So until I see how you have connected it I cannot advise further.
I don't think that connection is reliable enough. Can you try with a piece of wire connected to the screw terminal and the hook probe connected to the other end of the wire?
I have just tried at work the same setup and it shows a nice sine wave.
I have to check out again my home setup, what is wrong there.
Yesterday, I have measured some of the transistors, basically comparing the ,measurements between channels and I have noticed some discrepancies.
I guess I still have some bad component there.
At of the A1360Y at he collector I have 0V and at the other channel, I have 1.1xxV.
Basically we need to get a view of how the waveform is distorted so we can figure out where the problem may be.
OK, after fiddling with the scope for a while(I don't know why I have to play with it?), I have managed to see a sine wave.
I don't have the option to save it in Bit file, only wfm and I can't attach those type of files here.
I'll have to take pictures.
You need to select BMP format (Storage Button > Storage > Bit map) then press External to save. The WFM file is just raw data (X,Y coordinates to plot.) BMP is exactly what is on LCD.
I have installed a software called Ultra Sigma and that software will let me to print the screen, but I couldn't find the location where has saved the file.
I will look into it more later on today.
Then press STORAGE on side menu to select the type used, select Bit Map.
Then press External and New File.
But if you can't figure it out just take photos of the screen.
Finally I have managed to save them.
First one, is the good channel, second one is the bad channel with the same settings and the third one is still the bad channel, but I made it much more viewable.
So, you said it sounded distorted. With a speaker connected to the output, you would say the output is very quiet, almost not there?
Yes, I have to be very close to the speakers.
Today, I was measuring with the Ohm meter all the resistors and one of the 22K was showing 0.6 Ohm, but when I have removed the board, it was showing a correct value.
How is that possible?
I went through all the parts on that channel and I didn't find anything bad.
To measure voltages it's very hard, because on top of the amp is the HDMI board.
Where was the 22k? Can you highlight it in circuit?
