Cap suggestion please help!
  • mad55
    • Aug 2011
    And now for something completely different...
    I am rebuilding some speaker crossovers for some vintage ADS speakers and am wondering if anyone can track down the specs of the original caps, I believe they are both non polarized..
    1) Nippon-chemicon Ce02P BP 100v33uf
    2)Nippon- chemicon Ce04P BP 100v130uf
    Anyways, I am terrified that the sound will change if I choose an unsuitable cap... I want to keep the specs as close to original as possible...and I've heard the ESR rating affects the sound. I appreciate any advice or guidance,
    Thanks in advance,
    Mike
  • PCBONEZ
    Grumpy Old Fart
    • Aug 2005
    • 10661
    Re: Cap suggestion please help!
    In most all brands 'BP' indicates Bi-Polar [not polarized].
    If so, the caps won't be marked for plus and minus. [No side stripe. No + or - symbols.]
    If that's what they are the replacement series from Chemicon are:
    SME-BP [85°C]
    KME-BP [105°C]
    Mann-Made Global Warming.
    - Dr Seuss
    • PCBONEZ
      Grumpy Old Fart
      • Aug 2005
      • 10661
      Appears to be the case.
      http://www.wellgainelectronics.com/n...0vce02pbp.aspx
      - Dr Seuss
      • romansroad
        • 123
        Originally posted by mad55
        I am rebuilding some speaker crossovers for some vintage ADS speakers ....
        Mike
        I was wondering what happened to initiate the rebuild? ADS's are great, with robust crossovers and rubber surrounds, so was there an issue with overdriving them?
        • japlytic
          • Oct 2005
          • 2086
          Not all bipolar/non-polarised capacitors are created equal.
          Some are only designed for small signal applications, or horizontal deflection applications, or speaker crossover applications.
          • Longbow
            • Jun 2011
            • 623
            If there is no evidence that the original caps are bad, why change them? You will not get "better" performance unless the originals are leaking or lost their value. There's no magic here and nothing to be terrified about. It is much more likely that your drivers need attention - have a look at the surrounds.
            Is it plugged in?
            • chth96
              by chth96
              06-02-2024, 07:31 PM
            • eryjus
              by eryjus
              05-10-2023, 11:21 AM
            • bulkchart32
              i think i accidently ordered non-polarized 10uf caps for my original xbox. will this cause a problem?
              by bulkchart32
              i ordered a lot of caps from digikey to repair my xboxs. one thing i ordered was 50NXA10MEFC5X11-ND caps and i think they are not polarized. will this cause any kind of a problem? i really don't want to order new caps just because of this.
              06-16-2025, 03:09 AM
            • badcap111
              How to read inductor specs?
              by badcap111
              I have a broken samsung galaxy s10 with missing inductor. I want to replace the missing inductor and I have found some vendors. But I don't understand how to read the specifications of the inductor. The specs are:
              INDUCTOR-SMD;470NH,20%,2520,T0.8,0.029OH
              I understand that the inductor is 470 nH with 20% margin, and the size is 2520 or 1008 (imperial measure), but what do T0.8,0.0290OH mean? I can't find any explanation on the web.
              09-12-2023, 01:25 PM
            • badcappo
              Unknown diode specs V6 18
              by badcappo
              Hi there, looking for a compatible replacement for a diode type labelled "V6 18" from a dead Panasonic plasma TV power source. Possibly a V6 600 volts diode as seen here: https://electronics.stackexchange.co...nt-diode-v6-88 ?
              Thank you ...
              03-09-2025, 07:13 AM
