$ 96¢ LED Tester
  • capwizard
    • Jun 2016
    • 1991
    $ 96¢ LED Tester
    Happy BadCaps Veterans Day (US 11/11/2016). To whomever help whoever !
    $0.96 LED Tester is my gift give to all BadCaps Veterans
    Picture 1.2.3.------Setup ---voltage at dc 302 v current 3.68 ma
    Tested with one Zener
    Tested with one Direct LED strip
    Tested with one Edge LED strip
    Picture 9.10.---------Tested with large LED screen 5*9=45 leds * 6v-----270 v/leds
    Current limited setups at 3.68 ma (with 330 Ohm resister), up to 20 ma.
    Voltage setups at DC 302v (irregular voltage), up to DC 450 v. Please use Isolated transform If use Direct AC double or triple input.
    Thank you for watching.
  • BigOof
    Marantz SR5007 popping on volume change and mute in Direct Mode
    by BigOof
    I bought a used Marantz SR5007 and it's giving me some issues that I can't seem to really place. It functions well in most settings, ARC mostly works, it has no issues driving my speakers in any of the digital input modes, but I'm having issues running analog inputs in direct or pure direct mode. For some reason in this mode there's distortion for every volume increment I give it, but once the volume is stable it has no issues. Muting creates a loud pop, switching to another source also causes a pop and so does turning off the amp in that mode. Again, no issue in the digital modes....
    12-12-2024, 06:15 AM
  • DynaxSC
    Stubborn GIGABYTE B365M AORUS ELITE - main PCIe x16 GPU port working only in x8 width mode
    by DynaxSC
    I have this board, where I have exchanged the LGA1151 socket. During testing I discovered, that the large PCIEX16 slot won't by no force work in x16 mode, but keeps to work in x8 mode only.
    I tested this with GPU-Z, also with Render Test (but tried also Furmark and Heaven Benchmark - no effect).
    Tested on Core i5-9600K as well as on an Pentium G5420 and MSI NVIDIA GTX1070 and 2 other cards, including RTX3060Ti.
    Board architecture definitely allows x16 mode, as all 16 PCIe lanes are present between CPU and main GPU slot (nearest to CPU).
    05-04-2025, 12:08 PM
  • cheebster
    LG OLED55CX Clicking No Power
    by cheebster
    Hello, i have this OLED here, as the topic says OLED65CX.
    TV shows standby led, when pressed the PSU clicks, then shut down.
    Disconnecting the 12V VIN from the T-Con, make the TV boot up, led flashes like normal and it stays on.
    What i've tried so far:
    I have a working TV, an OLED55C1. Similar TV... Took all the boards to the C1, 1 by one, and everything works. So basically, all of these boards from the defective CX (PSU, Main, TCON) works either 1 by 1, or together on the working C1.
    However, none of the C1 boards work on the CX,...
    01-20-2025, 06:52 PM
  • MD HOST
    Esonic H61 FFL ES Original Tested Bios Bin File
    by MD HOST
    100%tested.
    Enjoy......
    10-11-2024, 11:38 AM
  • lmcancu
    RCA RLDED 4331B: 43 inch LED TV: Backlight issue
    by lmcancu
    Hi I am having an issue with the LED backlight of this TV. I can see the picture with a flash light, so I determined it was a backlight issue.
    Initially, after opening it I found 2 shorted and 1 open LED on 2 strips (total of 4). I removed the LEDs and shorted the pads together to verify if the backlight would work.
    Testing it, I found the backlight turned on and I measured 54V when TV was in standby (off), and 100v when TV was turned on. The 4 strips each contain 9 LEDs, so 36 in all minus 3.
    Instead of putting it back together I decided to replace...
    04-01-2023, 01:11 PM
