Teac audio receiver shutting off intermittently
  • xav_dude
    • Dec 2013
    • 12
    I have a TEAC AG-V8520 that works intermittently. When everything works fine and the receiver is turned off, the standby light is on, ready to be turned on. If I turn it on, main display goes on, standby light goes off and I can listen to music.
    What happens is that at any moment, receiver will completely shut off whether on standby or while turned on listening to music. The standby light will disappear, so will the main display. Pressing the power button won't change anything nor unplugging the AC cord. It'll stay in this state for half a second or for hours literally, come back for a few seconds or minutes or hours then goes off again, this is totally erratic.
    I was suspecting some kind of protect mode going on but measuring voltage at the Protect pin on the main board never showed any voltage when the receiver shuts off. I tried comparing voltage at different spots when problem happens and when it works fine but this is too complex for me.
    I'm uploading the "service manual" for a TEAC AG-V8060 that seems to share the exact same configuration as my 8520. Hope someone can help me pinpoint the issue!
  • retiredcaps
    • Apr 2010
    • 9271
    Re: Teac audio receiver shutting off intermittently
    I have never worked on any audio equipment, but I do watch MaxxArcade's youtube channel. He is also a member here on badcaps.
    On his channel, he does a lot of audio equipment repair and invariably a lot of the equipment has poor solder joints. You may have the same?
    http://www.youtube.com/user/Maxxarcade/videos
    --- begin sig file ---
    --- end sig file ---
    • rievax_60
      • May 2012
      • 897
      • australia
      Have you checked the ST-BY 5.6v on page 16?
      • xav_dude
        • Dec 2013
        • 12
        I checked the "+5.6V" pin located between the GND and F MUTE pins, is that the one you're referring to? If yes, there's constant 5.6V with or without the problem occuring.
        • rievax_60
          • May 2012
          • 897
          • australia
          Its difficult to make sense of the circuitry on the front panel because of the number of option circuits in the dotted lines.
          See if you can check for any change of state of pin 33 Reset, pin 26 Back-up, pin 1 Vdd
          on IC 81. Be careful to not short any pins together, some have -30v on them for the display.
          Look for corrosion caused by possible leaking capacitors. Backup capacitors like to leak although Im not certain where it is.
          • xav_dude
            • Dec 2013
            • 12
            pin 1 and pin 26 are always 4.74V and 4.47V respectively no matter what. When the receiver is not working, pin 33 is 0.08V and when working (standby light on) 4.30V.
            I also noticed that pin F MUTE on main board (the one beside +5.6V you asked me to check) has 4,63V when working and 0V when problem occurs. Not sure if that means anything.
            I'm not seeing any signs of corrosion or capacitors leak otherwise. It's pretty clean inside, no dust as well.
            • xav_dude
              • Dec 2013
              • 12
              So it seems that the system is going into reset mode. If I understand correctly, the reset path should have constant 4ish Volts. When issue occurs or if I press the reset button on the Tuner board, voltage drops along the path. I guess it's now all about finding the component that stops sending the 4V, is my thinking right?
              • rievax_60
                • May 2012
                • 897
                • australia
                Yes. Also 4.74v/4.47v seems too low.
                Usually when there is a 5.6v rail, it gets dropped to 5v after it passes through a diode on its way to the microcontroller.
                • xav_dude
                  • Dec 2013
                  • 12
                  I've noticed that resistor R837 (100K) on the Front board gets the 4.7V but only 0.08V gets out of it. When the system works, it outputs about 4.5V.
                  I was thinking this was the problem but if I press the reset button manually on the tuner board while the standby light is on, that resistor voltage output drops to zero as well which makes me think this is the common behavior when the reset path is broken... I'm a little confused now
                  Edit: The Back Up optional circuit in dotted lines is not my system.
                  • rievax_60
                    • May 2012
                    • 897
                    • australia
                    If Q823 is being turned on during the problem, try to find the reason.
                    • rievax_60
                      • May 2012
                      • 897
                      • australia
                      This is the type of problem that is likely to disappear when the faulty part is disturbed.
                      • xav_dude
                        • Dec 2013
                        • 12
                        Q823 is part of an optional circuit that is not on the board, should I be checking Q811 instead?
                        • rievax_60
                          • May 2012
                          • 897
                          • australia
                          Q811 provides power fail detection. Its collector should always be high.
                          What provides reset to the micro?
                          • xav_dude
                            • Dec 2013
                            • 12
                            You lost me with "What provides reset to the micro?"
                            • rievax_60
                              • May 2012
                              • 897
                              • australia
                              I cant properly follow the schematic because of the options that may or may not be present. Can you tell me which components the reset signal comes from?
                              • rievax_60
                                • May 2012
                                • 897
                                • australia
                                You said before that the Back Up Option is missing so that only leaves R837 and C806 in the reset circuit. You need to find what is causing the reset voltage to sometimes be shorted to ground. The capacitor could be faulty.
                                Try disconnecting the path to the tuner PCB.
                                • xav_dude
                                  • Dec 2013
                                  • 12
                                  I disconnected one of the front board connector going to the tuner board, the one carrying the reset wire (CN18) and instantly the standby light went on. Reconnecting it makes the issue happen again. Does that mean the reset switch is faulty? I'm not sure how this component works, it seems to let current through but it's not part of any circuit loop, that reset switch seems to be on a dead end. Unless its function is to go to ground only which would prevent the current from flowing all along the system when reset button is pressed?
                                  • rievax_60
                                    • May 2012
                                    • 897
                                    • australia
                                    It looks like a simple normally open press switch. You will need to have a close look. The only possibility I can think of is that the switch is growing tin whiskers. Try cleaning the switch with a toothbrush.
                                    • xav_dude
                                      • Dec 2013
                                      • 12
                                      Is there a way I could test bypassing the switch by going straight to the ground of the circuit board?
                                      • rievax_60
                                        • May 2012
                                        • 897
                                        • australia
                                        No, the switch is a normally open type.
                                        • tvguy12012012120
                                          by tvguy12012012120
                                          02-07-2025, 05:13 PM
                                        • fharris1977
                                          Vizio D50u-D1 Dead Set No Standby
                                          by fharris1977
                                          Hi. I got a Vizio with no power or standby, and won't turn on with remote or button. I checked the voltages on the connector and all read 0.00V or nearly 0(0.050 ON/OFF pin). None of the pins are labeled STB for standby although I do see some 5V pins. Other than the obvious standby led, which isn't coming on, is there a way to check for standby voltage on this PS. I'm trying to see if my problem is the PS or mainboard. Some Vizios I have fixed with no standby led me to think it was the PS but it turned out being the mainboard. Any experience with this set would be greatly appreciated.
                                          12-28-2023, 10:25 AM
                                        • Crystaleyes
                                          Samsung BN44-00259A standby question
                                          by Crystaleyes
                                          Hi all.
                                          I started a thread while back regarding TV power supply standby circuitry as it is something I am not quite on top of.
                                          SMPS theory and function is becoming more familiar, however the standby part is still a bit of a mystery.
                                          Anyway, a friend has this TV with the above mentioned power supply board which has no standby voltage, nor any other voltages leaving the board.
                                          The mains AC comes in fine, gets filtered and rectified with power is on the main filter cap as well as the transformer and drain pins of the ICE3B0665J, but that's it.
                                          08-11-2023, 05:15 AM
                                        • Maniackk
                                          Yoga 530-14ARR NM-B781 Ryzen 3 2200 – overheating and shutting down under load
                                          by Maniackk
                                          I’ve got a stubborn patient here. The laptop powers on and works, all components like the screen, keyboard, touchpad, etc. are functional. The issue is that it heats up very quickly under load (within a few minutes up to 95°C) and then shuts down shortly after. Subsequent attempts to turn it back on right after a “hot shutdown” result in it shutting off within a few seconds. Interestingly, if I enter the BIOS, it can stay there for 2 days without shutting down (most likely due to low CPU load and low temperatures).
                                          The cooling system has been cleaned, thermal...
                                          09-03-2025, 09:32 AM
                                        • CDNBrewer
                                          Running out of Ideas, hoping someone smart can provide some for my ONKYO TX-SR353 Receiver
                                          by CDNBrewer
                                          Hello Everyone,
                                          I have an Onkyo TX-SR353 Audio/Video Receiver (5.1 ch with HDMI) that I am having a really hard time diagnosing and I'm about to throw this in the junk and go buy a new unit that is on sale until the 7th.
                                          Symptoms:
                                          • Intermittent (part of the reason why i'm having a hard time isolating problem), sometimes will work for 10+h at a time without issue
                                          • Original symptom was wife reported loud banging noise (like someone was banging on the wall with their fists) from the LEFT SURROUND speaker and then the unit shut off.
                                          • I swapped the Left and Right surround
                                          08-05-2025, 09:29 PM
