Hello again,
I have a new problem and need some suggestions. I have bought a few Chinese led down-lights. Any one of them is rated at 12W and constructed from series connection of 12x 1W leds. They are powered with a 310mA constant current driver delivering 27-42V DC. Seller states that the driver does not respond well to triac dimming solutions on primary side.
So, I have been thinking to use some pwm or something on the secondary side between driver and the lamp. I have found a circuit http://www.reuk.co.uk/OtherImages/ne...er-circuit.gif
This circuit may be usable, but I do not know enough to determine that. I can make a power supply for ne555 circuit.
Questions:
If I use a Fet instead of npn transistor, can i use 42v in circuit connecting leds and fet drain-source and lower voltage to power the ne555 and its circuit?
Should i separate the grounds of these to circuits?
Do I need some other protection between ne555 pin 3 and fet gate if there are different voltages in these two parts of a circuit (I have seen people using opto elements in similar situations but i do not know much about them)?
Do you have some other idea about a better way to accomplish my goal with easy obtainable components? I need to make similar circuits for eight lamps, so it should be something affordable, too.
Thankful in advance,
Sasa
Questions:
Sasa
