Small Tiny SMD Caps, soldering technique, values and polarity?
  • dicky96
    Sun Seeker
    • Mar 2017
    • 1825
    • Spain
    Hi guys
    Me again - learning fast
    OK I have a couple questions, I'm working on a Western Digital WD10EURS controller board. I found a short circuit cap on the 5V rail and removed that.
    What I would like to know is how would I identify the value of the faulty cap? It appears to me to be a decoupling cap on the 5V rail (as it connects between te rail and ground) and I'm tempted to either think it is something like a 100nF cap, or just try the drive without it.
    While finding the fault, I removed a diode from across the 5V SATA connection to 0V. I've removed one of these before on a drive of mine which went short circuit when the computer PSU blew up (with a flash, a bang and a little fire!) and I think these are avalanche diodes for protection, anyway that drive worked OK without it.
    I also removed a SMD cap near the 5V pins on the SATA connector. This one again was between 5V and 0V
    OK so the questiond:
    1. I want to resolder the diode and cap. The diode polarity is obvious but the cap reads 10uF on my meter so would that mean it is polarised like an electrolytic? In which case how to find the polarity - there are no markings I can see. Actually it reads 10.00uF exactly in one polarity and 9.84uF the other way round - on my Fluke. Is that telling me something?
    2. What is the technique for replacing the tiny little short circuit cap. I've soldered SMD caps and resistors before but on this drive controller board they are tiny - considerably smaller than anything I tried to solder before such as SOT23 or SOIC chips which I am OK with.
    I only have an illuminated bench magnifier probably 2-3X and a 10x / 20x double ended jewelers loop
    Pics are on this thread, to save me reposting again here: https://www.badcaps.net/forum/showthread.php?t=61761 post #12.
    Rich
    Follow me on YouTube
    Learn Electronics Repair
  • diif
    • Feb 2014
    • 6978
    • England
    Re: Small Tiny SMD Caps, soldering technique, values and polarity?
    Ceramic SMD caps aren't polarised. You can solder them either way round.
    To attach i'd use either my hot air station or my iron and small curved tip (T12-JS02). Some decent flux is a must. I use Amtech 559. A paste that allows for plenty of rework time before it burns up.
    I also use a stereo microscope for SMD work, it makes things so much easier and enjoyable.
    • dicky96
      Sun Seeker
      • Mar 2017
      • 1825
      • Spain
      Thanks Diif
      Will solder the SMD cap back either way then. You guys have to realise I was brought up on valves and stuff though I have moved on a bit since then.
      A Stereo Microscope is on my list of must gets next time i am back in the UK (in 3 weeks or so).
      For Flux I use a tin of this 'Pasta do Lutowania' stuff which I have to melt with my soldering iron tip but it does wonders with desolder braid and rework in general.
      However I have seen videos on youtube where they use some sort of liquid flux and apply it with a small paint brush or dropper?
      I do worry about resoldering small smd components in densely populated parts of the PCB. I would think I might desolder other parts by mistake in the process?
      Rich
      • diif
        • Feb 2014
        • 6978
        • England
        Low air speed so nothing blows away and plenty of practice on scrap boards. That worry will soon subside.
        I prefer the thicker paste to the runny flux. I also have some cheap China Kingbo flux in a tub that i have used to full an empty syringe.
        • proxneo
          Recapping Sony ICF-SW55 - verifying cap values
          by proxneo
          Dear reader
          I am performing a repair on a Sony ICF-SW55, which includes recapping (some) of the SMD capacitors on the mainboard. I am looking for verification of their values. At the moment, I'm 95% sure I've got the right values, but it is hard to find some official, credible or multiple independant sources on this.
          At the moment, I have selected replacements based on the following list of values:
          3 x 470uF 10VDC
          3 x 4.7uF 35VDC
          4 x 47uF 50VDC
          8 x 22uF 6.3 VDC
          1 x 220uF 6.3VDC
          5 x 100uF 6.3VDC
          Which...
          06-21-2023, 12:38 AM
          LENOVO ThinkCentre M72e Tiny ThinkCentre M G465 Specification for Upgrade or Repair
          This specification for the LENOVO ThinkCentre M72e Tiny can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ThinkCentre M72e Tiny boardview and ThinkCentre M72e Tiny schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
          09-12-2024, 03:36 PM
          LENOVO ThinkCentre M72e Tiny ThinkCentre M G460 Specification for Upgrade or Repair
          LENOVO ThinkCentre M72e Tiny ThinkCentre M G470 Specification for Upgrade or Repair
