Hi, i have a hotair station LK852D-2 , and the problem is about the air flow is little and hardly to getout any air flow from it, i unfurtanitly replaced the potinmeter 500k ohm with new one, but it never solved the problem, and then i unsoldered from the board as you can see in the attached photo, and that make Some parts of the circuit diagram been damaged, and I need someone who has the same circuit diagram to provide me same photo of the diagram, especially the place where the 500 kΩ potentiometer switch is located( the place of 500k ohm potentiometer is indicated it with red arrow in the attached photo). is there any solution to the low air flow problem? What is the reason for that? Thanks in advance.
problem with hotair station LK852D-2
by khaledmusHi, i have a hotair station LK852D-2 , and the problem is about the air flow is little and hardly to getout any air flow from it, i unfurtanitly replaced the potinmeter 500k ohm with new one, but it never solved the problem, and then i unsoldered from the board as you can see in the attached photo, and that make Some parts of the circuit diagram been damaged, and I need someone who has the same circuit diagram to provide me same photo of the diagram, especially the place where the 500 kΩ potentiometer switch is located( the place of 500k ohm potentiometer is indicated it with red arrow in the...
This specification for the ASUS ROG FLOW-X13-GV301RE-007W Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the FLOW-X13-GV301RE-007W boardview and FLOW-X13-GV301RE-007W schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...09-07-2024, 06:40 AM
by theone111I have an LG Plasma TV 60PM6700 for the past ~12 years.
In the last ~3-4 months I have been having some issues.- Problem: It started with random picture disappearing (sound still worked).
Solution: Had to turn off TV wait a few seconds before turning it on again. - Problem: Then it got worse and the TV started to shut down and when turning on the no picture just sound.
Solution: Had to turn off TV wait about 10-20 seconds and turn it on again to solve. - Problem: TV shuts down
1 Photo - Problem: It started with random picture disappearing (sound still worked).
by Zeonalbastai have a problem with thinkpad X1 carbon gen 2 "LMQ-1MB 12298-2 48.4LY26.021"
The laptop was turned off because the MOSFET was not transmitting voltage. After checking it turned out that the gate pin on the MOSFET was the problem, because it was producing an inappropriate voltage. and it was discovered that the problem was with the Think engine, so I decided to reprint each pin, and finally the mosfet could work properly. However, there is another problem, even though the voltage has been supplied to the laptop, it still won't turn on, there isn't even an LED indicator. After double... - Loading...
