TC Electronic Studio Konnekt 48 revival
  • Khron
    • Sep 2006
    • 1350
    • Finland
    #61
    Re: TC Electronic Studio Konnekt 48 revival
    Well, all of these readings were supposed to be taken while OFF...
    Khron's Cave - Electronics - Audio - Teardowns - Mods - Repairs - Projects - Music - Rants - Shenanigans
    • solozabal
      • Apr 2016
      • 27
      • Croatia
      #62
      Sorry for that, i'm not so good with this but always wanted to learn more about it..
      Without 220v cable connected, there are 45mV on both spots, so I suppose that's good..
      • Khron
        • Sep 2006
        • 1350
        • Finland
        #63
        That's a bit TOO low, actually... I would've expected at least something like 300mV (a Schottky diode forward-voltage drop), or closer to 5-600mV (a standard silicon diode/junction drop).
        It might be worth removing L68, for starters, and see if the 3.3v rail is still low.
        • solozabal
          • Apr 2016
          • 27
          • Croatia
          #64
          I've removed L68 and voltage jump to 1.42V..., one interesting thing while measuring voltage with digital multimeter was that first it shows 3.3V for half of second than steady 1.42V... Don't know why is acting like that.
          Dice II chip and two Schottky diode are still going extremely hot after switch ON...
          • solozabal
            • Apr 2016
            • 27
            • Croatia
            #65
            I've removed and tested this smd element tagged in attach, which is directly connected to C489. It's marked with code RL A, but I didn't found anything abot it on google.. I suppose it's voltage regulator or something similar.
            Diode test; in one direction 0.64v and 0.61v, and in other OL and 0.8v, so that's not good... am I right?
            • Khron
              • Sep 2006
              • 1350
              • Finland
              #66
              That's connected to the GROUND leg of C489 (since the + of the cap is definitely connected to the band-end of that rectifier diode ). And with all those resistors and caps next to it, it's a safe bet it's actually the TL431 (or variant) that's part of the feedback - D74 on the schematic.
              • solozabal
                • Apr 2016
                • 27
                • Croatia
                #67
                Ok, I'm still trying to find culprit for dropped voltage, so I removed R486, R504 and raised up two first legs of IC46 to disconnect this 3V3 part of the board... but to no avail..
                L68 is still outside of the board, so what's left to test now... I've already tested two schootky diodes and they are ok (forward voltage 0.147v, reverse was OL), C489 and C488 were changed with Rubycons, so I suppose we can trust them. Only thing left is L64 but what can be bad about it... Or TR5, but how to test it, I think I will need oscilloscope to see what's happening there.
                • Khron
                  • Sep 2006
                  • 1350
                  • Finland
                  #68
                  Removing R486 (and thus disconnecting the feedback) most definitely could NOT have helped. Although, to be perfectly honest, i'm not 100% sure if the feedback-less voltage would've (normally) went up, or down...
                  What you could do, in this case, is reconnect all the components you've removed. Before soldering back L64, measure its DC resistance (expect a few milliohms). Or actually, if you have something like a 1 ohm resistor to solder in series with L64, that would be great - then, you can use that as a current shunt. The voltage across that series 1 ohm will be directly proportional with the current going through that (1V/A).
                  On the other hand, i guess we (still) can't be sure what would be a normal current draw to expect...
                  • solozabal
                    • Apr 2016
                    • 27
                    • Croatia
                    #69
                    When I had removed L64, and turn power ON, after few seconds C489 has bulged and trow out liquid, huh..no more YXF Rubycons to swap... I suppose that's happened because of high voltage on it...
                    I think it was around 20v.. but I'm not really sure cause I've quickly turned device OFF when I've noticed something's burning on other side..
                    I've changed bulged cap with MBZ one, and reconnected all the components, so everything's in its place now, but we have same situation like before (1.4v instead 3.3v)...
                    When C489 is not connected to the board, there is not voltage there... two schootky diodes SS24 and Dice II chip are not heating only in that case.
                    It seems like C489 cap is really important element in 3v3 rail..
                    • Khron
                      • Sep 2006
                      • 1350
                      • Finland
                      #70
                      Well, there you go - did you really expect anything good to happen, with the feedback disconnected?
                      • solozabal
                        • Apr 2016
                        • 27
                        • Croatia
                        #71
                        It was happened after I've reconnected back all the feedback components on the board, except D74 and L68... my mistake... I don't have 1 ohm resistor to test current, it would be interesting to see what's happening there..
                        But I don't understand why there is no voltage on 3.3 rail when C489 is out of the board? And is it safe to take out L64, when all components were connected..?
                        • Khron
                          • Sep 2006
                          • 1350
                          • Finland
                          #72
                          *sigh* D74 is a crucial part of the feedback circuit, which limits the duty-cycle of the switching transistor, which in turn keeps the voltage from going too high. With that missing, your YXF cap blew up.
                          You can see the schematic, right? What do you think might happen with L64 missing? See where R486 is connected?
                          • solozabal
                            • Apr 2016
                            • 27
                            • Croatia
                            #73
                            Yes, I understand now, sorry for the dumb questions, but like I said I'm not so good at reading schematics...
                            I've believed that something in that circuit was wrong so I've tried to randomly pull components in hope of finding root of the problem.. obviously in wrong way..
                            • Khron
                              • Sep 2006
                              • 1350
                              • Finland
                              #74
                              Weeeeeell, the "randomly" part is where you went the wrong way, unfortunately
                              But in this case, you can only hope you didn't toast the Dice chip (or anything else), when the feedbackless 3.3v went as high as to blow that cap...
                              • solozabal
                                • Apr 2016
                                • 27
                                • Croatia
                                #75
                                I think I got lucky When that have happened, L68 was also out of the board so high voltage didn't go further...
                                Any idea what else might be smart to do test on?
                                • Khron
                                  • Sep 2006
                                  • 1350
                                  • Finland
                                  #76
                                  It would be pretty great if you had two adjustable / lab power supplies, to "replace" what comes out of TR5. 3.3v for the whole digital side, and a 5v to supply the buck converter that supplies the firewire chip (which provides the main clock to the Dice).
                                  • solozabal
                                    • Apr 2016
                                    • 27
                                    • Croatia
                                    #77
                                    Can I use PC power supply for this purpose..? It has all the combinations of voltages I need for this test.
                                    • Khron
                                      • Sep 2006
                                      • 1350
                                      • Finland
                                      #78
                                      I suppose you could, although i'm not sure how important the isolation of the firewire chip's supply is. And "of course", unless you use some ammeters, you can't really monitor the current consumption on each rail
                                      • solozabal
                                        • Apr 2016
                                        • 27
                                        • Croatia
                                        #79
                                        Ok, thanks. I would try to do a 3.3v rail test first, because I think that is a root of the trouble..
                                        I already have 1.3/1.4V there, so I will need to take off TR5 before applying 3.3V from power supply..
                                        But with C489 disconnected, I have clear situation because there is no voltage there. So I just need to connect external 3.3v between TP672 and DGND... and hope for the best
                                        • Khron
                                          • Sep 2006
                                          • 1350
                                          • Finland
                                          #80
                                          I'd rather suggest you remove L65 (on the primary of TR5) as well as L64 (or D103) and D81.
                                            HP ZBook Studio G4 + DreamColor Z27x Studio Display Mobile workstation Studio Specification for Upgrade or Repair
                                            This specification for the HP ZBook Studio G4 + DreamColor Z27x Studio Display Mobile workstation can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Studio G4 + DreamColor Z27x Studio Display boardview and Studio G4 + DreamColor Z27x Studio Display schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps...
                                            09-06-2024, 06:00 AM
                                            MSI Creator Z16HX STUDIO B13VFTO-053 Notebook Z16 HX Studio Specification for Upgrade or Repair
                                            This specification for the MSI Creator Z16HX STUDIO B13VFTO-053 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Z16HX STUDIO B13VFTO-053 boardview and Z16HX STUDIO B13VFTO-053 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                            09-07-2024, 06:38 AM
                                            MSI Creator Z16 HX STUDIO B13VGTO-052 Notebook Z16 HX Studio Specification for Upgrade or Repair
                                            This specification for the MSI Creator Z16 HX STUDIO B13VGTO-052 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Z16 HX STUDIO B13VGTO-052 boardview and Z16 HX STUDIO B13VGTO-052 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any...
                                            MSI Creator Z16 HX STUDIO B13VGTO-051 Notebook Z16 HX Studio Specification for Upgrade or Repair
                                            This specification for the MSI Creator Z16 HX STUDIO B13VGTO-051 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Z16 HX STUDIO B13VGTO-051 boardview and Z16 HX STUDIO B13VGTO-051 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any...
                                            HP ZBook Studio Studio G5 Mobile workstation Specification for Upgrade or Repair
                                            This specification for the HP ZBook Studio Studio G5 Mobile workstation can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Studio G5 boardview and Studio G5 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                            09-06-2024, 08:23 AM
