Sencore CR-143
  • Hemingray
    KABOOM!
    • Jul 2010
    • 143
    Sencore CR-143
    Scored one today, this is a rather nice CRT Tester, just need the manual to go with it, if anyone has one or knows where to download one?
    EDIT: Someone on the Antique Radio Forums has a scanned copy for me to use.
  • CapLeaker
    Revenge lil Rock 5 repair
    by CapLeaker
    Got a Revenge lil Rock 5 in for repair. It seems to be some sort of a small guitar tube amp.
    Complaint: Doesn't work.
    Fix: R13 390 Ohm 5W resistor open. Replaced it with a 7W 390 Ohm resistor, working A1.
    Didn't find any schematic online, so I scanned the paper I had....
    10-15-2021, 07:01 AM
  • jesi
    help with hp 640 g1 no display
    by jesi
    hi there everyone
    hp probook 640 g1 6050a2566302-mb-a04
    comes on to no display
    came with this fault , i have flashed the bios with almost 18 files from here
    and other places, still the same
    i can see the lcd come on but no graphics , forced the lcd backlight on with 3.3v
    but still no graphics , looking for a cpu to test if thats the issue or not
    any ideas welcome
    thanks in advance
    04-09-2019, 12:12 AM
  • jesi
    hp x360 not charging battery
    by jesi
    hi there
    hp x360 bucks uma mb 16872-1 448.0c204.0011
    all working on the charger
    all works when charger pin removed battery takes over and works
    but only will not charge battery stuck on percentage ?????
    so far changed to new battery , changed charger , also changed bq24737
    the only thing i dont understand that it has 2.6v on scl and sda on battery ??
    on this mb its using 2 sot23-6 fets on the scl sda ???
    also one sot23-6 has the marking of k702 which i think its a 2n7002 and the other...
    04-04-2019, 12:13 AM
  • Curious.George
    Antique Vizio tablet looping
    by Curious.George
    A neighbor dropped off an ancient (antique? the thing must way 2 pounds!!)) Visio VTAB1008 for me to look at. After a day on the charger, it's stuck in an endless reboot loop (can't tell it NOT to try to turn on and to, instead, just charge battery!).
    I can divert it to recovery mode which seems like it is stable enough that I could leave the tablet waiting for input for hours without a problem. I've wiped cache and separately restored factory settings (haven't, yet, tried to reinstall an image from a uSD card).
    When charger is disconnected, I just get a momentary...
    01-20-2019, 04:00 PM
  • jesi
    need help on hp x360 mb
    by jesi
    hi there
    need help on hp x360 pavilion schematic
    mb : bucks_uma_mb 16872-1 448.0c204.0011
    kb9028q ec bin file , and how to flash with a rt809f
    many thanks
    03-25-2019, 07:11 AM
