Replacement for PWM regulator AP1501-33
  • emilije
    • Aug 2010
    • 60
    Hi guys,
    In Linksys WRT54G i've found one faulty AP1501-33 PWM regulator (to263-5l housing)
    According to datasheet 33 means 3.3V
    Here in Croatian shops i can only find AP1501-50 which would be 5V. Is there any other replacement or i must find exactly AP1501-33?
    Thanx!
  • mariushm
    • May 2011
    • 3799
    Re: Replacement for PWM regulator AP1501-33
    You can replace it with anything that has the same pin arrangement but it has to be fixed value, 3.3v
    See if you can order one from Farnell ( http://www.farnell.com/ but use UK version if you can't see your country) or RS-Online ( http://hr.rsdelivers.com/?&cm_mmc=Wo..._-MainWorldMap )
    For example, these seem to be compatible with that IC
    ap1506 http://uk.farnell.com/diodes-inc/ap1...263/dp/1825316
    lm2595s-33 http://uk.farnell.com/national-semic...595/dp/1215202
    these might also work but they're designed to run at a lower frequency, which means the components used with the previous chip (inductors, capacitors) may be too small for them and thus the chip may be unstable.
    LM2575S-3.3 http://uk.farnell.com/national-semic...575/dp/8221944
    ap1512 3.3 http://uk.farnell.com/diodes-inc/ap1...263/dp/1825328
