Sony/Samsung HDTV with alot of AV, HDMI, Composite, PC Ports???
  • whitezombie455
    • Mar 2013
    • 9
    Hi there I am looking into buying a new television and I have come into a problem with all new HDTV's. Every tv they sell brand new current generation does not have enough ports! I am interested in a tv that has a lot of ports... and other features as well so please can someone post a list or link me to televisions that have the following specifications???:
    01. At least 3 Stereo/Composite Video ports (red white yellow)
    02. At least 3 HDMI ports
    03. At least 1 S-Video port (not a big deal if it doesn't have one)
    04. At least 1 RF port (coaxial cable port)
    05. At least 2 Component Video Ports that include a red and white (Red , White, Red, Blue, Green)
    06. At least 1 PC VGA Input & 1 PC Audio Input
    07. If the TV has internet then 1 Ethernet port (internet not a must)
    08. At least 1 USB port (Not a big deal if there isn't one)
    09. At least 1 optical out port
    10. At least 1 audio jack (if possible but not a big deal)
    11. 3D would be nice but not a must
    12. 1080p a must
    13. 42 Inches or More
    14. 60Hz or more refresh rate (At least 120Hz if 3D compatible)
    15. Would prefer it to be LED not LCD (Also must NOT be a plasma!!!)
    I found all the port definitions here if you need any clarification onto what I am talking about... http://www.bhphotovideo.com/indepth/...out-todays-tvs
    Re: Sony/Samsung HDTV with alot of AV, HDMI, Composite, PC Ports???
    You will not find a modern TV with this port set. Heck even a 5 year old TV would be lucky to have two component + two composite ports.
    What you need is an AVR, like a Onkyo TX-SR605. They have 3 component, something like 5 composite, a few Svideo and two HDMI ports. You can get other models with up to 7 HDMIs. They convert all formats to HDMI so you only set your TV to HDMI, plus they figure out audio automatically.
    Unfortunately most modern AVRs are going the same way as TVs; less and less inputs. The new Yamaha high end AVRs have two component and usually at least three or four composite, but no S-video at all. The main reason is, nearly everyone uses HDMI for everything. Everything on any TV I have set up in the past year or so is exclusively HDMI, with the exception of the old Xbox 360, which used the component port.
    The cost of such a system is likely to exceed that of buying new equipment with HDMI ports to replace the old stuff.
    • whitezombie455
      • Mar 2013
      • 9
      Re: Good HDTV with alot of AV, HDMI, Composite, PC Ports???
      Actually LCD doesn't matter to me at all... Anyways the best model closest to what I want I could find was the Samsung Model#: LN46C750
      Can you please reply with similar or even better Sony tvs?
        You won't be able to buy a C-series Samsung now - C-series is 2010. You can buy F-series (2013) or maybe E-series (2012), which in US has a combined component/composite port, usually a minimum of two HDMI, and a tuner. That's it. I'm sure you can buy an old RPTV with eleventy billion inputs, but what's the point? If you really need that many inputs then buy an older AVR and send it to a new plasma/LCD with HDMI. Or upgrade your equipment to HDMI, which is likely to be cheaper.
        • whitezombie455
          • Mar 2013
          • 9
          It took me 5 hours but I found ONE website!!! Lol.... No seriously I know it is probably cheaper to get a receiver just you would think tvs would still come with at least 2 red white yellows I mean I need it for my cable for god sakes AND I have an N64 that I occasionally play... I understand I could just get a receiver but I shouldn't have to... Anyways take a look here: http://tvsuperstores.com/Samsung_46_...HDTV_3611.html
          Sadly it is overly priced AND it in the USA and it is only via credit card... I would need it to be shippable to Canada along with able to use paypal lol... But yeah seriously idc if stores don't sell the tvs I would like but if I can find them online then that is A-okay! So please do you have any television models similar to the one I linked you to that you know of (I don't need a direct link to a website if you don't have one just a model name and brand) ???
            Panasonic's TH-42PZ8xx series plasma have two component, two rear composite + one side/front composite + 2-4HDMI. Unfortunately they are 2008 models.
            Other than that, no idea myself.
            If you only use your N64 etc occasionally, just get used to switching inputs or buy an external switch box (I got one for £3 a while ago, it took 3 composite and convert to one.)
            • Carlos#2003%
              Schematic de una Sony VAIO PCG-41217u, Sony VPCSB45FL (MBX-237), 1p-0117j01-a012 mbx-237.
              by Carlos#2003%
              Buenas mi nombre es carlos me uni al foro porque estoy buscando el schematic de una sony vaio pcg-41217u otras formas de escribirlo son 1p-0117j01-a012 mbx-237 numero de placa revision 1.2 o Sony VPCSB (MBX-237), en fin me gustaria y ayudaria un monton si alguien me puede dar dichi svhematic para hacer las mediciones de una laptop de la mencionada anteriormente(Sony VAIO PCG-41217U) con el fin de repararla dejo de funcionar solo prende el led de la bateria al pulsar el boton de power el disco empiesa a hacer ruido de actividad pero los leds del frontas no reflejan acividad y no enciende la pantalla....
              02-15-2024, 07:52 PM
            • Scruit
              What is a normal composite signal range for a C64?
              by Scruit
              Hello all,
              Working on my first C64 / Breadbin / 250407. Purchased as non-working. Getting black screen.
              More detail below, but for those that want to get right to the question.... Here are a few waveforms comparing the Pin15 output on the VIC chip (luma/sync) to the pin 4 on the AV socket (composite signal).
              https://imgur.com/gallery/PpqcqPY
              My question is: Is the composite waveform range of 0.1v-1v too low for a c64?
              More detail:
              Symptoms are that that I get...
              04-28-2022, 05:33 AM
              Sony VAIO SVF11N1L2E Hybrid (2-in-1) Fit multi-flip Specification for Upgrade or Repair
              This specification for the Sony VAIO SVF11N1L2E Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the SVF11N1L2E boardview and SVF11N1L2E schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
              09-06-2024, 05:27 AM
              Sony VAIO Duo 11 Hybrid (2-in-1) Duo 11 Specification for Upgrade or Repair
              This specification for the Sony VAIO Duo 11 Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Duo 11 boardview and Duo 11 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Sony VAIO...
              09-06-2024, 05:30 AM
              Sony VAIO VPCM12M1E/W Netbook Specification for Upgrade or Repair
              This specification for the Sony VAIO VPCM12M1E/W Netbook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the VAIO VPCM12M1E/W boardview and VAIO VPCM12M1E/W schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
