Inrush current limiter component (what is this thing called ?)
  • Dannyx
    CertifiedAxhole
    • Aug 2016
    • 3912
    Having repaired many power supplies lately, I've come once or twice across a component which, to my shame, I cannot figure out what it's called. I don't have a picture of it on hand sadly (maybe someone can post one), but it looks like a regular glass fuse (only a bit smaller), with two electrodes at each end and this thing makes a spark inside that glass envelope when you first plug the supply in. I know what its general purpose is: it's an inrush current limiter (or at least I think so). It's placed in parallel with the AC input, so I'm assuming it's like a spark gap: it takes away the initial surge and dissipates it in the form of a spark, which, because it's inside a vacuum tube, can't really do anything to "nasty". It's actually pretty satisfying to see that spark forming whenever I plugged the thing in.
    Funny story: when I first came across one of these, I was dealing with a faulty inverter on an LG monitor and as I was constantly plugging the supply in and out, taking measurements, until I saw this spark coming from near the AC inlet, so you can imagine I nearly soiled myself The supply was still ok, so that's when it clicked "OOOOOOH, I see what this thing does"
    I think it was labeled RA or RS on the board, though I can't figure out what it stands for (Rush arrestor/suppressor ?) It's definitely not an NTC thermistor - it can't be, since it doesn't look the part. Can anyone provide some more info ? No real reason, other than to enrich my knowledge
    Wattevah...
    • 31255
    Re: Inrush current limiter component (what is this thing called ?)
    the glass thing is a spark gap to suppress spikes,
    it's not a surge suppressor / inrush limiter.those look a bit like a large ceramic capacitor with a rough finish - usually dark green or black.
    and they connect inline like a fuse.
    • Dannyx
      CertifiedAxhole
      • Aug 2016
      • 3912
      Ok, so I was partly right. So when I search for those should I look for "spark gaps", or are they called something else ? To me, spark gaps are those zig-zagged traces placed close together Also, yeah I know about the NTC thermistors
      Wattevah...
        • 31255
        the zig-zag / forks are cheap attempts to avoid fitting real spark-gap devices.
        the difference is the tracks will leave carbon burns and need to be fixed afterwards - the glass ones work in a sealed space and dont need to be replaced!
        • Dannyx
          CertifiedAxhole
          • Aug 2016
          • 3912
          Oh wow, so I was wrong about that little sh!t LG monitor - it was actually built pretty well then, with a bit of quality, considering they bothered to add such a component at all
          Wattevah...
          • PeteS in CA
            • Aug 2005
            • 3582
            • USA, Unsure of Planet
            They're also called gas discharge tube, as they have a gas inside that controls the trigger voltage and forms a plasma path for the discharge.
            I'm sure I've given this summary on BCN before, but here are the three common voltage surge suppression devices:
            * Gas discharge tube - relatively slow but able to absorb considerable energy;
            * Transient Voltage Switch (TVS) - looks like a diode, very fast, less able to absorb energy, comparatively expensive;
            * Metal Oxide Varistor (MOV) - almost as fast as a TVS, can absorb almost as much energy as a gas discharge tube, inexpensive, gradually deteriorates - the trigger voltage gradually goes down until the MOV starts conducting at normal AC line voltages.
            All in all, MOVs are the most common. Cheap and effective are a good combination. MOVs can become a problem, however, in power environments where there are frequent line voltage surges. Examples would be areas that have lots of thunderstorms (= lightning strikes) or industrial areas where machinery generates line voltage surges. When an MOV deteriorates badly enough, the continual conduction soon becomes high enough to destroy (crack or blow apart) the MOV and blow the input fuse.
            PeteS in CA
            • Dannyx
              Master power switch for E-bike ideas
              by Dannyx
              Good day folks. I recently upgraded my bike with a sketchy motor and battery set I picked up from Ali. I say "sketchy" because the motor is rated 1.5kW (at least on paper), so such a retrofit is borderline illegal here and would require registration and possibly a type-A driver's license to operate on public roads, but looking past all that, it's a lot of fun and does go very fast....so fast in fact that the thing does wheelies on its own if I gun it hard enough
              There's one thing I'm looking to improve: no master kill-switch on this thing at all. The 48v battery pack...
              10-24-2021, 07:42 AM
            • Axis937
              Accidental slip of the hand caused a spark on Capacitor. Is my PANEL killed in action?
              by Axis937
              Hi folks, newbie here. My intention on a working monitor was to test for voltages on the various pins. Somewhere near the ribbon to the monitor, there we 2 caps. One was reading around 5V and the other was maybe about 12 or 14V . Cant really recall. Then it happened. The multimeter kissed the 5v cap and the other cap. Spark appeared. NOW... the part where the spark happened ( Caps near the Last ribbon cable ) is now totally white. 1/6 part of the screen is white. From my little understanding , i came to learn that there are transistors inside the TFT panel. Could that be a issue then? I have removed...
              11-10-2024, 06:50 AM
            • nicktasios
              Macintosh Quadra 840AV PSU
              by nicktasios
              I had my Quadra 840AV (which I recapped and had working) plugged in for some time without using it and randomly decided to turn it on today. Unfortunately it did not turn on. After checking the PSU, I found out I was not getting anything from 12V, only from the 5V rail. After a few minutes, I removed the PSU and plugged it back in the electrical outlet and it suddenly started making a weird sound and soon after smoke started coming out. I quickly unplugged it. I opened it up but on first instance I didn't see anything out of the ordinary really. I later turned it back on and one of the MOVs blew...
              12-22-2024, 05:07 AM
            • Fam787
              HELP! A1398 Dead,
              by Fam787
              I bought a second hand Mid 2014 A1398 MacBook Pro when I lived in Australia. I'd bought it as a back-up machine because I had a Mid 2014 MacBook Pro, and realising it might one day fail, I wanted a backup machine because I don't like change.
              Two weeks after buying MBP2, the seller called me to check if everything was OK with the unit, which I thought was odd. At that stage I might have turned it on a couple of times, but I'd not used it when he'd called. Over the last few years I used the machine seldomly because my original mac has been pretty OK. Every 3-6 months I'd charge it...
              12-27-2024, 05:19 PM
            • honeybadger0
              Yamaha EMX 512SC - Bad Limiter?
              by honeybadger0
              I have a Yamaha EMX 512sc powered mixer that gets heavy use. Recently a new problem has arisen ... it seems like the L output is way more sensitive than the R and the limiter light for main L is flashing even at very low (below the 2 setting on the knob) levels.
              It seems to be across all channels and with different inputs. The speakers have been recently tested as well and do not seem to have any of their own issues.
              Has anyone else encountered this problem and could help me out?​
              11-03-2024, 07:38 PM
