Re: Vox mini 3 amp
I did start to go through the sample process but they wanted me to fill in some extra forms and explain what my business was, why I wanted them, etc. I gave up at that point
Mouser/Digikey worked out very expensive with shipping, thankfully I found a seller on Aliexpress so I've bought 10 at half the price of 3! I went for the 3.2Watt version in the end.
There's a square section of solder under the chip on the reverse side of the board (for heat sinking I guess?), I pre-heated it with a soldering iron for a moment then flipped it over and used my cheap hot air station to finish it off, that seemed to work well and all the pads survived, nothing was scorched or melted.
Fitting might be a bit harder, times like this I wish I had a scope. I'll probably add some more solder to the pad underneath to give it a bit more meat to soak heat into during operation.
Thanks for sharing your experience midibob, I'm grateful
Originally posted by midibob
View Post
