There is some useful advice contained in the Philips LCD TV chassis FL9.1 Service Manual for the 32PFL3504D/F7 to 32PFL3514D/F7 models that I have not seen elesewhere. While a large service organisation might have hot-air desoldering guns with attachments to fit most integrated circuit packages, the amateur will find that the task of replacing surface mount ICs without inflicting damage to components and circuit board is not easy.With Soldering Iron:
1. Using desoldering braid, remove the solder from all pins of the flat pack-IC. When you use solder flux which is applied to all pins of the flat pack-IC,
you can remove it easily.
2. Lift each lead of the flat pack-IC upward one by one, using a sharp pin or wire to which solder will not adhere (iron wire). When heating the pins, use
a fine tip soldering iron or a hot air desoldering machine.
3. Bottom of the flat pack-IC is fixed with glue to the CBA; when removing entire flat pack-IC, first apply soldering iron to center of the flat pack-IC and heat
up. Then remove (glue will be melted).
4. Release the flat pack-IC from the CBA using tweezers.
(to be continued!).
