitsu LIFEBOOK LIFEBOOK U7511 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the LIFEBOOK U7511 boardview and LIFEBOOK U7511 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
    09-07-2024, 03:40 AM
    Fujitsu LIFEBOOK LIFEBOOK U7411 Notebook U Specification for Upgrade or Repair
    This specification for the Fujitsu LIFEBOOK LIFEBOOK U7411 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the LIFEBOOK U7411 boardview and LIFEBOOK U7411 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
