DPS5020 dual power supply build
  • redwire
    replied
    Re: DPS5020 dual power supply build
    I love enclosures like that, could build a power amplifier...
    With the DPS modules I add (Y-caps 2,200pF or more) from (-) and (+) to chassis GND, to limit HF noise.
    Once I did try add an output choke and cap, noise was gone but the extra DC resistance ruined the regulation. A clamp-on ferrite could work. It's mainly if you want to power radios or need quiet power with little noise, I add an extra filter on the DPS output.
    Add a resistor from the bridge rectifier (-) to earth ground to limit the stray voltage due to the power transformer's leakage.
    Most DPS modules have a low-side N-ch mosfet, so they disconnect output (-) when you command it off. You can check with ohmmeter, there is no continuity from module input (-) to output (-). This can make them confusing.
    I think the mosfet allows the units to not blow up when charging batteries.
    I would rotate the bottom so air from the ventilation holes can go by the DPS for cooling.
    I also use big 10,000uF filter caps with no problems, the modules like that and RuTech recommends several 1000's uF so AC ripple does not stress the module. An 8A bridge or better, with heatsink can take the inrush and steady 5A.
    Serial comms will be an issue if both DPS modules are floating.
  • Dannyx
    replied
    Originally posted by stj View Post
    oh nice, an oldskool rack case!!
    Glad you like it
    replied
  • Dannyx
    replied
    Here's some pictures of the case that just arrived today and how I plan to lay it all out. Only one PSU module for now as you can see, but I shall prepare the second location as well for when I'll finally get the other one too. I'm actually planning to take the front panel to a CNC or router to have it machined professionally because that's 3mm thick aluminium there...sawing through that and hoping to achieve some precise cutouts would not be fun or easy. This project has gone way overboard already, so might as well go all out. Not sure if those DPS supplies deserve such a nice case, but hey...YOLO
    replied
    well with regular transformers and rectifiers you have no noise to suppress because your following the sinewave.
    the DP modules may create noise - but maybe not - they have good caps on them.
    and if they do create switching noise, any filter would have to be selected for the frequency you want to block.
  • Dannyx
    replied
    Also I remember I have this in my junk box as well. I ripped it from a plasma TV before tossing it out. Might make a nice addition to out project maybe ?
  • Dannyx
    replied
    i wouldnt worry about chokes, the DP units run at very high frequency and without a scope you would have trouble pinning down any noise to suppress.
    Are you referring to a possible choke between the bridge rectifier and the input of the modules ? My current build also doesn't have any of those - it's straight off the diode bridge, with two capacitors in parallel there.
    replied
  • Dannyx
    replied
    Inrush current might be a problem indeed, so I'm trying to come up with something like a soft-start....
    The modules themselves are the most expensive part of the build - the transformers were scored for free out of the junk pile and I already have them, so no money lost there
  • megaraider
    replied
    wth 10000uF...??? Have you done the peak current maths upon power up
    Not to mention EMI filters needed, chokes, ..., and the total cost amount...!!!
    imo, keep it simple, functional, clean and... much cheaper »
    » use DC laptop adapters (eg: 19V~3.5A, 30V~3A) to power the DPS50xx modules.
  • Dannyx
    started a topic DPS5020 dual power supply build
    Good day folks. A while back, in a different topic of mine about how I was trying to build my own adjustable power supply from scratch, someone suggested I should just scrap that idea and not bother and just get a pre-made power supply module which would be infinitely better and save me a lot of trouble and so I did: I got myself the DPS5015 of Ali after it was recommended to me, for which I built a nice little enclosure and powered it off a rather beefy UPS transformer. Granted, it was a bit pricey for my taste, but I realise now it was money worth spending because it does everything I need and more and I would have never achieved the same level of functionality and stability with my own attempt at building one.
    So now it's time for a new project, bigger, better, stronger Being very satisfied with the overall performance of these little power supplies, I of course turned to them again as the heart for my new supply and noticed an improved version came out in the meantime, the DPS5020, which can not only take an additional 5A which was already overkill but also includes a piece of software which allows the board to communicate with an app on a PC or phone so you can view and adjust your values from your PC or device. Now I must admit, although I try to call myself a semi-professional, I AM a sucker for eye-candy like this, so I had to get myself one. Again, expensive ! For my budget at least, especially since I went all-out and got the BT version which I'll probably never use Actually, the project calls for TWO of them, but I didn't have the necessary funds at the time. It has now arrived and with it sitting on my desk, it's time to start building: same two chunky UPS transformers, two 50a rectifiers, some fuses, two filter caps (more on that later), a ton of wires, enclosure....etc.
    I laid down a wiring diagram, although it's very simple: there's two circuits side by side, perfectly identical, to form a dual-output bench supply. This way I can have two completely isolated supplies or I can join their GNDs together to have a common-GND dual-output supply which is handy for testing devices which require more than one power rail (12v-5v for instance). That's the theory at least.
    There are some things I still need to work out.
    1) Let's start with the very beginning: notice how I wired the two transformers straight to the 230VAC input - should I look for some sort of EMI filtering there ? If so, what should this be ?
    2) For C1 and C2 I found some caps on Ali which CLAIM to be 10000uF/80V....is bulk capacitance a generally good idea on the input of the DC-DC modules there or should I look for some inductors as well ?
    3) ZD1 and ZD2 - 51v zener diodes. 50v is the maximum input the modules can tolerate. If the 230v input swings too high, the secondary voltage will also increase, possibly past the 50v margin, so supposedly those zeners will become biased and blow F3/F4. Good idea/bad idea ? I fear they may false-trigger often :|
    4) feel free to suggest stuff and improve on my design
    I'll keep you guys posted along the way with pictures of the build Cheers and thanks.
