Hi fellow members. Happy 2025. I have some SMD carbon resistors to replace on the Filter board but I don't know the package size to order. Anyone have any resistor replacement experience with this Yamaha small PA system? Thanks!
Yamaha Stagepas 300
by DAVEMAC02I have a Yamaha Stagepas 300 PA system with the left channel out. There are separate power inputs to each Power Amplifier. I repaired the left channel amplifier so both work. However, I still have no left channel output to speaker. Both speakers are good. I have a multimeter and an old Radio Shack signal tracer for troubleshooting and that's it. I checked all voltage inputs to both amps and they match. Don't know how to proceed to check or trace signals or voltages at amp outputs BEFORE they go to speakers. Any help appreciated. Thanks in advance, Dave
This specification for the ASUS ROG G512LI-HAPPY Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the G512LI-HAPPY boardview and G512LI-HAPPY schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for...09-06-2024, 11:40 PM
Help Needed: Yamaha RX-V485 Network Issue After Firmware Update (WN9711 Error)
I'm facing an issue with my Yamaha RX-V485 receiver. During a firmware update, the process failed, and now the USB, Bluetooth, and network functionalities are not working. Occasionally, the receiver displays the error code WN9711.
I came across Yamaha Technical Bulletin No. 0103, which describes a similar issue for models like the RX-V4A, RX-V6A, and RX-A2A. According to the bulletin, the issue can be resolved by shorting soldering points (e.g., J260 for RX-V4A or...-
I'm having trouble with my Yamaha RX-V485 receiver. After encountering a "version error", the USB, Bluetooth, and network functions have stopped working, making it impossible to perform a firmware update through normal methods.
After doing some research on forums, I found that earlier Yamaha models with similar issues (like the internal error message) could be fixed by shorting or soldering specific pads—such as R896—and then powering on the unit to enter a service/boot mode that displays the model info and allows recovery.
I managed to find the service... -
by jjneI have an old Yamaha RX V675 receiver which is starting to develop issues with the sound, although it doesn't quite match up with what folk normally report with these.
From cold, the sound cuts in and out. When this happens the amp is losing sync with the optical input (speaker graphic disappears from the front panel). But this is not resolved by putting the unit into pure direct mode. After a couple of minutes this resolves, although there are occasional clicks from the speakers after that.
At first I thought it was either a speaker relay or the DSP, but I don't think...-
- Loading...
