Re: KSGER T12 OLED - says ERROR or INVERT
Light stabbing on the 'loose' part of the wool. I used to wipe but sometimes solder would fly off.
I switched to T12 at a later stage but kept using brass wool. I now keep the 936 as a back up.Leave a comment:
another question,
how are you all using the wool?
i wipe the tip across it, i dont stab it into the pot.Leave a comment:
I find brass wool gives a shorter tip life, it scrapes off the plating, metal against metal. In our manufacturing plant, this was the case and techs were actually throwing the brass wool in the garbage because it kills tips fast.
A moist sponge has always worked the best for me, as long as you don't make a steam bath. "thermal shock" for a piece of plated metal does not bother it.
The T12 soldering stands have all the wrong dimensions - many mm gap so the handle droops or falls out. This machined aluminum one is stupid expensive, the tip hits hard, nothing to catch it from falling out, usual crap design.
Russians made some mods of a cheap stand.
I bought one also the angle is not correct and the opening is to wide to keep the soldering iron in place it a shame that it not made correctly because to me it would be a nice stand otherwise
I have use the brass wool and have not had a problem as such but if you clean your tip a lot it does slowly wear out your tip but I tend to run my tip a little bit hotter than maybe I should ( also have to clean the tip more often because of the higher temperature setting ) but I do not want to burn traces off the boards so there is a trade off which I willing to acceptLast edited by sam_sam_sam; 03-03-2020, 09:19 PM.Leave a comment:
Interesting. I have had the opposite experience. I had a 936 (knockoff of the hakko 936 but the "high end" kind of knockoff if you can call it that) heater element die on me and a few tips that got oxidised because of plating cracks when using sponge. I did get good millage out of it though.
I switched to T12 and brass wool. I still haven't had a dead tip or bad tip in years.
I would guess it also comes down to how the brass wool is 'packed'? Having it loosely or tightly packed in its container would act differently? (analogues to different grit sandpaper)
This machined aluminum one is stupid expensive, the tip hits hard, nothing to catch it from falling out, usual crap design.Last edited by Spider1211; 03-03-2020, 04:46 PM.Leave a comment:
brass wool is fine,
but a lot of the cheaper stuff is brass or yellow-coated steel!!
steel is to hard - brass is soft.Leave a comment:
Russians made some mods of a cheap stand.Leave a comment:
Never mind, I did not initially see the cutout in the stand for the steel wool. Although as is, it seems one would bang the tip on the stand before getting used to that angle.Leave a comment:
Get one of these instead. Try coaxing the seller in sending you one(they are already sending the metal wool as per the link you provided)
https://www.aliexpress.com/item/3245...archweb201603_Leave a comment:
Ooops that was the wrong link
This one....
https://www.aliexpress.com/item/3299...archweb201603_Leave a comment:
I want one of these
https://www.aliexpress.com/wholesale...ing+iron+stand
The reviewers say it works perfectly with the aluminium handleLeave a comment:
i made a stand - it's in the ghetto-mods thread.Leave a comment:
I found the same thing with the one that I have but I think it because the angle is not quite enough and the center of balance is off so the back end with cord is heavier than the front end of itLeave a comment:
mine is over 4 years old now, and i still have not had to replace any tips - these things never pit or burn away!!!Leave a comment:
I got it sorted - there isn't a circuit board inside the handle it is a plastic thing with clips to connect to the bit (so this is one of the higher quality handles?). The silver part unscrewed from the handle section with the stain relief and the plastic part with the clips was screwed onto that
with the iron disassembled and a tip pushed in I could get it to work, but wiith it reassembled it would not. After having a very close look I figured out that the tip can not insert far enough into the handle to contact the clips
This is because there is a white silicone insert in the front section of the handle (the end where the tip inserts) and it is a bit too long so the tip can not insert far enough. I had to tease it out a bit with a small sharp screwdriver and slice a couple of mm off with a Stanley knife.
The soldering iron now works fine
Having done a bit of soldering with it my first impressions are very positive.
I think this was a bargain at £43 inc postage for the 220V version with a built in 24V PSU, with the aluminium handle and the following tips included
T12-BC1
5x T12-BC2
T12-BC3
T12-BL
T12-D12
T12-D16
T12-ILS
T12-J02
T12-KU
T12-K
And I also bought a T12-BCM2 tip separately
The seller seems to be a general shop and they just had one of these. They listed it as new and it does look new but maybe they got it somewhere and thought it didn't work or never tried it?
If anyone else has the same problem the attached pics should helpLeave a comment:
No it is 5x
One was loose and the other 4 are KSGER branded in sealed plastic, unopened . You can see them in the photos of the original ebay listing I posted
I don't know why this was so inexpensive - they even had a best offer option but I just payed the £43 before someone else did - this was in UK pounds but it is still only about 49 eurosLast edited by dicky96; 02-04-2020, 05:24 PM.Leave a comment:
i use T12 all the time - love it!
butT12-BC1
5x T12-BC2
T12-BC3
T12-BL
T12-D12
T12-D16
T12-ILS
T12-J02
T12-KU
T12-K
those tips are normally about €3 each - that's €42 worth of tips!!
original hakko are about €35 each!Leave a comment:
T12-BC1
5x T12-BC2
T12-BC3
T12-BL
T12-D12
T12-D16
T12-ILS
T12-J02
T12-KU
T12-K
If anyone else has the same problem the attached pics should helpLast edited by dicky96; 02-04-2020, 06:11 AM.Leave a comment:
This specification for the ASUS VivoBook Vivobook Pro 15 OLED D3500QC-L1351W Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Vivobook Pro 15 OLED D3500QC-L1351W boardview and Vivobook Pro 15 OLED D3500QC-L1351W schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that...09-07-2024, 04:30 AM
This specification for the Gigabyte AERO 14 OLED BMF-72ESBB4SH Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 14 OLED BMF-72ESBB4SH boardview and 14 OLED BMF-72ESBB4SH schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...09-07-2024, 07:12 AM
This specification for the Gigabyte AERO 16 OLED BSF-A3LA964SP Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 16 OLED BSF-A3LA964SP boardview and 16 OLED BSF-A3LA964SP schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...09-07-2024, 07:12 AM
This specification for the Gigabyte AERO 14 OLED 9MF-E2USBB4SH Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 14 OLED 9MF-E2USBB4SH boardview and 14 OLED 9MF-E2USBB4SH schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...09-07-2024, 06:40 AM
This specification for the Gigabyte AERO 16 OLED BSF-73US994SH Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 16 OLED BSF-73US994SH boardview and 16 OLED BSF-73US994SH schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...09-07-2024, 06:38 AM
- Loading...
