Mio Digiwalker 269
  • barry wilkins
    • Aug 2009
    • 172
    Mio Digiwalker 269
    Hi do any of you know much a bout sat navs.
    I have a Mio 269 which I have had some time now ,and it would be nice to upgrade the maps.
    I saw some thing on the internet ,I think it was showing how to unlock the device and then load Tomtom maps on to it.
    I know most sat navs use the same maps ,so I suppose it is possible.
    Any advice on this would be appreciated.
    thanks
    Barry Wilkins
  • sofles
    Bowers & Wilkins PX7 S2 Needed help with identifying charging IC
    by sofles
    Hi there,
    Recently I bought broken Bowers & Wilkins PX7 S2, the problem with them is that battery discharges on its own even with headphones turned off. It is a quite common issue with this model and even with model higher PX8.
    With help of thermal camera I found out that there is one IC that is hot even with headphones turned off. To check if I'm correct I bought another PX7 S2 working one and replaced small charging board with this IC and problem solved, battery no more drains on its own. After changing board back to original problem returned so I'm 100% sure problem...
    05-30-2025, 01:11 PM
  • sigh45
    Bowers & Wilkins PX7 S2e Internal Photo's
    by sigh45
    This is a long shot but does anyone have a photo of the USB Charge board wiring? I have a pair here that somebody has used a blowlamp to get the port off, Luckily the tracks are all good but some of the NC and filter cables were desoldered. A new port is fitted but there isn't a sniff of any marking on either side of the headphones as to the cables use. Here's hoping
    Cheers
    Simon
    11-09-2024, 07:46 AM
  • samtron786
    Tomtom GO 920 touch screen doesn't work anymore
    by samtron786
    Hi
    Tomtom GO 920 touch screen doesn't work anymore, I also tried resetting it didn't help thank you very much
    06-29-2022, 03:46 AM
  • macsoftware
    I need help a bout surface book bios me region
    by macsoftware
    hallo friends my surface book touch screen won't working after me region clean , idon t have the original dump the chip winbond is damaged plz help me
    05-09-2021, 09:33 AM
  • barry wilkins
    Battery Charging Peugot Boxer
    by barry wilkins
    I am having a problem with the starter battery in my motor caravan, the makers info is very poor so I am struggling a bit with this.
    As it is Euro 6 I think the charging is done by the ECU,not the spilt charge system with relays.
    I managed to start the engine after a boost and the voltage rose to about 14 volts ,but now it is about 11.5 volts.
    It is not charging by the EHU where the 12volt power supply is.
    It is quite complex .
    Starter battery
    Liesure battery
    Solar panel
    BCA module with relays fuses and the power supply
    The fuse in...
    01-31-2021, 12:20 PM
