Do you get schematics?
  • chico1st
    • Jan 2012
    • 21
    When you guys are fixing TVs, monitors, PSUs etc do you get schematics for them?
    Some troubleshooting just seems to be impossible without them.
    If you are fixing a TV and don't have the schematics do you just check all the FETs, fuses and caps? since you don't know what any voltage levels should be or do you dissect the design from the PCB?
  • 999999999
    • Sep 2006
    • 774
    Re: Do you get schematics?
    Yes, get the schematics for the specific product when possible. When not possible, try to get the datasheets for any ICs present.
    Yes check discrete components too, consider the symptoms of the device and what could cause those. You do usually have a fair idea of what voltage levels are supposed to be based on what the circuit does and often when there is a fault, voltages don't just change a little bit, they are WAY off or no voltage or in the case of bad capacitors, large ripple present that shouldn't be. The most effective repair person is someone who already has some familiarity with the electronic circuits used to make that type of device work.
    Yes otherwise you begin to dissect the design tracing either backwards until you find an unexpected value or forward from power input - again it depends on what the problem is.
    It is easier to describe method for a specific situation and hunt for info than to try to vaguely describe a methodology. Sometimes it also helps to research common faults for the specific product model, similar models from same manufacturer, and similar products from other manufacturers. When all else fails you take a modular approach and replace the most likely, entire circuit board OR decide it is not cost or time effective and abandon it... sometimes if you have no expectation that a replacement board will do any better or last any longer, it becomes an issue of whether you want to perpetually repair it.
    In other words I consider a repair far more viable if I can improve the circuit or product in some way to make it less likely to fail the same way again. That might include improving chassis ventilation, or higher spec components, adding or improving heatsinking on overheating parts. Other times it isn't important, for example if more than half the desired or reasonable product life is already over, having it last as long after repair as it did before repair is good enough so long as the value of the (working) product exceeds the time and cost to repair it.
    • retiredcaps
      • Apr 2010
      • 9271
      http://elektrotanya.com/
      --- begin sig file ---
      --- end sig file ---
      • Alfieh
        NAD C320BEE repair possibly bad capacitors
        by Alfieh
        hey Im very new to repairing electronics with capacitors as well as using a multimeter so I need so help/guidance fixing this issue
        recently I was handed a family members old NAD C320BEE that they had in their loft for storage for a few years but when powered on it went into power safety mode due to a problem on the protection circuit somewhere before it went into storage I was told it worked fine I found lots of people online talking about how the capasitors are known to be pretty bad in this model and can cause this issue the only problem being I don't have much experience sorting...
        11-19-2024, 04:55 PM
      • Popalwali
        Asus Nexus 7 2012 (ME370T REV 2.4) Schematics needed
        by Popalwali
        Hello Everyone,
        I will be really grateful if someone shares schematics and if possible the boardview of the old Asus Nexus 7 (2012) Tablet. The motherboard is ME370T Rev. 2.4. Now I can find schematics for the Rev. 1.0 but I could not find the schematics for the Rev 2.4. I tried to look for similarities in the Rev. 1 but there are somethings missing, plus the board i have has nearly no component names printed on it which as a newbie makes pretty hard for me to locate things. Any assistance will be appreciated. Thank you.
        08-25-2024, 11:28 AM
      • Techmanx
        Schematics Download Site
        by Techmanx
        If anyone needs schematic diagrams for any pro audio gear like what professional musicians use, such as guitar amps, power amplifiers, vintage tube amps, musical gear like keyboards, effects pedals, guitar wiring diagrams and service manuals, check out https://schematics.ca . I'm a road musician and an electronics tech and I got schematics for just about every piece of gear in my band from this site and they are free to download. It's always good to be prepared in case you fry something while on on the road, which always happens it seems. https://schematics-free.com has a lot of free audio schematics...
        06-28-2023, 12:08 PM
      • Plg_666
        Need schematics of Msi claw a1m
        by Plg_666
        Hello, comrades. I've encountered the following issue. I live in a small town, and we had a power outage. My girlfriend's MSI claw was unlucky because it was charging at the time and didn't turn on afterward. The local service center suggested replacing the Tps65993bh controller. However, after replacing it, the motherboard still didn't start. The technician believes that the processor might be dead, but he needs the motherboard's schematics to confirm this. Please share the motherboard schematics if you have one for this console or a laptop with a core ultra 5/7 125H/155h processor.
        10-28-2025, 01:35 AM
      • mrautom8
        Samsung TV UN75H6350AFXZC main board schematics?
        by mrautom8
        Schematics for the main board needed please. Sticker on board states BN94-07517A but the silkscreen says BN41-02157B. Cant find here or anywhere on the web.
        Backlights work when main boards disconnected. When connected and power button switched, the relay on the PSU board turns on for one second then back off.
        While relay is on, all voltage rails are present and steady (scoped) on main board.
        I love a good logic puzzle but getting lost without any schematics.
        No shorts on ANY capacitor main board.
        Thermal camera shows 3.3V inductor getting warm instantly but...
        10-19-2025, 06:32 PM
